toto
Posted: Sat Jan 25, 2014 1:39 pm Post subject: Exists a way to implement a Timeout? |
I use the hardware Usart to send and receive data trough RS485
dim as Ori byte , Rx_coman as byte , Quant_bytes as byte , Rx_end as byte, Temp_nr as word , pl_nr as word
dim yptas byte , Word_dbg as word , R_done as byte , Rx_dad(16) as byte , Master as byte
_a:
If Ischarwaiting(#1) <> 0 Then
Inputbin #1 , Serialchar 'get the byte
If Serialchar <> Master Then Goto localation2 'is the first byte not 254 continue to other location
Inputbin #1 , Ori , Rx_coman , Quant_bytes , Rx_end , Temp_nr , ypt , Word_dbg , R_done , Rx_dad(1) , Quant_bytes
If Temp_nr <> pl_nr Or R_done <> 125 Then 'test if part of the received data are correct or not
R_done = 0 : Rx_dados(1) = 0
Clear Serialin
Reset Watchdog
End if
location2:
Note that the INPUTBIN statement doesn't wait for a <RETURN> but just for the number of bytes. Help from Bascom!!!!
What happend here if all the expected data not received correct "noise", wait the Inputbin forever?
If yes, exists a way to implement a Timeout?
toto
(BASCOM-AVR version : 2.0.7.2 , Latest : 2.0.7.6 ) |
Posted: Sat Jan 25, 2014 8:03 pm Post subject: |
Why not use inkey to grab individual Bytes, that you copy into an Array and when youget the end of message character process the message.
I quite often put the Serial Input processing in a uart receive ISR that handles to low Level processingand passes "complete" Messages to the main app.
something like
Rfid_char = Inkey(#1) 'Read serial char
If Rfid_char = 2 Then 'Chr 2 - Start of MSG
Rfid_ptr = 0 'Reset pointer
Incr Rfid_ptr 'Move to next byte
Rfid_array(rfid_ptr) = Rfid_char 'Save char to array
If Rfid_ptr = 13 Then 'and correct length
Rfid_have_buffer = 1 'tell user space
Rfid_ptr = 0 'Reset buffer
toto
Posted: Sat Jan 25, 2014 10:07 pm Post subject: |
Hi i.dobson,
I never have used Inkey and dont know if it works for my case then in the Inputbin stream i receive the bytes quantity information to fill the byte array, thats why i use inputbin. But if it freeze if not receive the expected quantities of data, i can't use it in my program.
I look for a solution to implement a Timeout in my code
I apreciate if anyone can help me with the Timeout
toto |
for_ro
Posted: Sat Jan 25, 2014 10:24 pm Post subject: |
$Timeout ? |
Posted: Sat Jan 25, 2014 10:35 pm Post subject: |
inkey is like inputbin, just that it gets one character. So you need to manually copy the result into an Array.
