Joined: 22 Jan 2006 Posts: 72 Location: Dublin, Ireland
Posted: Thu Jun 18, 2015 8:19 pm Post subject: Select Case issue
Hi All
This is really question to Mark
I have issue with Select Case in my code, I was able to reproduce the problem in the sample file for select case.
Using case statement with AND for example:
Case 1 And Test = 1 : Print "1"
Case 2 And Test = 1 : Print "2"
And then next case just plane value without AND
Case 6 : Print "6"
Case 6 seams to be ignored for some reason.
'----------------------------------------------------------------------------------------- 'name : case.bas 'copyright : (c) 1995-2013, MCS Electronics 'purpose : demonstrates SELECT CASE statement 'micro : Mega48 'suited for demo : yes 'commercial addon needed : no '-----------------------------------------------------------------------------------------
$regfile="m48def.dat"' specify the used micro $crystal=8000000' used crystal frequency $baud=19200' use baud rate $hwstack=32' default use 32 for the hardware stack $swstack=10' default use 10 for the SW stack $framesize=40' default use 40 for the frame space
Dim I AsByte'dim variable Dim S AsString*5 , Z AsString*5 Dim Test AsByte
Test =1
Input"Enter value (0-255) " , I
SelectCase I
Case1And Test =1:Print"1" Case2And Test =1:Print"2" 'Case 3 To 5 : Print "3-5" make sure this is remark for first test Case6:Print"6" CaseIs>=10:Print">= 10" CaseElse:Print"Not in Case statement" EndSelect Loop End
After compiling with Case 3 To 5 : Print "3-5" all working fine.
Test =1
SelectCase I
Case1And Test =1:Print"1" Case2And Test =1:Print"2" Case3To5:Print"3-5"'Using 3 To 5 Seams To Be Fixing The Issue Case6:Print"6" CaseIs>=10:Print">= 10" CaseElse:Print"Not in Case statement" EndSelect Loop End
Regards
Pawel
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.7.8 )
you use unsupported syntax. The idea of select case, is that a decision is made based on the value of a variable.
this is stretch a bit by using the IS where you can use syntax like you want. So use IS if you want to code like that. But a better way would be :
if test=1 then
select case I
end if _________________ Mark
Posted: Thu Jun 18, 2015 9:44 pm Post subject:
Thank you Mark
Pity be cause i have really neat piece of code for analog keypad done this way with nesting like below.
"Un-nesting" is done after button is released and ADC value is less then 10
If Key_stop =1Then'Key_stop Alias Up_stop_down.2 If Up_stop_down_flag.2 =0Then
Up_stop_down_flag.2 =1 Call Beep_sound
Call Rotor_stop
$nocompile
Sub Convert_adc_button:
Analog0 =Getadc(0)
Analog1 =Getadc(1)
Analog2 =Getadc(2) ' lsp, mode, menue, preset , park Dbg'for stack debug If Analog0 <10And Key_button <>0Then
Key_button =0
Key_button_flag =0 Debug"key_button_relesed" End If If Analog1 <10And Up_stop_down <>0Then
Up_stop_down =0
Up_stop_down_flag =0 Debug"UP_stop_down_relesed" End If If Analog2 <10And Func_button <>0Then
Func_button =0
Func_button_flag =0 Debug"function_button_relesed" End If
Case695To710And Up_stop_down.0 =0:'key up
Up_stop_down.0 =1 Debug"Key_UP: "
Case590To620And Up_stop_down.1 =0:'Key down
Up_stop_down.1 =1 Debug"Key_Down: " Case315To335And Up_stop_down.2 =0:' Key stop
Up_stop_down.2 =1 Debug"Key_Stop" Case740To750And Up_stop_down.3 =0:'Key up and stop
Up_stop_down.3 =1 Debug"key_up and down" Case670To685And Up_stop_down.4 =0:' key stop and down
Up_stop_down.4 =1 Debug"key_stop and down" Case790To810And Up_stop_down.5 =0:' key up and down
Up_stop_down.5 =1 Debug"key_up and down"
