pyclan
Posted: Tue Jul 29, 2014 10:43 am Post subject: XRAM + HARD SPI not work!? |
Hi everyone!
SRAM connected as in the description HELP BASCOM - Adding XRAM to XMEGA using EBI
CY7C1049DV33-10 - 512k x 8
Code: |
$regfile = "xm128A1def.dat"
$crystal = 2000000
$hwstack = 300 ' default use 32 for the hardware stack
$swstack = 300 ' default use 10 for the SW stack
$framesize = 200 ' default use 40 for the frame space
$xramstart = &H4000
$xramsize = &H80000
' All EBI-Ports must be set to OUTPUT
' All Ports, ACTIVE-LOW , must be set to 1 !!!
' All Ports, ACTIVE-HIGH, must be set to 0 !!!
Porth_dirset = &B1111_1111 : Porth = &B1111_0011 'WR, RD, ALE1, ALE2, CS0-3 = output : ALE1 & 2 auf 0 !!!
Portj_dirset = &B1111_1111 : Portj = &B1111_1111
Portk_dirset = &B1111_1111 : Portk = &B1111_1111
Config Xram = 3port , Ale = Ale12 , Sdbus = 8 , Modesel0 = Sram , Adrsize0 = 256b , Waitstate0 = 0 , Baseadr0 = &H10000 , Modesel1 = Sram , Adrsize1 = 512k , Waitstate1 = 0 , Baseadr1 = &H20000
'We enable Low Level Interrupts in static mode
'SPI_PIN____________________________
Config Pinc.7 = Output 'SCK
Sck Alias Portb.1
Config Pinc.5 = Output 'MOSI
Mosi Alias Portc.5
Config Pinc.6 = Input 'MISO
Miso Alias Pinc.6
Config Pinc.4 = Output
Spi_ss Alias Portc.4
'Set Spi_ss ' Set SPI-SS to
Portc_pin6ctrl = &B00_011_000 ' MISO pin pull up
Config Spic = Hard , Master = Yes , Mode = 0 , Clockdiv = Clk64 , Data_order = Msb
Open "SPIC" For Binary As #12
'TOUCH_PIN__________________________
Config Pinc.1 = Output
Cs_touch Alias Portc.1
Set Cs_touch
Config Pinf.3 = Input
Int_touch Alias Pinf.3 '
Set Int_touch
'BEEP_PIN___________________________
Config Pinr.0 = Output
Beep Alias Portr.0
Set Beep
Reset Cs_touch
Print #12 , 144
Set Cs_touch
Waitms 100
Reset Beep
Wait 1
End 'end program
This code stops at the line Print # 12, 144 EBI - SRAM, DISPLAY work, SPI not work and also in the simulator.
If you comment out $xramstart = &H4000, SPI works, EBI - SRAM, DISPLAY not work.
What could be the problem?
Thanks,
Ruslan.
Posted: Tue Jul 29, 2014 12:18 pm Post subject: |
it might be a problem of huge ram which uses rampX.
check if your xmega.lib contains this code :
Code: |
[_XSPI]
_SPI2BASE:
;translate the SPI numbers passed in softstack to the base address
; SPI base is usual 8C0,9C0,AC0,BC0 but for the E series this is 8E0
; Ld r23,y+ ; pop SPI number 0-3 back from the stack
_SPI2BASE_NI: ; when called direct, R23 must be loaded with the SPI number 0-3
#IF _HUGE
Clr R26 ; page address
Out RAMPX,R26
#ENDIF
* ldi r26,lbyte(_SPI_BASE); base address LSB $C0
Ldi r27,8 ; base MSB
add r27,r23 ; add SPI, registers now point to CTRL register
Ret |
especial the part:
#IF _HUGE
Out RAMPX,R26
#ENDIF _________________ Mark |
pyclan
Posted: Tue Jul 29, 2014 12:55 pm Post subject: |
Hi Mark!
Yes library provides.
comment = AVR XMEGA library
libversion = 2.0.7.7
date = 21 July 2011
Was as follows:
Code: | [_XSPI]
_SPI2BASE:
#IF _HUGE
Out RAMPX,R26
#ENDIF
Ret |
Replaced by your code. Everything works.
Thanks,
Ruslan. |
