erg322
Posted: Tue Dec 17, 2013 7:51 am Post subject: 4x4 keypad program and a simple game for it |
Couldn't resist........
' _ _____
' / | / / | ____ ___ ___
' / |/ / /| | / __ `__ \/ _ \
' / /| / ___ |/ / / / / / __/
' /_/ |_/_/ |_/_/ /_/ /_/\___/ '
' Elementery Keypad Program with the game HiLo....use as a routine
' when needed. There is a better 3x3 alphanumeric keypad at AN #21
' in the apps page but this one is simple and hackable.
' Program for a 4x4 keypad Plus "*" And "#" For Use In Other Programs.
' Note 1. Only test for press and release to stop multiple chars.
' Note 2. Subroutines "Getnum", "FindKey", the row subroutines and
' "Releasekey" are needed for the keypad.
' 28th April 2013
' Acknowledgement to - Amol Shah for concept.
' ASCII Text - http://www.network-science.de/ascii/ (use slant)
' ____ ___ __
' / __ \ __ / __(_)___ (_)/ /_(_)___ ____ _____
' / / / / _ \/ /_/ / __ \/ / __/ / __ \/ __ \/ ___/
' / /_/ / __/ __/ / / / / / /_/ / /_/ / / / (__ )
' /_____/\___/_/ /_/_/ /_/_/\__/_/\____/_/ /_/____/
$regfile = 8052.dat
$crystal = 11059200 ' Baud rate accurate Xtal
$baud = 2400
$large
Config Lcdpin = Pin , Db4 = P2.4 , Db5 = P2.5 , Db6 = P2.6 , Db7 = P2.7 , E = P1.0 , Rs = P1.2
Rem with the config lcdpin statement you can override the compiler settings
Config Lcd = 20 * 4
Column1 Alias P0.0 'The columns on my Keyboard
Column2 Alias P0.1 'have 10k ohm pullup resistors.
Column3 Alias P0.2
Column4 Alias P0.3
Row1 Alias P0.4
Row2 Alias P0.5
Row3 Alias P0.6
Row4 Alias P0.7
' Keyboard matrix goes like this..........
' Columns 1 2 3 4 Rows
' 1 2 3 A 1
' 4 5 6 B 2
' 7 8 9 C 3 For Reference
' * 0 # D 4 (ASCII 0=&H30 9=&H39 A=&H41 D=&H44 *=&H2A #=&H23)
'I have decoded it for the moment 0-9 then A=10 B=11 C=12 D=13 *=14 #=15
'as an byte value.
Dim A As Byte 'Flag indicating a key is pressed
Dim C As Byte 'Character of key pressed
Dim D As Byte '0-99 from 2 "C" variables
Dim K As Byte 'Random number
Dim X As Byte 'Number used to shuffle Rnd() function
' ____
' / __ \_________ ____ _________ ____ ___
' / /_/ / ___/ __ \/ __ `/ ___/ __ `/ __ `__ \
' / ____/ / / /_/ / /_/ / / / /_/ / / / / / /
' /_/ /_/ \____/\__ /_/ \__,_/_/ /_/ /_/
' ____/
Prelude :
K = Rnd(100)
Cursor Off
Gosub Rand_seed
Locate 1 , 1
Lcd "The Game is HiLo"
Locate 2 , 1
Lcd "Enter No. 0-100"
Main :
Gosub Get_num
D = C * 10
Locate 1 , 1
Lcd "Number guessed " ; C ; " "
Locate 2 , 1
Lcd " "
Gosub Get_num
D = D + C
Locate 1 , 1
Lcd "Number guessed " ; D
Locate 2 , 1
If D < K Then
Lcd "Too Low... "
Goto Main
If D > K Then
Lcd "Too High.. "
Goto Main
If D = K Then
Lcd "Your Right !!"
Wait 3
K = Rnd(100)
Locate 1 , 1
Lcd "Ready Again "
Locate 2 , 1
Lcd "Type 2 digit guess"
Goto Main
' _____ __ __ _
' / ___/__ __/ /_ _________ __ __/ /_(_)___ ___ _____
' \__ \/ / / / __ \/ ___/ __ \/ / / / __/ / __ \/ _ \/ ___/
' ___/ / /_/ / /_/ / / / /_/ / /_/ / /_/ / / / / __(__ )
'/____/\__,_/_.___/_/ \____/\__,_/\__/_/_/ /_/\___/____/
Rand_seed :
'Since the Rnd function is a mathematic function then we have to
'seed it so the function doesn't start from the first result everytime.
Locate 1 , 1
Lcd "Need 2 digit seed"
Gosub Get_num
D = C * 10
Locate 1 , 1
Lcd "First Digit " ; C ; " "
Gosub Get_num
D = D + C
Locate 1 , 1
Lcd "Seed " ; D
Waitms 250 'Reasure user it was entered
For X = 1 To D 'Like shuffling a deck of cards
K = Rnd(100)
Next X
'----------------------------------- Keypad Stuff ---------------------------------
Get_num :
A = 0 'Initialise "Key Pressed" flag
Gosub Find_key
If A = 0 Then Goto Get_num 'No key pressed so loop and try again
Gosub Key_released 'Now we wait till user lets the key go
Find_key :
'This is an simple 4x4 keyboard decoder with A to D and the * and # commented out
'----------- 1st Row ----------
Row1 = 0 'These feed the keyboard with a logic zero
Row2 = 1 'then a set of tests to see which
Row3 = 1 'column follows the row, this computes to
Row4 = 1 'the intersection which is the key linking
'row to column.
Debounce Column1 , 0 , 1_but , Sub
Debounce Column2 , 0 , 2_but , Sub
Debounce Column3 , 0 , 3_but , Sub
' Debounce Column4 , 0 , A_but , Sub 'Only Need 0 to 9
'----------- 2nd Row ----------
Row1 = 1
Row2 = 0
Row3 = 1
Row4 = 1
Debounce Column1 , 0 , 4_but , Sub
Debounce Column2 , 0 , 5_but , Sub
Debounce Column3 , 0 , 6_but , Sub
' Debounce Column4 , 0 , B_but , Sub '
'----------- 3rd Row ----------
Row1 = 1
Row2 = 1
Row3 = 0
Row4 = 1
Debounce Column1 , 0 , 7_but , Sub
Debounce Column2 , 0 , 8_but , Sub
Debounce Column3 , 0 , 9_but , Sub
' Debounce Column4 , 0 , C_but , Sub
'----------- 4th Row ----------
Row1 = 1
Row2 = 1
Row3 = 1
Row4 = 0
' Debounce Column1 , 0 , Star_but , Sub
Debounce Column2 , 0 , 0_but , Sub
' Debounce Column3 , 0 , Hash_but , Sub
' Debounce Column4 , 0 , D_but , Sub
'These subroutines provide the vars C and A
'with values from the rows debounce commands.
'---------- 1st Row -----------
1_but :
C = 1
A = 1
2_but :
C = 2
A = 1
3_but :
C = 3
A = 1
A_but :
C = 10
A = 1
'-------- 2nd Row -----------
4_but :
C = 4
A = 1
5_but :
C = 5
A = 1
6_but :
C = 6
A = 1
B_but :
C = 11
A = 1
'-------- 3rd Row -----------
7_but :
C = 7
A = 1
8_but :
C = 8
A = 1
9_but :
C = 9
A = 1
C_but :
C = 12
A = 1
'-------- 4th Row -----------
Star_but :
C = 14
A = 1
0_but :
C = 0
A = 1
Hash_but :
C = 15
A = 1
D_but :
C = 13
A = 1
Key_released :
A = 0 'Start with key released
Gosub Find_key 'Test key
'If A=1 the button is still down so loop
Loop Until A = 0 'If A=0 then key has been released then
'return.
Return |
