kimmi
Posted: Thu Jun 18, 2015 9:33 pm Post subject: |
I just tested
open new file and save it as 123
then press = sign and error is same _________________ / Kim
kimmi
Posted: Thu Jun 18, 2015 9:54 pm Post subject: |
Hmm , I deleted the bascom-avr.xml
and now its working OK with = sign
strange error in my Win-XP i think
will upgrade to win10 soon
tnx for the help Mark... _________________ / Kim |
Posted: Thu Jun 18, 2015 10:33 pm Post subject: |
no it is not XP. I fixed the error. And i produced the problem about selecting a single character with your settings. I did not found the reason for that yet.
I love win10. I is best of win7 and win8. _________________ Mark |
AdrianJ
Posted: Fri Jun 19, 2015 12:28 am Post subject: |
The problem that Meister is having with selection of whole words when using the mouse is somewhat similar to what I see.
In my case, if I put the cursor within a word and press the left mouse button to select that entry point, the cursor jumps to the space just before that word. The arrow keys must then be used to reposition the cursor inside the word to continue editing at that point.
Windows XP sp3
I did raise a support ticket for this, but Mark could not reproduce the issue.
I can live with it, for all the other good stuff in 2.0.7.9 _________________ Adrian Jansen
Posted: Fri Jun 19, 2015 8:44 am Post subject: |
you wrote : "I did raise a support ticket for this, but Mark could not reproduce the issue."
Please give the ticket so i can check it. It might be the same or not.
As i wrote previously, i was able to reproduce the problem Meister reported by checking the = problem. It happens when there is a special delimiter in front like () , +. But i only get this with kimmi's setting file. _________________ Mark |
Posted: Fri Jun 19, 2015 9:07 am Post subject: |
In the mean time i found the reason for the odd selection problem : it happens with some fonts. when you select consolas (a clear nice font) this problem will not occur.
I will fix it for the non block fonts too. _________________ Mark |
AdrianJ
Posted: Sat Jun 20, 2015 2:01 am Post subject: |
The support ticket re the selection problem was AHN-34922-735
I will try your suggestion with the consolas font too. _________________ Adrian Jansen
AdrianJ
Posted: Tue Jun 23, 2015 4:36 am Post subject: |
Consolas font made no difference to my problems with text selection, or the repeat key effects.
I will revert to system font, which I think looks better.
Certainly the idea of graying out sections of code which are not part of the current compiler switch setting is really useful !
But I did notice that one of my constructions like
#if _chip = 29
...code...
#endif
Where the chip number is the compiler code number for the chip, based on the regfile setting, did not show correctly. I can see why, since the editor has no prior knowledge of what chip is being compiled for. _________________ Adrian Jansen
Posted: Tue Jun 23, 2015 8:35 am Post subject: |
hi Adrian
I looked up your ticket. that was a problem that holding a key gave only 1 key. And the rest of the keys when the key was released. I could never reproduce that. But i also see i do not have a settings file from you.
So it would be best if you send me your settings file.
about the font : you need to close the window and open it again with the new font setting. I see a new font property (monofont) is not updated when you chose a new font so it only get updated when you open a file.
if it doesnt solve the digit select problem, i can have a look with your settings file. i also would need some small example code.
the _chip is unknown. it is simple to change :
in the dat file, add the _chip to the CONST section
[CONST]
_ROMSIZE = 262144
_CHIP= 43 ; m2560 _________________ Mark |
AdrianJ
Posted: Wed Jun 24, 2015 12:51 am Post subject: |
@ Mark
I sent my settings file and a sample to support, using the same ticket number.
Quote: | in the dat file, add the _chip to the CONST section |
I note there is already a constant named _CHIP in the [DEVICE] section of the dat file. So one probably has to be careful that you use the same number for the value ?
Interestingly defining the same _CHIP constant in the [CONST] section does not create a compiler error, And yes, it does then show up as active ( not greyed out ) when used in a conditional compile statement - Magic !
I guess that also means one could define a constant like _CHIPNAME in the dat file and assign a meaningful string to it, then use that as the parameter in a conditional compile. That would be better than having to look up the _CHIP number assigned from the DEVICE section. _________________ Adrian Jansen
Posted: Wed Jun 24, 2015 8:40 am Post subject: |
yes, you need to take care to use exact the same _CHIP setting.
the DEVICE setting is just setting info, these are not constants known to the compiler. Only registers and constants are known to the compiler. So adding the _CHIP to the CONST section is ok.
In the mean time the problem with the selection has been solved. will have a look at your settings file to see if i can duplicate the repeat key problem. _________________ Mark |
Posted: Thu Jun 25, 2015 8:47 am Post subject: |
The key repeat problem was also solved : this is just a setting in windows configuration. Just set the repeat delay to a lower value. _________________ Mark |
ivangel
Posted: Fri Jun 26, 2015 12:06 pm Post subject: Simulator did not work |
Simulator did not work.
The program I have installed on two computers, both this Win7 x64, one is a platform from AMD, Intel's second, after starting the simulator I get this error in attachment file _________________ www.midaz.com.pl |
Posted: Fri Jun 26, 2015 8:29 pm Post subject: |
you best send an email to support : i do not know if the problem is for all your code, or just 1 ? in any case we need the files (zipped) to check it. _________________ Mark |
ivangel
Posted: Sat Jun 27, 2015 3:55 pm Post subject: |
Ok, i send email.
Just checked and it seems that for XMEGA does not work, for ATMEGA is ok. The problem is also such that for XMEGA malfunctioning function "lookup", receives unrealistic values from the table. Include a relevant example. Greetings _________________ www.midaz.com.pl |
