ATXMEGA USART problem
kulisek
PostPosted: Wed Jun 11, 2014 1:57 pm    Post subject: ATXMEGA USART problem Reply with quote
What is wrong on this code: ???
$regfile = "xm32E5def.dat"
$crystal = 32000000
Config Com2 = 1000000 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8    ' <- here is error with Com2 on PC7
Open "com2:" For Binary As #1
It gives me error on COM2 USART on port PC6/PC7. COM1 and COM4 is OK
PostPosted: Wed Jun 11, 2014 3:42 pm    Post subject: Re: ATXMEGA USART problem Reply with quote
kulisek wrote:
COM1 and COM4 is OK
Surely not, COM1 & COM3 works, COM2 & COM4 won't.
The XMega32E5 provides one UART for PortC and one for PortD, other XMegas provide two UARTs for one port, so enumeration goes there:
PortC_UART0, ...C_UART1: COM1, COM2
PortD_UART0, ...D_UART1: COM3, COM4
For the XM32E5 PortC_UART0 and PortD_UART0 is available, which makes it COM1 and COM3.
kulisek
PostPosted: Wed Jun 11, 2014 4:54 pm    Post subject: Reply with quote
But here http://avrhelp.mcselec.com/index.html?configcomx.htm is written
COM2 - UART_C1 PORTC.7 PORTC.6
and I need PC6/7 for it
PostPosted: Wed Jun 11, 2014 8:58 pm    Post subject: Reply with quote
it is as MWS says.
if you look in the PDF you will see that RXD and TXD are both on pc2/3 and pc6/7. Some xmega have a remap register where you can remap pins.
for example to remap the UART pins from the default, use PORTC_REMAP.4=1
while this swaps the pins, you still need to access the USART with the correct name.
PostPosted: Wed Jun 11, 2014 9:12 pm    Post subject: Reply with quote
Surprise, surprise, the XMega32E5 contains no UART_C1, didn't I write that already?
But - it contains a REMAP-register, where you can decide whether pins 0..3, or 4..7 are used for COM1, it looks that is what you want.
This:
Set PORTC_REMAP.4
will use PC6 for RXD0 and PC7 for TXD0.
You could have found this out yourself by simply reading the fffriendly manual.
PostPosted: Wed Jun 11, 2014 9:18 pm    Post subject: Reply with quote
MWS seems we wrote at the same time Very Happy
PostPosted: Wed Jun 11, 2014 9:19 pm    Post subject: Reply with quote
Well, you've made it first to the finishing line Very Happy
PostPosted: Wed Jun 11, 2014 9:26 pm    Post subject: Reply with quote
maybe because the server is closer at my home Wink
