Is the Assembler 'sleep' command the same as BASCOM Powerdo
TSEYFARTH
PostPosted: Fri Apr 24, 2015 8:58 pm    Post subject: Is the Assembler 'sleep' command the same as BASCOM Powerdo Reply with quote
Hello all,
Can anyone tell me if the Asm code, "sleep" is the same as MCS BASCOM "Powerdown"?
If not, can anyone tell me how to modify Everts asm code to emulate the Powerdown command of MCS BASCOM?
   ' Powerdown
 'The asm code below by Evert Dekker disables the Brownout Detect, And puts the device to sleep.
   $asm
     lds r25,MCUCR                                             'get current MCUcR
     sbr r25,&B01100000                                        'Set bit 5 & 6 (BODSE & BODS) (1 Clks)
     sts MCUcR,r25                                             'save to MCUcR (2 Clks)
     sbr r25,&B01000000                                        'Set bit 6 (BODS) (1 Clks)
     cbr r25,&B00100000                                        'Clear bit 5 (BODSE) (1 Clks)
     sts MCUCR,r25                                             'save to MCUcR (2 Clks)
     Sleep                                                     'good night  (1 Clks)
   $end Asm
Thank you,
Tim
PostPosted: Fri Apr 24, 2015 9:08 pm    Post subject: Reply with quote
sleep is an assembler mnemonic.
powerdown uses sleep too. All sleep modes require to set some bits in a register in a special sequence and end with the sleep instruction.
it differs from chip to chip.
TSEYFARTH
PostPosted: Fri Apr 24, 2015 9:28 pm    Post subject: Reply with quote
Hi Mark,
I am using an Atmega 168PA. I was using the BASCOM command "powerdown". But I wanted to also turn off the BOD. I found a thread wherein Evert wrote the asm code I included in the original post. I wanted to be sure that the effect of using the assembler mnemonic command 'sleep' was the same as the powerdown command built into BASCOM.
Tim
PostPosted: Fri Apr 24, 2015 9:43 pm    Post subject: Reply with quote
please stick to bascoms config power= . it is really the best for you to do.
or take time to read the data sheet. the MCUCR register in the mentioned chip is totally different. as far as i can see the bod can only be turned off by the fuse bits in the m168.
Table 10-1 in the pdf lists the various power modes.
laborratte
PostPosted: Mon Apr 27, 2015 2:59 pm    Post subject: Reply with quote
Hi.
The M168PA is a picoPower device and supports BOD software disable. The mechanism for enabling is identical to the chip Evert was using.
The sleep mode which is executed by the sleep instruction depends on SMCR (sleep mode control register). See datasheet chapter 10 for details.
For your specific mode and chip the assemble instructions could be as follow:
'Power down on M168PA with BOD disable
  $asm
     ldi r25,&B00000101                                        'set sleep mode to power down (SM2:0 = 010) and enable sleep (SE = 1)
     sts SMCR,r25                                              'save to SMCR
     lds r25,MCUCR                                             'get current MCUCR
     sts MCUCR,r25                                             'save to MCUCR (2 Clks)
     'sbr r25,&B01000000                                       'Set bit 6 (BODS) (1 Clks) (this line is redundant and don't need to execute)
     clr r25                                                   'it is recommend to disable sleep after wake up (see datasheet)
   $end Asm
Keep in mind that this sequence is chip specific and may not work on other chips. That is why Mark recommend to use config power...
Edit: if you are using interrupts you should encapsulate this seqence in a disable interrupts - enable interrupts instruction pair.
TSEYFARTH
PostPosted: Mon Apr 27, 2015 4:37 pm    Post subject: Reply with quote
Hi laboratte,
Yes, I know it was the same family and supports this feature. I just wanted to be sure that the sleep command is the same as the BASCOM sleep. Previously, I was using only the built in commands. I started looking into turning off BOD as saw the thread on the forum - discussing the timing issues and the necessity to use asm - which I have not a clue about coding.
I see the differences you made and thank you. I had not tested either yet but plan to today.
One thing, can you tell me what r25 means?
Thank you again,
Tim
laborratte
PostPosted: Mon Apr 27, 2015 4:47 pm    Post subject: Reply with quote
r25 is one of 32 general purpose registers of the CPU. Nearly every data transfer and caluculation has to be done with these registers. For details see Chapter 7 of 168PA's datasheet.
TSEYFARTH
PostPosted: Mon Apr 27, 2015 5:20 pm    Post subject: Reply with quote
Thanks will do!
Tim
PostPosted: Mon Apr 27, 2015 10:02 pm    Post subject: Reply with quote
Sorry, i had the wrong PDF open. Laboratte is right. The P(A) indeed supports this for some of the sleep modes. it is probably a good idea to add this option.
TSEYFARTH
PostPosted: Mon Apr 27, 2015 10:09 pm    Post subject: Reply with quote
Thanks for the confirmation Mark.
Have a wonderful evening!
Tim
