atmega64
Posted: Fri May 06, 2016 2:35 pm Post subject: Waveplayer stereo |
I used the example of Glen Aidukas (for the stereo file version) for building a stereo wave file player.
The problem is that on one channel, the audio is ok and on a channel, the audio is disturbed.
I did the test using the same amp once for one channel and then to another, then the circuit is ok.
Something is wrong with the code?
I have attached two audio file to better understand the problem.
It 'a good project would be a shame if I do not solve this problem, help
thank you.
' Project: Wave Audio file player. (only plays wave riff PCM format)
' Play Wave format, RIFF, Mono max 44KHz/stereo max 22KHz, 8bit, PCM audio file
' Version for stereo wave files
' By: Glen Aidukas
'=====[ Compiler Directives ]===================================================
$regfile = "m1284Pdef.dat" '"m644pdef.dat"
$crystal = 18432000 ' 18.432 MHz
$baud = 38400
$hwstack = 100
$swstack = 100
$framesize = 100
'=====[ Includes ]==============================================================
$include "Config_MMC.bas" ' Load SD/MMC code and config
$include "Config_AVR-DOS.BAS" ' Load FAT File system code
'$include "WavePlayerLib.bas" ' PlayWaveFile code.
Const Vsw = "2.1"
Const Wp_bufsize = 250 ' Size of each (A&B) buffers
Const Wp_statusnoerrors = 0 ' No errors
Const Wp_statusbadfile = 1 ' Not a wave file!
Const Wp_statusbadwavformat = 2 ' Bad format (Bits|SampleRate|Other)
Const Wp_bufa = 0 ' Buffer A
Const Wp_bufb = 1 ' Buffer B
Const Wp_bufempty = 0 ' Buffer status Empty
Const Wp_buffull = 1 ' Buffer status Full
Dim Wp_btemp1 As Byte ' Needed for Fat Drivers
Dim Wp_filename As String * 14 ' Fat Filename
Dim Wp_buf As String * 4 ' misc. text
Dim Wp_buf_a (wp_bufsize ) As Byte ' buffer A for double buffering
Dim Wp_buf_b (wp_bufsize ) As Byte ' buffer B for double buffering
Dim Wp_a_buf_status As Byte ' buffer A full (1) or empty (0)
Dim Wp_b_buf_status As Byte ' buffer B full (1) or empty (0)
Dim Wp_activebuffer As Byte ' Actively playing buffer [0|1]
Dim Wp_bufpos As Byte ' Position in the active buffer
Dim Wp_status As Byte ' return status
Dim Wp_numchannels As Byte ' 1 or 2 channels
Dim Wp_bitspersample As Word ' 8 or 16 bits (only 8 at the moment)
Dim Wp_samplerate As Word ' Sample rate (EX: 8k|11K|22k|other)
Dim Wp_byterate As Word ' Read Bytes per second
Dim Wp_blockalign As Word '
Dim Wp_chunksize As Long '
Dim Wp_filesize As Long ' Size of wave file in bytes
' misc. vars
Dim Wp_ch As Byte '
Dim Wp_lx As Long '
Declare Sub Getwavefileinfo (wp_filename As String)
'Declare Sub Playwavefile(wp_filename As String)
Dim Btemp1 As Byte ' used by filesystem
Dim Filename As String * 12 ' Fat Filename
Dim Flag_error_sd As Byte
'=====[ Config misc stuff ]=====================================================
Config Serialout = Buffered , Size = 100 ' Serial Buffering
Config Serialin = Buffered , Size = 254
Print
Print "SW V" ; Vsw
Print "Init. file system SD CARD... ";
Waitms 100
Flag_error_sd = 0
Btemp1 = Initfilesystem(1) ' Init Partition 1
If Btemp1 <> 0 Then
Print "Error: " ; Btemp1
Flag_error_sd = 1
Print "OK"
Filename = Dir( "*.wav")
On Compare1a Wp_play_isr ' set up interrupt vector
Print "Starting..."
If Filename <> "" Then
Getwavefileinfo Filename
Print
Print "Filename : " ; Filename
If Wp_status = Wp_statusbadfile Then
Print "Bad File!"
Goto Sound_error
Open Filename For Binary As # 10
''' Make sure its something we know how to play...
If Wp_numchannels <> 1 And Wp_numchannels <> 2 Then
Wp_status = Wp_statusbadwavformat
Print "Unknown format or Bad Format!"
Goto Sound_error
If Wp_bitspersample <> 8 Then
Print "Unknown format!"
Goto Sound_error
Print "BitRate : " ; Wp_samplerate
Print "Channels : " ; Wp_numchannels
Print "BitsPerSecond : " ; Wp_bitspersample
Print "SampleRate : " ; Wp_samplerate
Print "BlockAlign : " ; Wp_blockalign
Print "ChunkSize : " ; Wp_chunksize
Print "FileSize : " ; Wp_filesize
'=====[ Config Timer2 for PWM audio output ]=================================
' This is done by using the PWM out puts on Timer2 (OC2A and OC2B)
Config Timer2 = Pwm , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 1
Stop Timer2
'=====[ Setup Timer1 for sample pushing isr ]================================
' Timer1 is used for setting the rate for pushing the samples to timer2 (PWM)
Config Timer1 = Timer , Prescale = 1 , Compare A = Disconnect , Clear Timer = 1
Stop Timer1
'On Compare1a Wp_play_isr ' set up interrupt vector
''' setup compare1a reload value to match the SampleRate
Wp_lx = _xtal / Wp_samplerate ' CPU Speed / SampleRate of wave file
Compare1a = Wp_lx
Wp_lx = 45 : Seek # 10 , Wp_lx ' seek to start of data at location 45
''' start loading buffers
Get # 10 , Wp_buf_a (1) , , Wp_bufsize ' preload buffer A
Wp_a_buf_status = Wp_buffull ' mark buffer A as full
Get # 10 , Wp_buf_b (1) , , Wp_bufsize ' preload buffer B
Wp_b_buf_status = Wp_buffull ' mark buffer B as full
Wp_activebuffer = Wp_bufa ' start with buf 0
Wp_bufpos = 0 ' Reset the buffer possition
'======[ start playing file!!! ]============================
Start Timer1 : Start Timer2
Enable Compare1a
''' Watch the two buffers and fill them up when ether is emty
While Eof(# 10) = 0
If Wp_a_buf_status = Wp_bufempty Then
Elseif Wp_b_buf_status = Wp_bufempty Then
' Both buffers are full here so this would be a good place to
' do some other stuff if needed. DON'T TAKE TOO LONG THOUGH!
Wp_ch = Inkey()
If Wp_ch = " " Then
Wp_lx = Lof(# 10) ' skip to end ...
Seek # 10 , Wp_lx
Wend
Disable Compare1a
Stop Timer1 : Stop Timer2
Close # 10
Sound_error :
Filename = Dir() 'next wave
Waitms 500
Loop Until Filename = ""
Filename = Dir( "*.wav") 'torna al primo wave
Print : Print "End list"
Waitms 500
End 'end program
Wp_samplerate = 0 : Wp_numchannels = 0 : Wp_bitspersample = 0 ' clear old values
Wp_buf = ""
Open Wp_filename For Binary As # 10
''' Read file format
Get # 10 , Wp_buf , 9 , 4 ' should be "WAVE"
If Wp_buf <> "WAVE" Then
Close # 10
Get # 10 , Wp_numchannels , 23 ' Read number of channels (1|2, Mono|Stereo)
Get # 10 , Wp_samplerate , 25 ' Read Sample rate (EX: 8k|11K|22k|other)
Get # 10 , Wp_byterate , 29 ' Read Bytes per second
Get # 10 , Wp_bitspersample , 35 ' Read bits per sample (8|16)
Get # 10 , Wp_blockalign , 33 ' BlockAlignment
Get # 10 , Wp_chunksize , 41 ' ChunkSize
Wp_filesize = Lof(# 10) ' Get file size
Close # 10
'=====[ WP_Play ISR routine ]===================================================
' while Timer1 is active, cycle between buffer A and B and write its data
Wp_play_isr :
If Wp_activebuffer = Wp_bufa Then ' buffer A
Incr Wp_bufpos ' incrment to next byte
Pwm2a = Wp_buf_a (wp_bufpos ) ' load sample into pwm2a
If Wp_numchannels = 2 Then Incr Wp_bufpos ' if stereo then...
Pwm2b = Wp_buf_a (wp_bufpos ) ' load same sample if mono
If Wp_bufpos = Wp_bufsize Then ' hit end of buffer A
Wp_bufpos = 0 ' reset buffer pos to 0
Wp_activebuffer = Wp_bufb ' Set active buffer to B
Wp_a_buf_status = Wp_bufempty ' set buffer status empty
Else ' buffer B
Pwm2a = Wp_buf_b (wp_bufpos ) ' load sample into pwm2a
Wp_activebuffer = Wp_bufa ' Set active buffer to B
Wp_b_buf_status = Wp_bufempty ' set buffer status empty
Return |
glena
Joined: 25 Jul 2007 Posts: 284 Location: PA near Philly
Posted: Sat May 07, 2016 5:20 pm Post subject: |
Without having closer analyzed the code and only by watching the ISR's natural symmetry, I'd say the one or the other doesn't match.
Pwm2a = Wp_buf_a(wp_bufpos) ' load sample into pwm2a
Pwm2b = Wp_buf_a(wp_bufpos) ' load same sample if mono
Else ' buffer B
Pwm2a = Wp_buf_b(wp_bufpos) ' load sample into pwm2a
Return |
atmega64
Posted: Mon May 09, 2016 8:40 am Post subject: |
Sorry if I answer late ...
Thanks Glena short enclose the original wave file ....
however the problem occurs with various wave files, and I am sure that the format is correct: Stereo 22kHz, 8bit, PCM audio files...
Thanks MWS, the anomaly in the code might be the problem ....
the correct code so that's what follows?
Wp_play_isr:
Else ' buffer B
Pwm2b = Wp_buf_b(wp_bufpos) ' load same sample if mono
Posted: Mon May 09, 2016 7:42 pm Post subject: |
atmega64 wrote: | the correct code so that's what follows? |
Is this actually a question, or the answer?
If everything fails, you still can do coding by hearing |
atmega64
Posted: Tue May 10, 2016 7:16 am Post subject: |
I tried the code and now everything is ok ... |
atmega64
Posted: Tue May 10, 2016 8:14 am Post subject: |
one last question,
because when I use a 4gb sd card formatted FAT32 returns me the error 227: Error response at Read Byte Command ???
With an SD card from 2GB okay ... |
laborratte
Posted: Tue May 10, 2016 11:23 am Post subject: |
With 4GB you have a SDHC Card, so use the "config_MMCSD_HC.inc" as card driver. For dertails look to the "AVR-DOS File System" help topic and the samples. |
atmega64
Posted: Wed May 11, 2016 7:19 am Post subject: |
"config_MMCSD_HC.inc" as card driver works also with ATXMEGA ??? |
Duesentrieb72
Posted: Wed May 11, 2016 7:45 am Post subject: |
Yes, it works with ATXmega also.
Here the part of its SPI configuration
' --------- Start of Section for HW-SPI ----------------------------------------
'FOR XMEGA DEVICES
#if _xmega = 1
'portc_pin6ctrl=&B00_011_000 ' MISO pin pull up
'Config Pinc.4 = Output ' define here Pin for CS of MMC/SD Card
'Mmc_cs Alias Portc.4
'Set Mmc_cs
' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
'Spi_ss Alias Portc.4
'SPI Configuration for XMEGA
'The MMC-XMEGA.LIB expect SPIC
'If you want to use SPID, SPIE or SPIF you NEED TO CHANGE THE MMC-XMEGA.LIB
'It is documented in MMC-XMEGA.LIB where you need to change the Library
'Config Spic = Hard , Master = Yes , Mode = 0, Clockdiv = Clk2 , Data_order = Msb
Open "SPIC" For Binary As #14
Const _mmc_spi = Spic_ctrl
#else
' define Chip-Select Pin
' Config PinG.5 = Output ' define here Pin for CS of MMC/SD Card
' Mmc_cs Alias PortG.5
' Set Mmc_cs
' ' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
' Config Pinb.0 = Output ' define here Pin of SPI SS
' Spi_ss Alias Portb.0
' Set Spi_ss ' Set SPI-SS to Output and High for Proper work of
' ' portb.3=1 'pull up on miso
' ' HW-SPI is configured to highest Speed
' Config Spi = Hard, Interrupt = Off, Data_Order = Msb, Master = Yes, Polarity = Low, Phase = 0, Clockrate = 4, Noss = 1
' SPSR = 1 ' Makes SPI run at 8Mhz instead of 4Mhz
' Spiinit
#endif
' --------- End of Section for HW-SPI ------------------------------------------ |
atmega64
Posted: Wed May 11, 2016 8:24 am Post subject: |
thank you...
then works with both, either with atmega that with atmega .... |
