Run ADC on ATMega1280...???
Ajaxelectronic
PostPosted: Wed Sep 28, 2016 2:21 pm    Post subject: Run ADC on ATMega1280...??? Reply with quote
Hi
how can we run ADC in the ATMega1280A chip?
i wrote a code. it work in proteus but not work in real, i get random value between 258 to 385 only. my hardware is right. i have 10uH inductor and 100nF capacitor for LCP in AVCC. AVcc and Aref pins are connected together.
i test my code with of f, Avcc, Aref, internal_1.1 and internal_2.56 for my reference voltage, but not work none.
this is my code :
$regfile = "M1280def.dat"
$crystal = 11059200
$hwstack = 256
$swstack = 256
$framesize = 320
$baud = 9600
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Configurations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Config Lcd = 20 * 4
Config Lcdpin = Pin , Db7 = Porta.7 , Db6 = Porta.6 , Db5 = Porta.5 , Db4 = Porta.4 , E = Porta.3 , Rs = Porta.2
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Variables
dim w(16) as word
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Initializations
initlcd
cursor off
cls
home
lcd "Ready..."
waitms 500
cls
enable interrupts
config adc=SINGLE, prescaler=auto , REFERENCE = off
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Main Program
do
 start adc
 w(1)=getadc(0)
 w(2)=getadc(1)
 w(3)=getadc(2)
 w(4)=getadc(3)
 w(5)=getadc(4)
 w(6)=getadc(5)
 w(7)=getadc(6)
 w(8)=getadc(7)
 w(9)=getadc(8)
 w(10)=getadc(9)
 w(11)=getadc(10)
 w(12)=getadc(11)
 w(13)=getadc(12)
 w(14)=getadc(13)
 w(15)=getadc(14)
 w(16)=getadc(15)
 stop adc
 home
 lcd "0:";w(1);"  4:";w(5);"  8:";w(9)
 locate 2,1
 lcd "1:";w(2);"  5:";w(6);"  9:";w(10)
 locate 3,1
 lcd "2:";w(3);"  6:";w(7);"  10:";w(11)
 locate 4,1
 lcd "3:";w(4);"  7:";w(8);"  11:";w(12)
 w(1)=0
 w(2)=0
 w(3)=0
 w(4)=0
 w(5)=0
 w(6)=0
 w(7)=0
 w(8)=0
 w(9)=0
 w(10)=0
 w(11)=0
 w(12)=0
 w(13)=0
 w(14)=0
 w(15)=0
 w(16)=0
 waitms 1000
loop
end
www.mrkelectronic.blogfa.com
Best Regards
View user's profile Visit poster's website Yahoo Messenger
i.dobson
PostPosted: Wed Sep 28, 2016 3:23 pm    Post subject: Reply with quote
I'm also using a mega1280 and don't have any problems with the adc. I'm using:-
Config Adc = Single , Prescaler = Auto , Reference = Avcc
Start Adc
maybe try starting the ADC (even though the help texts says it isn't necessary).
If avcc and aref are tied together you should use avcc as your ADC reference. I'm not sure how the AVR would react if you set the reference to any other voltage than avcc.
Regards
Ian Dobson
Ajaxelectronic
PostPosted: Wed Sep 28, 2016 4:09 pm    Post subject: Reply with quote
Hi i.dobson
thanks alot. i try your code. but it doesn't work for me. Crying or Very sad Crying or Very sad Crying or Very sad
Best Regards
Ajaxelectronic
PostPosted: Wed Sep 28, 2016 5:36 pm    Post subject: Reply with quote
yes...
my chip was corrupted. i change my chip and it work now.
other question. what is the best way for measuring effective voltage of a pulse train? this pulse frequency changing between 150Hz to 10KHz.
Best Regards
i.dobson
PostPosted: Wed Sep 28, 2016 6:06 pm    Post subject: Reply with quote
Do you want to measure the "average voltage" or the frequency of the pulse?
For average voltage you could use a RC filter (resistor & capacitor)
For frequency maybe try using an Interrupt Input that fires on a rising or falling edge, and Count the number of pluses per second.
Regards
Ian Dobson
Ajaxelectronic
PostPosted: Thu Sep 29, 2016 12:11 am    Post subject: Reply with quote
yes, i want to measure average voltage and frequency. i measure frequency and don't have problem with it. but in measuring average voltage i have problem.
i not use RC filter yet. what is R and C value? i think it depend on frequency but we have a wide range of frequency(150Hz to 10Khz).
how can we calculate R and C value?
Best Regards
i.dobson
PostPosted: Thu Sep 29, 2016 11:14 am    Post subject: Reply with quote
Have a look here http://sim.okawa-denshi.jp/en/CRtool.php that should help you calculate the correct values for R&C.
Regards
Ian Dobson
Ajaxelectronic
PostPosted: Fri Sep 30, 2016 9:56 pm    Post subject: Reply with quote
thank you i.dobson
i calculate my R and C value for this low pass filter. but it can pass my frequency just. my problem is my ADC value does change very very fast and i don't have a steady state for ADC value.
Best Regards
i.dobson
PostPosted: Sat Oct 01, 2016 7:19 am    Post subject: Reply with quote
Maybe try increasing the value of C. Also try measurung the voltage with a Volt meter. You might Need to use a Software filter on the AVR (have a look here for a good example http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13285&highlight=smoothing ).
Regards
Ian Dobson
Ajaxelectronic
PostPosted: Sat Oct 01, 2016 5:52 pm    Post subject: Reply with quote
thanks a lot
i buy an IC for convert RMS to Dc value. my chip is AD736 and i want to running it. i thinks this is better way.
thanks again
Best Regards
