WRITE VARIABLE TO FLASH MEMORY OF MICROCONTROLLER
hamedhamedi
PostPosted: Tue Jan 06, 2015 8:20 pm    Post subject: WRITE VARIABLE TO FLASH MEMORY OF MICROCONTROLLER Reply with quote
I want to save a variable to a predefined address of flash memory of microcontroller.
who can i do it?
thanks
PostPosted: Tue Jan 06, 2015 11:34 pm    Post subject: Reply with quote
The short answer, is no, you cannot write to flash memory from within a running progam in an AVR processor.
But why not use the eeprom ?
That is provided to store 'variables' which will be used after a power cycle. Note that there are still limitations. You cannot write to eeprom an unlimited number of times, so you must use these 'variables' to store only new values needed after a change. System setup 'variables' are often used in this way.
Please explain further what you are trying to do.
Adrian Jansen
hamedhamedi
PostPosted: Fri Jan 09, 2015 10:19 am    Post subject: Reply with quote
thank you AdrianJ for all respone in froum
eeprom writing time is very long for my program.writing 2 byte take 17ms time to do.
i write another question in 2 weeks ago about it in froum. but i didnt get an exact answer!
according to datasheet writing a byte to eeprom take 3.5ms,so writing 2 byte take 7ms.
but i check writing time in this way:
1-i set a pin in program such as pinb.0
2- writing 2 byte(an integer variable) to eeprom
3-reset the pin in program
i check the timing in osciloscope, it take 17ms!!!!
why????
during writing to eeprom variable,cpu halted (according to help of bascom) my critical interrupt lost and it is very bad.
i want to use external eeprom like at24c08 to save time.
if i write to eeprom byte by byte the time did not save,because i should use a waitms 5 for complete writing sequence.
during writing to eeprom,at24c08 do not respond to input command.
i can use page write to write a integer immediately without waitms.so i can write up to 8 byte to a page of eeprom,and then wait to complete writing to eeprom by internal circuit of at24c08.the time of writing is not important for me.
now the question is:
who to write a page into at24c08?
thanks
hamedhamedi
PostPosted: Fri Jan 09, 2015 10:22 am    Post subject: Reply with quote
my code to write a page in at24c08 is here:
$regfile = "m32def.dat"
$crystal = 4000000
Open "comd.6:9600,8,n,1" For Output As #1
Print #1 , "start"
Config Sda = Portd.4
Config Scl = Portd.5
Config I2cdelay = 1
Const Eeread = 161
Const Eewrite = 160
Config Portd.7 = Output
Tester Alias Portd.7
Dim Address As Word , Highaddress As Byte , Lowaddress As Byte , Highintvar As Byte , Lowintvar As Byte
Dim Intvar As Integer
Dim J As Integer
Dim I As Integer
Config Portd.2 = Output
Intr Alias Portd.2
J = -30500
For I = 0 To 50
  J = J + I
  'Print #1 , J
  Address = I
  Highaddress = High(address)
  Lowaddress = Low(address)
  Highintvar = High(j)
  Lowintvar = Low(j)
  Print #1 , J
  'Print #1 , I
  'Print #1 , Highintvar
  'Print #1 , Lowintvar
  'Print #1 , "------"
  Gosub Writeeepromserial
  Toggle Tester
Next I
Print #1 , "read"
For I = 0 To 50
  Address = I
  Gosub Readeepromserial
  Intvar = Makeint(lowintvar , Highintvar)
  Print #1 , Intvar
Next I
Writeeepromserial:
I2cstart
I2cwbyte Eewrite
I2cwbyte Highaddress
I2cwbyte Lowaddress
I2crbyte Highintvar
I2crbyte Lowintvar
I2cstop
Waitms 5
Readeepromserial:
I2cstart
I2cwbyte Eewrite
I2cwbyte Lowaddress
I2cstart
I2cwbyte Eeread
I2crbyte Highintvar , Nack
I2cstop
Waitms 5
I2cstart
I2cwbyte Eewrite
I2cwbyte Lowaddress
I2cstart
I2cwbyte Eeread
I2crbyte Lowintvar , Nack
I2cstop
Waitms 5
PostPosted: Fri Jan 09, 2015 12:31 pm    Post subject: Reply with quote
-Your using the software i2c, better use the hardware i2s (twi) it's faster. (you must change your hardware then)
See http://avrhelp.mcselec.com/config_twi.htm
-Your waiting after every write 5ms, that's also not really needed. Most of the eeproms writing faster then described in the datasheet.
To be sure that the data is written and also to be sure that your not waiting to long for nothing you can do ACK polling, look at this:
Writeeepromserial:
I2cstart
I2cwbyte Eewrite
I2cwbyte Lowaddress
I2crbyte Highintvar
I2crbyte Lowintvar
I2cstop
 Do                                                         'To replace the waitms5 by polling for ACK
   I2cstart                                                 'generate start
   I2cwbyte Eewrite                                   'slave adsress
   I2cstop
 Loop Until Err = 0
-Also writing a complete page to the eeprom will speed up writing.
-In your test loop your printing some things, this also consumes some time.
-Splitting ADDRESS up in high and low bytes can be done faster with the overlay function, same with J (see this nice tutorial from MAK3 about overlay http://mcselec.com/index.php?option=com_content&task=view&id=307&Itemid=57 )
Dim Address As Word
Dim Lowaddress As Byte At Address Overlay
Dim Highaddress As Byte At Address + 1 Overlay
Dim J As Integer
Dim Lowintvar As Byte At J Overlay
Dim Highintvar As Byte At J + 1 Overlay
'You can reduce the first part of the main loop then to this
J = -30500
For I = 0 To 50
  J = J + I
  'Print #1 , J
  Address = I
  Print #1 , J
  'Print #1 , I
  Toggle Tester
Next I
-You toggle TESTER pin, so it takes 2 loops to go from low to high to low, don't forget that.
PostPosted: Fri Jan 09, 2015 1:09 pm    Post subject: Reply with quote
I have crazy and NOT TESTED idea Very Happy
$sim
$crystal = 4000000
Dim A As Integer
Dim B As Eram Integer
Dim C(2) As Eram Byte At B Overlay
Dim Idx As Byte , Help_byte As Byte
Const Must_be_saved = 1                                     'for this test
If A = Must_be_saved Then Idx = 2
'sequent write 2 x 1 Byte (one time in loop takes 3,5ms)
If Idx > 0 Then
 Select Case Idx
  Case 1
   Help_byte = High(a)
   C(idx) = Help_byte
   Decr Idx
  Case 2
   Help_byte = Low(a)
   C(idx) = Help_byte
   Decr Idx
Bascom Ambassador
PostPosted: Fri Jan 09, 2015 8:35 pm    Post subject: internal EEprom? Reply with quote
Perhaps I missed something. Why not write to the internal EEprom?
Have fun
Ben Zijlstra
hamedhamedi
PostPosted: Sat Jan 10, 2015 1:20 pm    Post subject: Reply with quote
I write in first post that internal eeprom writing halt the cpu until writing sequence complete.
the main question was who to write a page in at24c external eeprom.
the code i posted,do not return same variable as writed to eeprom!
thanks
hgrueneis
PostPosted: Sat Jan 10, 2015 4:41 pm    Post subject: wait while writing to eeprom Reply with quote
Look up the HELP under ASM Libraries and Add-Ons.
Instead of eeproms you could use Ramtron memory libraries.
Depending on type I2C or SPI.
No wait while writing because they write in real time and usually (look up the datasheet) you will not ever reach the write limit.
Hubert
hamedhamedi
PostPosted: Sat Jan 10, 2015 7:34 pm    Post subject: Reply with quote
thank you
after reading your post i search in help of bascom and datasheets,so many question added to my main question Rolling Eyes Shocked Sad
refering to bascom help :
Ramtron memory chips are as quick as RAM and can be overwritten almost unlimited times.
1- i can not understand main difference of Ramtron memory chips and eeprom!
can Ramtron memory chips save variable like eeprom without power?
By using : $lib "fm24c16.lib"
The EEPROM read and write routines from the library will be used instead of the internal EEPROM.
Thus you can still use : Dim BE as ERAM Byte
And you can use READEEPROM and WRITEEEPROM, but instead of using the internal EEPROM, the external I2C EEPROM is used.
The lib is for the FM24C16. It uses I2C/TWI.
at24c08 also use twi, so can i use writeeeprom and readeeprom instruction for writing and reading from at24c08 or no?
thanks
Tiny
PostPosted: Sun Jan 11, 2015 9:02 am    Post subject: Reply with quote
yes they hold the data without power, for example CY14B101I from cypress
Kind regards,
Tiny
hamedhamedi
PostPosted: Sun Jan 11, 2015 9:32 am    Post subject: Reply with quote
thank you
Atmel doesnt have part like this?
