TSEYFARTH
Posted: Tue Sep 02, 2014 5:40 am Post subject: Bootloader via RS485? |
Hello all,
Has anyone been able to get a bootloader to work via an RS485 interface in the middle? What I am suggesting is to use the same BASCOM Bootloader with the correct baud rate, but instead of a direct connection between the PC serial port, and the uC; a RS485 <--> RS485 exists in the middle.
If so can you share sample code?
Thank you,
Tim
i.dobson
Posted: Tue Sep 02, 2014 7:33 am Post subject: |
Just use the Standard bootloader. You just Need to modify it a bit to handle the Setting/resetting of the transmit pin (Have a look at the config print command)
Regards
TSEYFARTH
Posted: Tue Sep 02, 2014 6:11 pm Post subject: |
Hi and Thank you Ian,
I was trying to figure out where to put the RTS control - you answered it!
Thanks again,
Tim |
i.dobson
Posted: Tue Sep 02, 2014 6:27 pm Post subject: |
No problems. Glad to be of service.
Regards
TSEYFARTH
Posted: Wed Sep 03, 2014 4:11 am Post subject: |
Ian,
I have got to tell you again, and Mark for the first time - THANK YOU!!
That is SOOOOO COOOOLLLLL! I had no idea that command even existed! I have always had to guess when to turn on/off RTS, and this is just amazingly COOL!
Again, thank you!!!!!
Tim |
