Posted: Thu Jun 12, 2014 8:24 am Post subject: Using Inkey (# var) and Input(# var)
Hello
I try to prepare function, where can I choise number of COM port like variable.
Example:
Function r_data(byval data_f asstring, byval Cl_port asbyte)asstring Local data_f asstring*100 Local data_read asstring*100 Local Cl_port asbyte Local Ikey asbyte
Ikey=Inkey(#Cl_port) if Ikey="+"then Input #Cl_port data_read Noecho endif
r_data=data_read
EndFunction
In help is described, that it is possible, but doesn't work. Why?
If local variable Cl_port I change with fix number (eg. 3) it works.
i do not know to which topic in the help you refer to? it is only possible for Xmega, and only when using variable that starts with name buart. _________________ Mark
