Deanus
Posted: Tue Feb 21, 2012 7:39 am Post subject: Retting Resetting BITS, Lots of them |
Hi Guys,
I have the need to set and reset lots of bits.
Each bit correcponds to a menu if items
Eg:
MenuItem1 Bit1
MenuItem2 Bit2
MenuItem3 Bit3
MenuItem4 Bit4
To as many as is required menu Items and the associated bits.
The menu items are held in an array and requires a bit for each (to enable or disable a test or function)
The array system does not support bits, So I endeavored to write a sub that looked for the bit you wish to
set/reset, figured out which byte the bit was in, and did the set / reset.
I had set up an array of bytes.
Dim Bitbyte(4) As Byte
Dim Ln As Byte
'Load Ram variables from EEprom
Bitbyte(1) = 0
Bitbyte(2) = 0
Bitbyte(3) = 0
Bitbyte(4) = 0
In the process of trying various ways of doing this, I accidentally forgot to change the byte number
and ended up with a command like
toggle bitbyte(1).13
and to my surprise, it worked.
So I wrote the following small routine to try it out, and it too works.
It goes through 32 bits setting,printing to terminal and resetting & printing to terminal.
Since I can't find any mention of this on the Net or Bascom help files, (bit setting in bytes, yes, but not bits in other bytes)
I guess my question is to Albert or any of you guys that know Bascom inside out.
Is this a legal Bascom way of bit setting and resetting.
I have already put it in my program (an 8535) and it seems to work a treat, just don't know whether it might play funny buggers down the track.
I would just like to add that I am impressed with all people on this forum that spend time helping the masses to achieve their goals
with the minimum fuss, and I thank you all.
Test code below.
(don't forget to turn Terminal on to see the results)
$regfile = "8535DEF.dat"
$hwstack = 20 ' default use 32 for the hardware stack
$swstack = 40 ' default use 10 for the SW stack
$sim
Dim Bitbyte(4) As Byte '=32 bits
Dim Ln As Byte
Bitbyte(1) = 0
Bitbyte(2) = 0
Bitbyte(3) = 0
Bitbyte(4) = 0
Bitbyte(1).14 = 1
For Ln = 1 To 32
Bitbyte(1).ln = 1
Print Ln ; " " ; Bitbyte(1).ln ; " "; ' Notice in all four lines within the fornext, the byte is ALWAYS Bitbyte(1)
Bitbyte(1).ln = 0 ' the .LN is the bit number up to 32 bits in this example
Print Bitbyte(1).ln
Loop |
Posted: Tue Feb 21, 2012 11:52 am Post subject: |
yes the bit works on all integer numeric variables.
you can have a bit array of 0-31 when you use a long :
dim L as Long
L.0=1
set L.31
dim idx as byte
reset L.idx _________________ Mark |
Deanus
Posted: Tue Feb 21, 2012 11:52 pm Post subject: |
Excellent, thanks Mark
Deanus |
