'========================= SYSTEM INT ======================
$regfile = "xm32a4udef.dat"
'$regfile = "xm32d4def.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 200
$framesize = 200
Config Osc = Enabled , 32mhzosc = Enabled ' enable 2 MHz and 32 MHz interal oscillators
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 ' use 32 MHz
Config Submode = New
$include "a4uadc.bas"
'$include "LED_DISPLAY.BAS"
'$sim
'======================== CONSTANT'S ============================
Const Tsam = 128
Const Primry_volt = 7.43 * 30.63
Const Period = 200
'Const Cal_pwm = Primry_volt * Period
Const Cal_pwm = 45514
'Const Bat_start = baettery volt *pervolt constant
Const Bat_start = 337
Const Bat_trip = 306
'======================== ALIAS'S ==============================
Power_sw Alias Pind.4
'========================I/O CON FIG ==========================
'Config Portb = Output
Config Portc = Output
Config Portd.1 = Output
Config Portd.0 = Output
Config Portc.5 = Output
Config Portc.7 = Output
Config Portc.6 = Output
'Config Xpin = Portb.3 , Invertio = Enabled , Slewrate = Enabled , Outpull = Wiredand , Sense = Both
Config Xpin = Portd.1 , Invertio = Disabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portd.0 , Invertio = Disabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portc.5 , Invertio = Disabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portc.7 , Invertio = Disabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portc.6 , Invertio = Disabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
'lcd pins
Config Xpin = Portd.7 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Porte.0 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Porte.1 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Porte.2 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portd.6 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portd.5 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
'HB DRIVE PINS
Config Xpin = Portc.0 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portc.1 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portc.2 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
Config Xpin = Portc.3 , Invertio = Enabled , Slewrate = Enabled , Outpull = Totem , Sense = Both
'HERE INPUT SENS SETTING
Config Xpin = Portd.2 , Outpull = Pullup , Sense = Falling 'enable Pull up and
Config Xpin = Portd.4 , Outpull = Pullup , Sense = Falling 'enable Pull up and
Config Xpin = Portb.3 , Outpull = Pullup , Sense = Falling 'enable Pull up and
Config Portr = Output
Config Porte = Output
'========================== PHRIPAREL INT ===========================
Adc_cfg
Adc_diff
Config Tcc0 = Pwm_topbot , Prescale = 4 , Comparea = Enabled , Compareb = Enabled , Comparec = Enabled , Compared = Enabled
Tcc0_per = Period ' period register
'Tcc0_ccabuf = 50 'compare A match value
'Tcc0_ccbbuf = 50 'compare B match value
'Tcc0_cccbuf = 50 'compare C match value
'Tcc0_ccdbuf = 50
'GOSUB CONFIG_ADC
Config Tcc1 = Normal , Prescale = 4
Tcc1_per = 1600
'for testing
'Tcc1_per = 3200
Tcc1_ccabuf = 1
Config Lcdpin = Pin , Db4 = Portd.7 , Db5 = Porte.0 , Db6 = Porte.1 , Db7 = Porte.2 , E = Portd.6 , Rs = Portd.5
Config Lcd = 16 * 4
Initlcd
Lcd " hello"
Wait 2
'========================INT CONFIG ============================
On Tcc1_cca Trigadc
Enable Tcc1_cca , Hi
'Adca_ch0_intctrl = &B00000011 ' TEMP CHANGE
Pmic_ctrl = &B00000111
'======================== FLAGS VERIABLES =========================
Dim Upson As Bit , Doom As Bit , Backupon As Bit
Dim Cycle_start As Bit , Output_doom As Bit
Dim Ovd_warn As Bit , Ovd_shutdown As Bit , Batlow_shut As Bit , Batlow_warn As Bit , Startup As Bit
Dim Over_heat As Bit
'======================== VERIABLE==============================
Dim Mux As Byte
Dim W As Integer , Wold As Long , Cnt As Byte
'Adca_ch0_muxctrl = &B00001000
Dim Sine_counter As Byte , Sine_table As Word , Pwm_update As Word
Dim Pwm_out As Byte At Pwm_update + 1 Overlay
Dim Outload As Integer , Outputrms As Integer , Outcurrent As Integer
Dim Output_prv As Integer , Output_pk As Integer
Dim Batvolt As Integer , Batact As Word , Batlcd As Single , Outputac As Integer
Dim Pwm_max As Word
Dim Batdispl As Word , Battery_sigma As Word , Battery_count As Byte
Dim Bvstr As String * 8
Dim Output_load As Long , Load_display As Long , Load_compare As Byte
Dim Output_volt As Long , Output_volt_display As Long
'======================== MAIN LOOP =============================
'Enable Interrupts
SEI
'HERE CALCULATE TO DISPLAY BATTER VOLT
Batlcd = Batact / 30.63
Bvstr = Fusing(batlcd , "#.##")
If Power_sw = 0 Then
Backupon = 1 'TURN ON INVERTOR
'TURN OFF INVERTOR
Backupon = 0
'LCD UPDATE DELAY
Waitms 500
End 'end program
'=======================ISR FUNCTION'S ============================
'///////////////////////////// timer c1 intreupt for analog chanel readings //////////////////////////
Trigadc:
Bv_ch_slect ' mux slection function for battery volt reading
Adc_run 'start adc conversion
Get_analog 'read chanel register and store values in veriable ad_result
Batvolt = Ad_result 'move result to batvolt veriable for battery level detect
Oc_ch_slect ' mux slection function for ct reading
Outcurrent = Ad_result
Ov_ch_slect ' mux slection function for output volt reading
Get_analog
Outputac = Ad_result
Shift Batvolt , Right , 2
Shift Outcurrent , Right , 2 , Signed
Shift Outputac , Right , 4 , Signed
'here calculate avrge battery volts because adc result is not good so avrging will give the good result
Battery_sigma = Batvolt + Battery_sigma
If Battery_count = 16 Then
Battery_count = 1
Batdispl = Battery_sigma
Shift Batdispl , Right , 5 'get avrge battery volt reading
Battery_sigma = 0
Incr Battery_count
Batact = Batdispl 'update battery reading
'HERE IF OUT PUT VOLT VALUE IS IN NEGITIVE THEN CONVERT IT IN POSITIVE
If Outputac < 0 Then : Decr Outputac : Toggle Outputac : End If
'HERE IF OUT PUT CURRENT VALUE IS IN NEGITIVE THEN CONVERT IT IN POSITIVE
If Outcurrent < 0 Then : Decr Outcurrent : Toggle Outcurrent : End If
'---------------------- HERE SINE WAVE INVERTOR CONTROL LOOP
'Backupon = 1 'TURN ON INVERTOR
If Backupon = 1 Then
If Sine_counter = 49 Then : Sine_counter = 0 : Doom = Doom Xor 1 : Else : Incr Sine_counter : End If
Pwm_max = Cal_pwm / Batact
Sine_table = Lookup(sine_counter , Sine_table255)
Pwm_update = Sine_table * Pwm_max
If Doom = 1 Then
Tcc0_ccbbuf = 0 'RIGHT HIGH HB OUT
Tcc0_cccbuf = 0 'LEFT LOW HB OUT
Tcc0_ccdbuf = Pwm_out + 1 'LEFT HIGH HB OUT
Tcc0_ccabuf = Pwm_out 'RIGHT LOW HB OUT
Tcc0_ccabuf = 0 'RIGHT LOW HB OUT
Tcc0_ccdbuf = 0 'LEFT HIGH HB OUT
Tcc0_ccbbuf = Pwm_out + 1 'RIGHT HIGH HB OUT
Tcc0_cccbuf = Pwm_out 'LEFT LOW HB OUT
'HERE AVRGE CURRENT AND AVRGE OUTPUT VOLT DETECTION
'SO THERE WOULD BE NO NEED TO ADD ANY AVRGE CAP ADDITION
'WHEN INVERTOR ON THEN DISPLAY INVERTOR VOLT AND LOAD
If Sine_counter = 0 And Doom = 1 Then
Output_load = Output_load / 100
Load_display = Output_load
Output_load = 0
Output_volt = Output_volt / 100
Output_volt_display = Output_volt
Output_volt = 0
Output_volt = Output_volt + Outputac
Output_load = Output_load + Outcurrent
Sine_table255:
Data 0 , 16 , 33 , 49 , 65 , 80 , 96 , 111 , 125 , 139 , 153 , 165 , 177 , 189 , 199 , 209 , 218 , 226 , 233 , 239 , 244 , 249 , 252 , 254 , 255 , 255 , 254 , 252 , 249 , 244 , 239 , 233 , 226 , 218 , 209 , 199 , 189 , 177 , 165 , 153 , 139 , 125 , 111 , 96 , 80 , 65 , 49 , 33 , 16 , 0
