timbak
Posted: Sat Feb 08, 2014 9:16 am Post subject: Atmega256a3bu problem with new (2.0.7.7) version |
Code doesn't work in chip when compiled in the new (2.0.7.7) version, and doesn't give any errors. In 2.0.7.6 it works well.
I tried to compile with old .dat file (from 2.0.7.6) but get an error 222:
Code: | Illegal character [expected (, got ')' [LBYTE(_UART_BASE)]]
Illegal character [expected (, got ')' [LBYTE(_UART_BASE)+$10]] |
Code: | $regfile = "xm256a3budef.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
Const Xtal_clock = 16000000
Const Pll_multi = 2
'' internal multiplier clock is not distrybuted
Const Prescale_a = 1
Const Prescale_b = 1
Const Prescale_c = 1
Const Cpu_clock = Xtal_clock * Pll_multi / Prescale_a / Prescale_b / Prescale_c
''calculated just for "print"
Config Osc = Disabled , Extosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_256clk , 32khzosc = Enabled
''Set the Multiplication factor and select the clock Reference for the PLL
Cpu_ccp = &HD8
Osc_pllctrl = &B11_0_00000 + Pll_multi ' EXTERNAL clock Source and Multiplication factor OR mask
Set Osc_ctrl.4 ' PLL enable
''must be writen manually
Config Priority = Static , Vector = Application , Lo = Enabled , Hi = Enabled
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM1:" For Binary As #1
On Usartc0_rxc Bt_in
Enable Usartc0_rxc , Hi
Dim Z As Byte
Wait 1
Print #1 , "Test"
Bt_in:
Z = Inkey(#1)
If Z = 123 Then
Goto &H20000
Else
Gosub Uart_sub
Uart_sub:
Print Chr(z);
Return |
Posted: Sat Feb 08, 2014 12:32 pm Post subject: |
Always check register.mcselec.com ! The enhancements/bugs contain info about changes since the release :
xmega, config OSC : when using external osc, enable the internal osc as well.
So for you : Config Osc = Enabled , Extosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_256clk , 32khzosc = Enabled
This is a bug caused by an improvement. the improvement is to wait for the status bits till the oscillator is ready. But when not using the internal osc, this bit can become 1 despite it is not enabled, leading to a wrong compare.
So as a workaround, enable the internal osc. _________________ Mark |
