jynx
Posted: Fri May 13, 2016 11:00 pm Post subject: XMEGA256A3BU Hardware / Software I2C |
I am trying to have a single MCU read as many I2C sensors as possible. The sensors will not be on the same I2C bus. I am using a XMEGA256A3BU and have tested I2C communication to my sensor with BASCOM. I have tested a single sensor using software I2C and hardware I2C interfaces . The XMEGA256A3BU has 2 I2C channels. Is it possible to use the 2 hardware based I2C channels along with I2C software based channels as well? How many software based I2C channels can BASCOM support? Can I use SPI channels at the same time as well? I am considering going with an MCU that has 4 I2C channels, but would still like to use additional software based I2C channels as well. Just trying to figure out what my possibilities are in the shortest time.
Posted: Tue May 17, 2016 10:26 am Post subject: |
you might want to check the multibus lib :
Code: | '------------------------------------------------------------------------------
'name : I2C-multibus.bas
'copyright : (c) 1995-2014, MCS Electronics
'purpose : demonstrates I2C multibus library
'micro : Mega88
'suited for demo : no, lib not included in demo
'commercial addon needed : no
$regfile="m88def.dat"
$crystal=8000000
$hwstack=32
$swstack=24
$framesize=24
config i2cbus=0,scl=portc.0,sda= portc.1 'each bus requires a configuration of the SCL and SDA pins
config i2cbus=1,scl=portc.2,sda= portc.3 'this sample creates 4 busses
config i2cbus=2,scl=portd.2,sda= portd.3
config i2cbus=3,scl=portd.4,sda= portd.5
Dim j as Byte
For j=0 to 3 'the first bus is 0 !!!
i2cbus=j 'select the BUS
i2cinit 'init the pins and state
for j=0 to 3
i2cbus=j 'select the bus
I2CSend &H40, &B01010101 'send some data
next
waitms 100
end |
_________________ Mark |
Mrshilov
Posted: Tue May 17, 2016 12:27 pm Post subject: |
Also in multibus you can reduce pins using common SDA line:
Code: | config i2cbus=0,scl=portc.0,sda= portc.1 'each bus requires a configuration of the SCL and SDA pins
config i2cbus=1,scl=portc.2,sda= portc.1 'this sample creates 4 busses
config i2cbus=2,scl=portd.2,sda= portc.1
config i2cbus=3,scl=portd.4,sda= portc.1 |
