Posted: Sat May 09, 2015 10:49 pm Post subject: Single pulse from Timer1 in CTC or PWM mode
Is it possible to generate a single 10ms pulse from Timer1 (eg OC1B output) with no interrupts in ATMEGA128?
I would like to get purly hardware generated one single 10ms pulse (not a pulse wave) after setting a command/commands for triggering it.
So I am looking for an alternative to this:
Set PORTB.6
Waitms 10
Reset PORTB.6
But without freezeng ATMEGA for 10 ms and without interrupts. CTC or PWM mode could help? Any ideas?
Posted: Sun May 10, 2015 6:52 am Post subject:
Not really. There is no hardware within the AVR which will generate a single pulse.
What is your objection to using interrupts ?
Interrupts are really the only way to do this, and allow other code to run until the IRQ is trigggered.
Setup a timer with the correct count and prescaler, enable the relevant IRQ, set the line you want to output, start the timer, then within the IRQ reset the line and stop the timer.
At most this should consume a few hundred clocks for the IRQ, probably only 20 or so if you wrote it in ASM.
You should also consider that your main program runs in a loop, so you will ( presumably ) generate that pulse every time around the loop. So in fact you can set up a timer to generate the pulse regularly, and then fit the rest of your program around that interval.
Does this help ? _________________ Adrian Jansen
