gabriel.moreano.epn
Posted: Fri Jul 04, 2014 6:20 pm Post subject: Help with USART |
Hello everyone my name is Gabriel, I have a problem with USART communication, I need to connect two atmega and that they have the same temperature value read from a sensor, I can send a character (print chr) and read in the atmega 2 with a inkey () but I need to know if you could send and read numbers with decimals, eg 37.5, the programs I'm using both atmegas is:
ATMEGA2
'1 Configuracion Principal
$regfile = "m164pdef.dat"
$crystal = 8000000
$baud = 9600
'2 Configuracion de Puertos
Ddra = &B00000000
Porta = &B00000000
'3 Configuracion de Perifericos
Config Com1 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Lcd = 16 * 2
Config Lcdbus = 4
Config Lcdpin = Pin , Db4 = Portb.0 , Db5 = Portb.1 , Db6 = Portb.2 , Db7 = Portb.3 , E = Portb.4 , Rs = Portb.5
Cls
Cursor Off
Start Adc
'4 Definicion de Variables
Dim Temp As Word , Temp1 As Word
Dim Temperatura As Single , Temperatura1 As Byte
Dim Tempcabina As Single , Tempcabina1 As Byte
Dim A As Single
A = 100 / 1024
'5 Programa Principal
Temp = Getadc(0)
Waitms 150
Temp1 = Getadc(1)
Waitms 150
Temperatura = Temp * A
Tempcabina = Temp1 * A
Temperatura1 = Temperatura
Tempcabina1 = Tempcabina
Print Chr(temperatura1)
Print Chr(tempcabina1)
Locate 1 , 1
Lcd "temp: " ; Fusing(temperatura , "##.#")
Locate 2 , 1
Lcd "tcabina: " ; Tempcabina1
ATMEGA 2
$crystal = 8000000
Ddra = &B00000000
Porta = &B00000000
Config Serialin = Buffered , Size = 4
Config Lcd = 16 * 2
Config Lcdbus = 4
Cls
Cursor Off
Dim Temperatura(3) As Byte , Auxtemp As Byte
Dim Tempcabina As Byte , Auxtempcabina As Byte
Dim Aux As Byte , Aux1 As Byte
Dim Oxigeno As Byte
Dim Cardiaco As Byte
Dim Humedad As Byte
Dim Settemp As Byte
Dim Sethumedad As Byte
Oxigeno = 93
Cardiaco = 65
Humedad = 55
Settemp = 37
Sethumedad = 55
Aux = Ischarwaiting()
If Aux = 1 Then
Temperatura(1) = Inkey()
Temperatura(2) = Inkey()
Temperatura(3) = Inkey()
If Temperatura(1) > 0 Then
Auxtemp = Temperatura(1)
Else
Else
Aux1 = Ischarwaiting()
If Aux1 = 1 Then
Tempcabina = Inkey()
If Tempcabina > 0 Then
Auxtempcabina = Tempcabina
Else
Else
Locate 1 , 1
Lcd "temp: " ; Auxtemp ; " "
Locate 2 , 1
Lcd "tcabina: " ; Auxtempcabina ; " "
Print Auxtemp
Print Auxtempcabina
Print Oxigeno
Print Cardiaco
Print Humedad
Print Settemp
Print Sethumedad
Posted: Fri Jul 04, 2014 9:39 pm Post subject: |
First -> Made shortcut to Wiki http://wiki.mcselec.com/bavr/BASCOM-AVR_Help
Easier to read than help pdf. Read : PRINT, FUSING, ISCHARWAITING, INPUT, INKEY, WAITKEY and ECHO. All with examples there.
Then You can think... You can print String like
Code: | Print Fusing(s , "#.##") 'prints 123.46 | and directly display it on second LCD as string..
or You can multiply by 10 and send as Word..and many other ways.
I made little PC program that decode this string and display parameters on desktop (it can send commands in other side too)
Code: | Tekst_pwm = Str(x)
Tekst_t = Str(odczyt)
Tekst_tryb = Str(tryb)
Tekst_pilnuj = Str(pilnuj)
Tekst_hist = Str(hist)
Message = Tekst_tryb + " " + Tekst_t + " " + Tekst_pwm + " " + Tekst_pilnuj + " " + Tekst_hist + " "
Print Message |
Please Log In if You want see picture. |
gabriel.moreano.epn
Posted: Fri Jul 04, 2014 11:38 pm Post subject: |
Might you give me a code example of how to read the number with decimals in atmega, the shipping is no problem but reading |
JC
Joined: 15 Dec 2007 Posts: 585 Location: Cleveland, OH
Posted: Sat Jul 05, 2014 7:16 pm Post subject: |
I don't know if you are running a simulation, or on real hardware.
Your schematics for the power and ground connections are NOT the same on the two micros.
Note that Vcc AND AVcc must be tied to V+. You have not shown the connection on the second micro.
Note that BOTH grounds on the M164 need to be tied to ground.
You show ARef tied to Vcc on one micro. Do NOT do this. This can damage the micro.
You can connect ARef to a cap to ground.
JC |
Posted: Sat Jul 05, 2014 9:29 pm Post subject: |
Here You have a tested one.
Code: | $regfile = "attiny2313a.dat"
$crystal = 8000000
$baud = 38400
Config Serialin = Buffered , Size = 10
Cls
Lcd "String "
Dim S As String * 5
If Ischarwaiting() = 1 Then
Input S
Locate 1 , 8 : Lcd S
End |
I test it moment before post this so its okay, and working. Note that in Terminal You must send Enter because Input waiting for it. You can use Waitkey Inkey, Do what You want, just test. Note that Ischarwaiting need Enable Interrupts.
Maybe Ischarwaiting You can use like that:
Code: |
While Ischarwaiting >0
Input S
Wend
Try use Fusing only once:
Code: |
Temperatura1 = Fusing(temperatura , "##.#")
Lcd Temperatura1
Print Temperatura1
