Posted: Thu Apr 17, 2014 10:00 pm Post subject: |
options, environment, Editor, Draw indention lines. _________________ Mark |
njepsen
Posted: Thu Apr 17, 2014 10:16 pm Post subject: |
thanks Mark. Only place I didnt look.
I am getting a windows error msg when I use the code explorer variables and when I attempt to close a file.I'll send some screen shots next week. _________________ Neil |
Deanus
Posted: Fri Apr 18, 2014 12:11 am Post subject: |
Hi Njepsen,
It's in Options, Environment, Top check box, and if you want the lines, check box second from bottom.
Regards
Dean |
mariofer
Posted: Fri Apr 18, 2014 3:06 pm Post subject: |
Hello
in this Bascom version i notate this error during parameters passing to function..
if pass negative number using variable it's ok
but if pass directly negative number , give an error
Declare Function Dac_out_010v(byval v_in As Integer) As Word
val=750
Dac_val = Dac_out_010v(val) OK
val=-750
Dac_val = Dac_out_010v(750) OK
Dac_val = Dac_out_010v( - 750) ERROR invalid data type 0010
and put space from - and 750
Regards
Mario |
njepsen
Posted: Tue Apr 22, 2014 8:18 am Post subject: err with 2.0.7.7 |
This error appears if I try to close a file having just used window/tile vertically
Quote: |
= 22/04/2014 7:15:13 p.m. =
There was an error during the execution of this program.
The application might become unstable and even useless.
It's recommended that you save your work and close this application.
Access violation at address 00405320 in module 'bascavr.exe'. Read of address FFFFFFDC.
Exception log with detailed tech info. Generated on 22/04/2014 7:14:47 p.m..
You may send it to the application vendor, helping him to understand what had happened.
Application title: BASCOM-AVR
Application file: C:\Program Files\MCS Electronics\2077\BASCOM-AVR\bascavr.exe
Exception class: EAccessViolation
Exception message: Access violation at address 00405320 in module 'bascavr.exe'. Read of address FFFFFFDC.
Exception address: 00405320
Main thread ID = 2768
Exception thread ID = 2768
Exception stack
Stack list, generated 22/04/2014 7:14:47 p.m.
(00004320){bascavr.exe } [00405320]
(0058741E){bascavr.exe } [0098841E] Unknown function at madTraceProcess + $534DAA
(0057C4ED){bascavr.exe } [0097D4ED] Unknown function at madTraceProcess + $529E79
(00275E9A){bascavr.exe } [00676E9A] Unknown function at madTraceProcess + $223826
(00275E37){bascavr.exe } [00676E37] Unknown function at madTraceProcess + $2237C3
(00275DF4){bascavr.exe } [00676DF4] Unknown function at madTraceProcess + $223780
(00276B2A){bascavr.exe } [00677B2A] Unknown function at madTraceProcess + $2244B6
(002755C6){bascavr.exe } [006765C6] Unknown function at madTraceProcess + $222F52
(0025A934){bascavr.exe } [0065B934] Unknown function at madTraceProcess + $2082C0
(002755E7){bascavr.exe } [006765E7] Unknown function at madTraceProcess + $222F73
(00256A26){bascavr.exe } [00657A26] Unknown function at madTraceProcess + $2043B2
(0024FAC9){bascavr.exe } [00650AC9] Unknown function at madTraceProcess + $1FD455
(0024FC06){bascavr.exe } [00650C06] Unknown function at madTraceProcess + $1FD592
(00248948){bascavr.exe } [00649948] Unknown function at madTraceProcess + $1F62D4
(00248E0A){bascavr.exe } [00649E0A] Unknown function at madTraceProcess + $1F6796
(0024913B){bascavr.exe } [0064A13B] Unknown function at madTraceProcess + $1F6AC7
(000C1B99){bascavr.exe } [004C2B99] Unknown function at madTraceProcess + $6F525
(00588824){bascavr.exe } [00989824] Unknown function at madTraceProcess + $5361B0
(000DD84F){bascavr.exe } [004DE84F] Unknown function at madTraceProcess + $8B1DB
(000DD926){bascavr.exe } [004DE926] Unknown function at madTraceProcess + $8B2B2
(000DDC1B){bascavr.exe } [004DEC1B] Unknown function at madTraceProcess + $8B5A7
(0059F9C7){bascavr.exe } [009A09C7] Unknown function at madTraceProcess + $54D353
Call stack for main thread
Stack list, generated 22/04/2014 7:14:48 p.m.
(0000D514){ntdll.dll } [7C90E514] KiFastSystemCallRet + $0
(00104017){bascavr.exe } [00505017] Unknown function at madTraceProcess + $B19A3
(00BFFAC9){bascavr.exe } [01000AC9] Unknown function at madTraceProcess + $BAD455
(0010409C){bascavr.exe } [0050509C] Unknown function at madTraceProcess + $B1A28
(0010636A){bascavr.exe } [0050736A] Unknown function at madTraceProcess + $B3CF6
(001060F1){bascavr.exe } [005070F1] Unknown function at madTraceProcess + $B3A7D
(00107C1C){bascavr.exe } [00508C1C] Unknown function at madTraceProcess + $B55A8
(000BE457){bascavr.exe } [004BF457] Unknown function at madTraceProcess + $6BDE3
(000C245B){bascavr.exe } [004C345B] Unknown function at madTraceProcess + $6FDE7
(000B97BA){bascavr.exe } [004BA7BA] Unknown function at madTraceProcess + $67146
(002CABBA){bascavr.exe } [006CBBBA] Unknown function at madTraceProcess + $278546
(000D5797){bascavr.exe } [004D6797] Unknown function at madTraceProcess + $83123
(0006FA10){bascavr.exe } [00470A10] madTraceProcess + $1D39C
(000C1B84){bascavr.exe } [004C2B84] Unknown function at madTraceProcess + $6F510
(0021DFE9){bascavr.exe } [0061EFE9] Unknown function at madTraceProcess + $1CB975
(0007C9E0){bascavr.exe } [0047D9E0] madTraceProcess + $2A36C
(000DD8EC){bascavr.exe } [004DE8EC] Unknown function at madTraceProcess + $8B278
(000D9C63){bascavr.exe } [004DAC63] Unknown function at madTraceProcess + $875EF
(00107B73){bascavr.exe } [00508B73] Unknown function at madTraceProcess + $B54FF
(00107201){bascavr.exe } [00508201] Unknown function at madTraceProcess + $B4B8D
(000F8BC0){bascavr.exe } [004F9BC0] Unknown function at madTraceProcess + $A654C
(000F9276){bascavr.exe } [004FA276] Unknown function at madTraceProcess + $A6C02
(000DDD41){bascavr.exe } [004DED41] Unknown function at madTraceProcess + $8B6CD
(00275E55){bascavr.exe } [00676E55] Unknown function at madTraceProcess + $2237E1
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Processor: Intel, Intel(R) Core(TM) i3 CPU 560 @ 3.33GHz, 3350 MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 64 bits DEP
Memory: 3574; free 2285
Display : 1920x1080 pixels, 32 bpp
List of loaded modules:
[00350000] C:\WINDOWS\system32\Normaliz.dll
<00400000> 6.0.5441.0 - 6.0.5441.0 (winmain(wmbla).060628-1735)
Unicode Normalization DLL
[00360000] C:\Program Files\MCS Electronics\2077\BASCOM-AVR\BSCAVRL.DLL
<00400000> (no module version info)
[003B0000] C:\Program Files\Citrix\ICA Client\ShellHook.dll
<10000000> 13.4.0.25 - 13.4.0.25
Citrix Receiver ShellHook DLL
[00400000] C:\Program Files\MCS Electronics\2077\BASCOM-AVR\bascavr.exe
2.0.7.7 - 2.0.7.7
BASCOM-AVR IDE
Unit versioning information:
JCL\source\common JclResources.pas 3850 2012-08-28 16:44:17 +0200 (mar. 28 août 2012)
JCL\source\common JclBase.pas 3865 2012-09-05 20:00:33 +0200 (mer. 05 sept. 2012)
JCL\source\windows JclWin32.pas 3796 2012-05-23 15:57:30 +0200 (mer. 23 mai 2012)
JCL\source\common JclLogic.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclStringConversions.pas 3795 2012-05-16 21:09:59 +0200 (mer. 16 mai 2012)
JCL\source\common JclCharsets.pas 3819 2012-08-14 11:25:52 +0200 (mar. 14 août 2012)
JCL\source\common Jcl8087.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclMath.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclStreams.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\common JclAnsiStrings.pas 3668 2012-01-03 20:03:51 +0100 (mar. 03 janv. 2012)
JCL\source\common JclUnicode.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\common JclWideStrings.pas 3759 2012-03-04 19:39:47 +0100 (dim. 04 mars 2012)
JCL\source\common JclStrings.pas 3770 2012-03-11 18:27:44 +0100 (dim. 11 mars 2012)
JCL\source\windows JclRegistry.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\common JclSynch.pas 3759 2012-03-04 19:39:47 +0100 (dim. 04 mars 2012)
JCL\source\windows JclShell.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\windows JclSecurity.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclDateTime.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclFileUtils.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\windows JclConsole.pas 3724 2012-02-12 23:30:08 +0100 (dim. 12 févr. 2012)
JCL\source\common JclSysUtils.pas 3860 2012-09-03 16:52:06 +0200 (lun. 03 sept. 2012)
JCL\source\common JclUnitVersioning.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\windows Snmp.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclIniFiles.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclSysInfo.pas 3843 2012-08-22 17:40:33 +0200 (mer. 22 août 2012)
JCL\source\windows JclPeImage.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\common JclUnitVersioningProviders.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\windows JclTD32.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\windows JclHookExcept.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\windows JclDebug.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\common JclRTTI.pas 3759 2012-03-04 19:39:47 +0100 (dim. 04 mars 2012)
JCL\source\common JclMime.pas 3599 2011-09-03 00:07:50 +0200 (sam. 03 sept. 2011)
JCL\source\common JclSimpleXml.pas 3861 2012-09-04 16:08:04 +0200 (mar. 04 sept. 2012)
JCL\source\vcl JclVclResources.pas 3675 2012-01-05 23:59:27 +0100 (jeu. 05 janv. 2012)
JCL\source\vcl JclGraphUtils.pas 3815 2012-08-13 12:46:22 +0200 (lun. 13 août 2012)
[01CD0000] C:\Program Files\MCS Electronics\2077\BASCOM-AVR\BASC-AVR.DLL
<00200000> 2.0.7.7 - 2.0.7.7
BASCOM-AVR Compiler
[04750000] C:\Program Files\MCS Electronics\2077\BASCOM-AVR\BASCPDF.DLL
<10000000> 1.0.0.1 - 1.0
PDF Reader DLL
[049F0000] C:\Program Files\MCS Electronics\2077\BASCOM-AVR\SaxComm7.ocx
<10000000> 7.0.0.2182 - 7, 0, 0, 2182
Sax Comm Objects 7.0
[06D40000] C:\Malwarebytes' Anti-Malware\mbamext.dll
<10000000> 1.2.0.0 - 1, 2, 0, 0
[06D60000] C:\Program Files\Acronis\TrueImageHome\timounter.dll
<10000000> 4.0.0.610 - 4,0,0,610
timounter Dynamic Link Library
[06E60000] C:\Documents and Settings\jepsen\Application Data\Dropbox\bin\DropboxExt.22.dll
<10000000> 1.0.0.22 - 1.0.0.22
Dropbox Shell Extension
[07010000] C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll
<10000000> 10.1.9.22 - 10.1.9.22
PDF Shell Extension
[070A0000] C:\Program Files\WinMerge\ShellExtensionU.dll
<10000000> 1.16.8.0 - 1.16.8
WinMerge Shell Integration library
[071F0000] C:\WINDOWS\system32\ftd2xx.dll
<10000000> 3.2.7.0 - 3.02.07
FTD2XX Dynamic Link Library
[07260000] C:\Program Files\Acronis\TrueImageHome\versions_page.dll
<10000000> 14.0.0.5519 - 14,0,0,5519
Versions Page
[072A0000] C:\PROGRA~1\PSPADE~1\PSPADS~1.DLL
[073D0000] C:\WINDOWS\system32\xpsp2res.dll
<00010000> 5.1.2600.5512 - 5.1.2600.5512 (xpsp.080413-2113)
Service Pack 2 Messages
[080E0000] C:\WINDOWS\system32\odbcint.dll
<00400000> 3.525.1132.0 - 3.525.1132.0 (xpsp.080413-0852)
Microsoft Data Access - ODBC Resources
[08100000] C:\Program Files\Acronis\TrueImageHome\tishell.dll
Acronis True Image Shell Extensions
[085F0000] C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCR80.dll
<78130000> 8.0.50727.6195 - 8.00.50727.6195
Microsoft® C Runtime Library
[08790000] C:\Program Files\NCH Software\ExpressZip\ezcm.dll
<10000000> (no module version info)
[087C0000] C:\WINDOWS\system32\MSVCP110.dll
<10000000> 11.0.51106.1 - 11.00.51106.1 built by: Q11REL
[08850000] C:\WINDOWS\system32\MSVCR110.dll
[08FF0000] C:\WINDOWS\system32\msls31.dll
<00400000> 3.10.349.0 - 3.10.349.0
Microsoft Line Services library file
[10000000] c:\progra~1\citrix\icacli~1\rshook.dll
Citrix Reverse Seamless Hook DLL
[10930000] C:\WINDOWS\system32\PortableDeviceApi.dll
5.2.5721.5145 - 5.2.5721.5145 (WMP_11.061018-2006)
Windows Portable Device API Components
[23200000] C:\Program Files\Ipswitch\WS_FTP 12\wsftpsi.dll
12.3.0.1 - 12,3,0,1
wsftpsi Module
[23700000] C:\Program Files\Ipswitch\WS_FTP 12\res0409.dll
[3CEA0000] C:\WINDOWS\system32\mshtml.dll
8.0.6001.19412 - 8.00.6001.19412 (longhorn_ie8_gdr.130228-1739)
Microsoft (R) HTML Viewer
[3D7A0000] C:\WINDOWS\system32\jscript.dll
5.8.6001.23141 - 5.8.6001.23141
Microsoft (R) JScript
[3D930000] C:\WINDOWS\system32\wininet.dll
Internet Extensions for Win32
[3DFD0000] C:\WINDOWS\system32\iertutil.dll
Run time utility for Internet Explorer
[3E1C0000] C:\WINDOWS\system32\ieframe.dll
Internet Explorer
[4EC50000] C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22791_x-ww_c8dff154\gdiplus.dll
5.2.6002.22791 - 5.2.6002.22791 (vistasp2_ldr.120203-0237)
Microsoft GDI+
[59A60000] C:\WINDOWS\system32\dbghelp.dll
5.1.2600.5512 - 5.1.2600.5512 (xpsp.080413-2105)
Windows Image Helper
[5AD70000] C:\WINDOWS\system32\uxtheme.dll
6.0.2900.5512 - 6.00.2900.5512 (xpsp.080413-2105)
Microsoft UxTheme Library
[5B860000] C:\WINDOWS\system32\NETAPI32.dll
5.1.2600.6260 - 5.1.2600.6260 (xpsp_sp3_gdr.120706-1619)
Net Win32 API DLL
[5D360000] C:\WINDOWS\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\MFC90ENU.DLL
9.0.30729.6161 - 9.00.30729.6161
MFC Language Specific Resources
[5EDD0000] C:\WINDOWS\system32\olepro32.dll
[603B0000] c:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
4.0.30319.1 - 4.0.30319.1 (RTMRel.030319-0100)
Microsoft .NET Runtime Execution Engine
[61880000] C:\WINDOWS\system32\oleacc.dll
7.0.2600.6153 - 7.0.2600.6153 (xpsp_sp3_gdr(oobla).110926-1140)
Active Accessibility Core Component
[63F00000] c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorie.dll
2.0.50727.3053 - 2.0.50727.3053 (netfxsp.050727-3000)
Microsoft .NET IE MIME Filter
[65E20000] C:\WINDOWS\system32\itss.dll
5.2.3790.4186 - 5.2.3790.4186 (srv03_sp2_qfe.071108-1306)
Microsoft® InfoTech Storage System Library
[65E50000] C:\WINDOWS\system32\itircl.dll
5.2.3790.2453 - 5.2.3790.2453 (srv03_sp1_qfe.050525-1536)
Microsoft® InfoTech IR Local DLL
[68000000] C:\WINDOWS\system32\rsaenh.dll
5.1.2600.5507 - 5.1.2600.5507 (xpsp.080318-1711)
Microsoft Enhanced Cryptographic Provider
[6C3F0000] C:\Program Files\AVG\AVG2014\avglogx.dll
14.0.0.4110 - 14.0.0.4110
AVG Logging Library
[6CD00000] C:\Program Files\AVG\AVG2014\avgntopensslx.dll
AVG NT OpenSSL Library
[6D3D0000] C:\Program Files\AVG\AVG2014\avgse.dll
14.0.0.4134 - 14.0.0.4134
AVG Shell Extension
[6D710000] C:\Program Files\AVG\AVG2014\avgsysx.dll
AVG SYS Library
[71AA0000] C:\WINDOWS\system32\WS2HELP.dll
5.1.2600.5512 - 5.1.2600.5512 (xpsp.080413-0852)
Windows Socket 2.0 Helper for Windows NT
[71AB0000] C:\WINDOWS\system32\WS2_32.dll
Windows Socket 2.0 32-Bit DLL
[71AD0000] C:\WINDOWS\system32\wsock32.dll
Windows Socket 32-Bit DLL
[71B20000] C:\WINDOWS\system32\mpr.dll
Multiple Provider Router DLL
[71BF0000] C:\WINDOWS\System32\SAMLIB.dll
SAM Library DLL
[71C10000] C:\WINDOWS\System32\ntlanman.dll
5.1.2600.5512 - 5.1.2600.5512 (xpsp.080413-2108)
Microsoft® Lan Manager
[71C80000] C:\WINDOWS\System32\NETRAP.dll
Net Remote Admin Protocol DLL
[71C90000] C:\WINDOWS\System32\NETUI1.dll
NT LM UI Common Code - Networking classes
[71CD0000] C:\WINDOWS\System32\NETUI0.dll
NT LM UI Common Code - GUI Classes
[72D10000] C:\WINDOWS\system32\msacm32.drv
5.1.2600.0 - 5.1.2600.0 (xpclient.010817-1148)
Microsoft Sound Mapper
[72D20000] C:\WINDOWS\system32\wdmaud.drv
WDM Audio driver mapper
[73000000] C:\WINDOWS\system32\winspool.drv
Windows Spooler Driver
[73BA0000] C:\WINDOWS\system32\sti.dll
Still Image Devices client DLL
[74320000] C:\WINDOWS\system32\ODBC32.dll
3.525.3012.0 - 3.525.3012.0 (xpsp_sp3_gdr.101108-1643)
Microsoft Data Access - ODBC Driver Manager
[74AE0000] C:\WINDOWS\system32\CFGMGR32.dll
5.1.2600.5512 - 5.1.2600.5512 (xpsp.080413-2111)
Configuration Manager Forwarder DLL
[754D0000] C:\WINDOWS\system32\CRYPTUI.dll
5.131.2600.5512 - 5.131.2600.5512 (xpsp.080413-2113)
Microsoft Trust UI Provider
[75970000] C:\WINDOWS\system32\MSGINA.dll
Windows NT Logon GINA DLL
[75A70000] C:\WINDOWS\system32\MSVFW32.dll
5.1.2600.5512 - 5.1.2600.5512 (xpsp.080413-0845)
Microsoft Video for Windows DLL
[75CF0000] C:\WINDOWS\system32\MLANG.dll
Multi Language Support DLL
[75F60000] C:\WINDOWS\System32\drprov.dll
Microsoft Terminal Server Network Provider
[75F70000] C:\WINDOWS\System32\davclnt.dll
Web DAV Client DLL
[75F80000] C:\WINDOWS\system32\browseui.dll
Shell Browser UI Library
[76360000] C:\WINDOWS\system32\WINSTA.dll
Winstation Library
[76380000] C:\WINDOWS\system32\msimg32.dll
GDIEXT Client DLL
[76390000] C:\WINDOWS\system32\IMM32.DLL
Windows XP IMM32 API Client DLL
[763B0000] C:\WINDOWS\system32\comdlg32.dll
Common Dialogs DLL
[76600000] C:\WINDOWS\System32\CSCDLL.dll
Offline Network Agent
[76990000] C:\WINDOWS\system32\ntshrui.dll
Shell extensions for sharing
[769C0000] C:\WINDOWS\system32\USERENV.dll
Userenv
[76B20000] C:\WINDOWS\system32\ATL.DLL
3.5.2284.2 - 3.05.2284
ATL Module for Windows XP (Unicode)
[76B40000] C:\WINDOWS\system32\winmm.dll
5.1.2600.6160 - 5.1.2600.6160 (xpsp_sp3_gdr.111014-1624)
MCI API DLL
[76BF0000] C:\WINDOWS\system32\PSAPI.DLL
Process Status Helper
[76C30000] C:\WINDOWS\system32\WINTRUST.dll
5.131.2600.6285 - 5.131.2600.6285 (xpsp_sp3_gdr.120824-1617)
Microsoft Trust Verification APIs
[76C90000] C:\WINDOWS\system32\IMAGEHLP.dll
5.1.2600.6198 - 5.1.2600.6198 (xpsp_sp3_gdr.120229-1643)
Windows NT Image Helper
[76E80000] C:\WINDOWS\system32\rtutils.dll
Routing Utilities
[76EB0000] C:\WINDOWS\system32\TAPI32.DLL
Microsoft® Windows(TM) Telephony API Client DLL
[76F60000] C:\WINDOWS\system32\WLDAP32.dll
Win32 LDAP API DLL
[76FD0000] C:\WINDOWS\system32\CLBCATQ.DLL
2001.12.4414.700 - 2001.12.4414.700
[77050000] C:\WINDOWS\system32\COMRes.dll
[77120000] C:\WINDOWS\system32\oleaut32.dll
5.1.2600.6341 - 5.1.2600.6341
[773D0000] C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
6.0.2900.6028 - 6.0 (xpsp_sp3_qfe.100823-1643)
User Experience Controls Library
[774E0000] C:\WINDOWS\system32\ole32.dll
5.1.2600.6168 - 5.1.2600.6168 (xpsp_sp3_gdr.111101-1829)
Microsoft OLE for Windows
[77690000] C:\WINDOWS\system32\NTMARTA.DLL
Windows NT MARTA provider
[77920000] C:\WINDOWS\system32\SETUPAPI.dll
Windows Setup API
[77A20000] C:\WINDOWS\System32\cscui.dll
Client Side Caching UI
[77A80000] C:\WINDOWS\system32\CRYPT32.dll
5.131.2600.6239 - 5.131.2600.6239 (xpsp_sp3_gdr.120601-1620)
Crypto API32
[77B20000] C:\WINDOWS\system32\MSASN1.dll
5.1.2600.5875 - 5.1.2600.5875 (xpsp_sp3_gdr.090904-1413)
ASN.1 Runtime APIs
[77B40000] C:\WINDOWS\system32\appHelp.dll
Application Compatibility Client Library
[77BD0000] C:\WINDOWS\system32\midimap.dll
Microsoft MIDI Mapper
[77BE0000] C:\WINDOWS\system32\MSACM32.dll
Microsoft ACM Audio Filter
[77C00000] C:\WINDOWS\system32\version.dll
Version Checking and File Installation Libraries
[77C10000] C:\WINDOWS\system32\msvcrt.dll
7.0.2600.5512 - 7.0.2600.5512 (xpsp.080413-2111)
Windows NT CRT DLL
[77DD0000] C:\WINDOWS\system32\ADVAPI32.dll
5.1.2600.5755 - 5.1.2600.5755 (xpsp_sp3_gdr.090206-1234)
Advanced Windows 32 Base API
[77E70000] C:\WINDOWS\system32\RPCRT4.dll
5.1.2600.6022 - 5.1.2600.6022 (xpsp_sp3_gdr.100813-1643)
Remote Procedure Call Runtime
[77F10000] C:\WINDOWS\system32\GDI32.dll
5.1.2600.5698 - 5.1.2600.5698 (xpsp_sp3_gdr.081022-1932)
GDI Client DLL
[77F60000] C:\WINDOWS\system32\SHLWAPI.dll
6.0.2900.5912 - 6.00.2900.5912 (xpsp_sp3_gdr.091207-1454)
Shell Light-weight Utility Library
[77FE0000] C:\WINDOWS\system32\Secur32.dll
5.1.2600.5834 - 5.1.2600.5834 (xpsp_sp3_gdr.090624-1305)
Security Support Provider Interface
[78130000] C:\WINDOWS\system32\urlmon.dll
OLE32 Extensions for Win32
[78480000] C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCP90.dll
Microsoft® C++ Runtime Library
[78520000] C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCR90.dll
[785E0000] C:\WINDOWS\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_028bc148\mfc90.dll
MFCDLL Shared Library - Retail Version
[79000000] C:\WINDOWS\system32\mscoree.dll
4.0.31106.0 - 4.0.31106.0 (Main.031106-0000)
[7C420000] C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCP80.dll
[7C800000] C:\WINDOWS\system32\kernel32.dll
5.1.2600.6293 - 5.1.2600.6293 (xpsp_sp3_gdr.121001-1622)
Windows NT BASE API Client DLL
[7C900000] C:\WINDOWS\system32\ntdll.dll
5.1.2600.6055 - 5.1.2600.6055 (xpsp_sp3_gdr.101209-1647)
NT Layer DLL
[7C9C0000] C:\WINDOWS\system32\shell32.dll
6.0.2900.6242 - 6.00.2900.6242 (xpsp_sp3_gdr.120608-1638)
Windows Shell Common Dll
[7D1E0000] C:\WINDOWS\system32\msi.dll
3.1.4001.5512 - 3.1.4001.5512
Windows Installer
[7E290000] C:\WINDOWS\system32\shdocvw.dll
Shell Doc Object and Control Library
[7E410000] C:\WINDOWS\system32\USER32.dll
Windows XP USER API Client DLL
[7E4B0000] C:\WINDOWS\system32\HHCTRL.OCX
5.2.3790.4110 - 5.2.3790.4110 (srv03_sp2_qfe.070702-2345)
Microsoft® HTML Help Control
[7E720000] C:\WINDOWS\system32\SXS.DLL
Fusion 2.5
Active Controls hierarchy:
TDCMemo "view"
TMDICHild "MDIChild_4"
Posted: Tue Apr 22, 2014 8:28 am Post subject: |
maybe it is because Val is a reserved world ?
see the help
JP |
Posted: Mon Apr 28, 2014 12:43 pm Post subject: |
@mario I checked it and you are right. I have changed it in the mean time and am running some tests before i release a fix.
if you write to support you can get a fix too.
@njepsen i tried to reproduce it but i can't. let me know if there is a way to reproduce it. _________________ Mark |
njepsen
Posted: Mon Apr 28, 2014 10:40 pm Post subject: |
I will do that Mark.
cheers _________________ Neil |
Madf
Posted: Sat Jun 14, 2014 12:58 pm Post subject: |
Good afternoon Mark.
Today trying understand with the new version (BASCOM v2.0.7.7). Why it does not work the old projects. The result: decided to take a simple code ...
Code: | $regfile = "xm32a4def.dat"
$hwstack = 64
$swstack = 64
$framesize = 100
$crystal = 32000000
'$lib "xmega.lib"
'$external _xmegafix_clear
'$external _xmegafix_rol_r1014
Config Osc = Enabled , 32mhzosc = Enabled , Extosc = Enabled , Startup = Extclk
Config Clock = Soft , Rtc = 1khz_32khz_crystosc , Gosub = Sectic
Config Porte.3 = Output
Config Xpin = Porte.3 , Invertio = Enabled ' inverting port
Led Alias Porte.3
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled ', Hi = Enabled
!nop
Sectic:
Toggle Led
When loading this code into the microcontroller - nothing happens?
LED does not flash (for an interrupt).
One gets the feeling that XMega just will not start.
Read the documentation and examples - the result is zero.
ps: forced to return back version of BASCOM 2.0.7.6. |
