suibaf
Posted: Mon Apr 14, 2014 6:16 pm Post subject: array error |
To avoid unpleasant reproaches I tryed to search for my problem, but I have not found the answer. If there is, can you sign me please?
In the help file there is :
Code: | 'the empty () indicated that an array will be passed
In my case I have a sub that I have declared:
Code: | Declare Sub Lcd_message(byval Indice_messaggio As Byte , Byval Message_array() As Byte) |
and then I tryed to use with no success:
Code: | Lcd_message(1 , Ric_idcard()) |
I tryed with call, without with different message error as you can see at row 276 and 312
Apologize if the question is fool, but I don't understand something.
BR
(BASCOM-AVR version : 2.0.7.7 ) _________________ Bascom AVR full |
Posted: Mon Apr 14, 2014 6:59 pm Post subject: |
Code: | Declare Sub Lcd_message(byval Indice_messaggio As Byte , Message_array() As Byte)
dim ar(10) as Byte , b as byte
for b = 1 to 10
ar(b) = b
next
lcd_message 3 , ar(1)
print message_array(Indice_messaggio)
end sub |
in the declare you use () but when passing data, you need to pass the first element.
also notice that arrays are passed byref. _________________ Mark |
suibaf
Posted: Mon Apr 14, 2014 9:32 pm Post subject: |
Mr. Alberts,
you are right, and in the file help is wrote, only now I have read. But I use also in this mode without warning message:
Code: | Ceck_ric_reader_rfid Rcv_buff() |
Where is the difference?
BR _________________ Bascom AVR full |
Posted: Mon Apr 14, 2014 9:55 pm Post subject: |
when you omit an element, the first will be used. but it is much better to be specific. _________________ Mark |
suibaf
Posted: Tue Apr 15, 2014 10:17 pm Post subject: |
Quote: | also notice that arrays are passed byref. |
OK thank you Mr. Alberts, it's clear. But I've notice that if I have a sub:
Code: | Declare Sub Lcd_message(byval Indice_messaggio As Byte , Message_array() As Byte) |
Message_array is passed byref. But inside sub when I use Message_array i have no correct value! (strange value that i no understand). So only for test inside sub I used original array and the value is correct!
Is there some concept that i lose?
Posted: Tue Apr 15, 2014 10:39 pm Post subject: |
without code it is hard to tell.
but the concept of passing an array is simple : you pass byreference which means you pass the address of the array.
in the sub you refer to this array with the name you used to pass.
Code: | dim ar(10) as byte
declare sub test(some() as byte)
print some(1) 'will print content of ar(1)
end sub
if the content is not right, test if the passed array is still ok.
you should post some code that demos your problem. (no screen shots) _________________ Mark |
suibaf
Posted: Thu Apr 17, 2014 10:14 pm Post subject: |
when you call the sub, use : Lcd_message 1 , Rcv_buff(1)
that is, the first array element.
if you get strange values, it might be because of an interrupt. in that case, increase $hwstack _________________ Mark |
