Author
Message
astroschmidt Joined: 04 Sep 2010 Posts: 33
Posted: Thu Jan 30, 2014 12:28 pm Post subject: Question to the use of SELECT-CASE with multiple statements
Hi folks,
I have a question concerning the correct use of the SELECT-CASE function.
Because according to the help-file of BASCOM one can use several statements after the CASE, I first tried it this way:
$regfile = "m32def.dat" 'ATMEGA32: 32k Flash, 2k RAM, 1k EEPROM
$framesize = 200
$swstack = 200
$hwstack = 200
$crystal = 16000000 '16 MHz Quarz
Dim Device_mode As Byte
Dim Ist_wert As Single , U_meas As Single , R_meas As Single , P_meas As Single , Last_value_high As Single
Select Case Device_mode
Case 4 : Ist_wert = U_meas : Last_value_high = U_meas
Case 5 : Ist_wert = P_meas : Last_value_high = P_meas
Case 6 : Ist_wert = R_meas : Last_value_high = R_meas
But this gives a compile error.
When I try it the CASE-statements in the following way, I get no compile errors:
Case 4
Case 5
Case 6
So am I right to assume, that multiple statements after a CASE only work, when I write them in a new line?
(Like the "IF-THEN-ELSE-ENDIF" short and long version)
Kind regards
Roger
(BASCOM-AVR version : 2.0.7.6 )
albertsm Joined: 09 Apr 2004 Posts: 5913 Location: Holland
Posted: Thu Jan 30, 2014 1:48 pm Post subject:
yes you are right. officially you should be able to use the first syntax. i will have a look at it. _________________ Mark
