Robert_d1968
Posted: Mon Feb 10, 2014 7:22 pm Post subject: Shutter control |
How many people would be interested in a camera shutter control that can go from 1ms to over a 1 minute delay at a 1 millisecond resolution. Serial port controlled and an external trigger?
This thing has motor current control (via serial port) and motor control in both directions.
The best one I have seen in America costs 800.00 usd and is not even close to this!
If enough are interested in it, I'll release the code for it.
Robert
PS. I forgot to mention it has a 10,000,000 cycle life! |
enniom
Posted: Tue Feb 11, 2014 12:35 am Post subject: |
Your flag and country ID don't match! |
Posted: Tue Feb 11, 2014 12:55 am Post subject: |
one can have a different location and flag. the flag is just to identify your country of origin. but one can work in another country. _________________ Mark |
AdrianJ
Posted: Tue Feb 11, 2014 7:44 am Post subject: |
Camera shutter control for which make and model of camera ? _________________ Adrian Jansen
Posted: Tue Feb 11, 2014 10:49 pm Post subject: |
The thing with project, code, code snippets, etc. is that you never know when it is useful to someone. Maybe over 2 years someone will find this and be very happy. One can not know. _________________ Mark |
pseddon
Posted: Wed Feb 12, 2014 4:57 pm Post subject: Re: Shutter control |
For what type of camera: DSLR, digital, film or ...?
Peter
ps this offers considerable flexibility http://triggertrap.com/
[quote="Robert_d1968"]How many people would be interested in a camera shutter control that can go from 1ms to over a 1 minute delay at a 1 millisecond resolution. Serial port controlled and an external trigger?
Robert
PS. I forgot to mention it has a 10,000,000 cycle life![/url] |
Robert_d1968
Posted: Wed Feb 12, 2014 6:01 pm Post subject: |
We seem to be thinking about this the wrong way.
This is not controlling your camera shutter, it's an external shutter that is controlled via an interface board ( also designed by me) that resides in a host computer. It's pretty high end and mostly for industrial usage.
But none the less could be adopted for any brand of camera.
Robert |
bzijlstra
Posted: Wed Feb 12, 2014 7:16 pm Post subject: count me in.. |
I am interested.
Have fun
Ben Zijlstra |
bzijlstra
Posted: Wed Feb 12, 2014 7:38 pm Post subject: count me in.. |
I am interested.
Have fun
Ben Zijlstra |
snipsnip
Posted: Wed Feb 12, 2014 9:23 pm Post subject: |
another interested vote.
some more application info would be cool.
cheers |
snipsnip
Posted: Wed Feb 12, 2014 9:31 pm Post subject: |
edit - double post, don't hit browser refresh! |
AdrianJ
Posted: Wed Feb 12, 2014 10:36 pm Post subject: |
Sounds neat. I can see uses other than for cameras as well.
But in most most digital cameras you cannot hold the internal shutter open indefinitely ( the old "bulb" setting ). So you would need to somehow interface with the camera enough to open the internal shutter, do the good stuff with your external shutter, then close the internal one. Once you can interface that far, you might as well use the internal shutter. These already have speed ranges of typically 1/2000 down to 8 secs or so. _________________ Adrian Jansen
Robert_d1968
Posted: Thu Feb 13, 2014 1:20 am Post subject: |
OK,
I need to change the proto types current sensor just a bit, I will release it in just a couple of days time.
It seems When I made it. I had it set up to work with milliamps of current instead of amps!
I will release it under the Share your working Bascom Avr code here.
Just the same as I have released the last entire project project, I will do the same with this one...
Robert |
Robert_d1968
Posted: Fri Jun 13, 2014 2:15 pm Post subject: |
Ok,
I'm going two release it within two days time. It's a brand new version and ultra small.
My computer will be down for a coupe of days time (moving) but after the internet is up again, I'll upload the
entire project for the shutter control.
As a bonus I'll through in the ECU (electronic control unit) project for it too.
The ECU was designed to be put into a small fan less computer and uses the sata22 pin connector to draw it's power from.
The ecu has a lot of I/O built into it and is fully opto isolated both inputs and outputs. Four of the inputs are 3.3vdc
tolerant the rest are five volt tolerant. All outputs are fused and can switch up to 1.5 amps of current.
More to list but not enough room.
Robert_d1968
