Ture11
Posted: Fri Jun 24, 2016 9:32 am Post subject: New Bascom AVR SE on Windows 2000 |
Hello,
I wanted to install (first time) a new Bascom AVR (fresh CD version, newly buyed) on a computer running Windows 2000 (Polish language), where is already installed the Bascom 8051.
After a trouble-free installation, I tried to start Bascom AVR first; it reported a lack of library GdiPlus.dll, so I downloaded it from the web and placed it to the place indicated by the error message.
After the program startup began to report a new message:
Code: | bascavr.exe - not found the entry point not found
The procedure entry point wcsnlen library msvcrt.dll. |
From what I read, it is a popular error associated with different MSVCRT versions of the file. I tried to replace this file (msvcrt.dll) with a file copied from Bascom 8051 and other downloaded from the net, but it nothing helped.
The OS of this computer cannot be changed or upgraded, it must be Win2000PL.
Is there a solution? FAQ doesn't helps me.
Thanks.
Evert :-)
Ture11
Posted: Fri Jun 24, 2016 10:15 am Post subject: |
Hi again,
Thanks. As I understand, since some version of Bascom AVR, the later systems are not supported... Can You tell me, since which version the WIN2000 is not supported?
Is there still any possibility to install it on Win2000 with some combinations or it is definitely not possible? |
Posted: Fri Jun 24, 2016 10:30 am Post subject: |
you really should stay away from windows 2000 and XP. Especially when the PC is connected to the internet.
when you install, make sure you have admin rights.
and install into a folder like c:\basavr so you do not have problems with access rights.
the dll you can download from our web the download section. otherwise, write to support.
Some dll need to be registered with regsvr32 from the command line, in the folder where the dll resides.
We do not check the latest versions on w2000 anymore, but i see no reason why it would not work. _________________ Mark |
Ture11
Posted: Fri Jun 24, 2016 12:57 pm Post subject: |
it does not change a thing.
I am installing W2000 into a VM and see how it goes. _________________ Mark |
Ture11
Posted: Fri Jun 24, 2016 1:08 pm Post subject: |
Thank You very much, Mark! I do not have access to a this WIN2000 computer at this moment |
Ture11
Posted: Fri Jun 24, 2016 1:42 pm Post subject: |
Thank You again,
I will try to do everything what was described by You and I believe it will help. |
Ture11
Posted: Fri Jun 24, 2016 3:30 pm Post subject: |
Okay, the problem was in GDIPLUS.DLL, i have no idea, what was wrong. Now it works!
Thank You very much! |
