remote area crop watering system
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM Project Blog
snipsnip
PostPosted: Tue Feb 25, 2014 4:04 am    Post subject: remote area crop watering system Reply with quote
Hi all,
working on a small remote area (solar) watering system, monitors soil moisture with a simple two prong probe
encapsulated in plaster .
lots of configurable options, fertiliser dosing, e/c measurement, pump times etc.
im using an arduino uno board and lcd shield.
looking at either using an off the shelf EC shield to look after the AC probe measurement or may look at doing the AC on board (if I can figure out how).
cheers
[/code]
PostPosted: Sun Mar 09, 2014 6:32 pm    Post subject: Reply with quote
Hello,
Would you please explain how you connect your arduino to bascom compiler, cables, etc..
because, I don't understand why I cannot load a program in my Arduino UNO
I Have a USB-ISP programmer, I try with different way and I haven't any success.
Thanks to your answers
JP Sad
snipsnip
PostPosted: Mon Mar 10, 2014 7:01 am    Post subject: Reply with quote
Hi JP,
you don't need the USB-ISP just a standard micro USB cable, the arduino bootloader does all the work.
But maybe you've wiped the bootloader already by using it?, no problems - just use the ISP then.
(the brains on the main forum would be more helpful, I'm just a simple electrician stumbling my way through this stuff)
I took a screen capture of the programmer settings I'm using, see attached
also I'd install the arduino ide then you can check the board is working, comport settings ect.
cheers
Simon
[/img]
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM Project Blog All times are GMT + 1 Hour
