target_locked
Posted: Thu Apr 24, 2014 2:09 pm Post subject: ATMEGA16 with LCD16x2 (4 bit) |
Hi there,
I am new to Bascom and I got an issue with LCD 16x2 (4 bit). My CPU is ATMega16.
I have another sample program written in C and it works well all times with this LCD. I call this LCD_Demo.hex
Now with my Bascom program (I call it LCD_Shift). It only run correctly after I run above LCD_Demo.hex. If I turn off the power and ON again, my LCD_Shift will not run correctly, strange chars appear.
I just leave power on, load LCD_Demo.hex, it will run well, then load my LCD_Shift.hex, it work well also.
I guess the issue related to the temporary memory that when I switch off the power it will loose the data.
I would like to know what is wrong in my Bascom LCD_Shift program? Do I miss any step to make the LCD run stably?
Thanks,
Here is my Bascom code:
' LCD_Shift: Shift 2 rows left then right
$regfile = "m16def.dat"
$crystal = 12000000
Config Porta = Output
Config Lcd = 16 * 2
Config Lcdbus = 4
Config Lcdmode = Port
Config Lcdpin = Pin , Rs = Porta.0 , E = Porta.2 , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7
Dim Pos As Byte
Upperline
Lcd "012345678901john"
Lowerline
Lcd "0123456789012ike"
For Pos = 0 To 16 Step 1
Waitms 300
Shiftlcd Left
Next Pos
For Pos = 0 To 32 Step 1
Waitms 200
Shiftlcd Right
Next Pos
And here is C Code Vision that work well all times:
//LCD DEMO
// the LCD is connected to PORTA outputs
// see the file lcd.h in the ..\inc directory
#asm
.equ __lcd_port=0x1b ;PORTA
#endasm
// include the LCD driver routines
#include <lcd.h>
#include <mega16.h>
void main(void)
// initialize the LCD for
// 2 lines & 16 columns
lcd_init(16);
// go on the second LCD line
lcd_gotoxy(1,0);
// display the message
lcd_putsf("ROW 1");
lcd_gotoxy(0,1);
lcd_putsf("ROW 2");
// stop here
while (1);
Here is the LCD circuit:
(BASCOM-AVR version : 2.0.7.3 , Latest : 2.0.7.7 ) |
Posted: Thu Apr 24, 2014 2:16 pm Post subject: |
you should remark these lines :
'Config Lcdbus = 4
'Config Lcdmode = Port
then you should make the WR pin low first. Or connect it to ground.
config ......
porta.1=0 'WR pin low
INITLCD 'now init lcd when wr pin is low
just read the help about lcd _________________ Mark |
target_locked
Posted: Fri Apr 25, 2014 11:36 am Post subject: |
Thanks Albertsm,
The solution work perfectly.
The key point is pulling the WR pin Low and command InitLCD.
Code: | $regfile = "m16def.dat"
$crystal = 12000000
Config Porta.1 = Output
Config Lcd = 16 * 2
Config Lcdbus = 4
Porta.1 = 0 'WR pin low
Initlcd 'now init lcd when wr pin is low
Dim Pos As Byte
Upperline
Lowerline
Waitms 300
Shiftlcd Left
Next Pos
Waitms 200
Shiftlcd Right
Next Pos
End |
Posted: Sat Apr 26, 2014 9:34 pm Post subject: |
yes and new version of bascom also support WR pin with BUSY check. for those having enough pins. _________________ Mark |
