nicofer
Posted: Fri May 27, 2016 8:18 am Post subject: AVR Dos File Time/Date |
I use AVR DOS and all is fine but the file TIME and DATE when listed on a PC is not correct .
I use it to do GPS data log so I load the TIME$ and date$ and use other time functions so I would think that the
same time and date info would be used when the file is created on the SD Card ?
I might have the syntax wrong
Is there any way to transfer a ( log ) file via " SOFTWARE USB" to a PC - maybe with a app on pc side ? I do not want to take the sd card out and use a card reader - I use a MEGA128
Any ideas ?
Nico
Posted: Fri May 27, 2016 10:42 am Post subject: |
hello,
you have a dedicated forum for AVR-Dos
and it is a good idea to show the code how you record your data.
JP |
nicofer
Posted: Fri May 27, 2016 10:56 am Post subject: |
Thanks , will post it there , the data or format is not so important , it is more the system itself that need to save the time and date info with the file name , I do not know the inside workings or how that is done , just need to know what and how I should feed it to get the correct file date& time created info.
Thanks anyway.
Cheers |
Duesentrieb72
Posted: Fri May 27, 2016 12:04 pm Post subject: |
" Is there any way to transfer a ( log ) file via " SOFTWARE USB" to a PC - maybe with a app on pc side ? I do not want to take the sd card out and use a card reader - I use a MEGA128 "
for this have a look on FTDI VNC2 Vinculum-II USB host controller...
http://www.ftdichip.com/Products/ICs/VNC2.htm |
Posted: Fri May 27, 2016 9:47 pm Post subject: |
With this you can switch the sd card from avr to usb.
Mass storage is not handle by the avr, but with the Maxim chip. Gives very good transfer rate. _________________ www.evertdekker.com Bascom code vault |
nicofer
Posted: Wed Jun 01, 2016 8:04 pm Post subject: |
Thanks for the replies.
I will have a look at the usb options , pcb real estate is limited , so thats why I would like the avr to perform this task , speed is not a real issue but then , talk is cheap , they say .
I found my syntax problem with the file date and time , wrong terminator!
Cheers |
nicofer
Posted: Wed Jun 01, 2016 8:22 pm Post subject: |
The Maxim chip seems like the perfect solution,have you used it?
Cheers |
