Const Pca9685adw =&H82 ' Write Adress (A0 to VCC and A1-A5 to gnd ) Const Pca9685m1 =&H00 ' Register Adress Mode 1 Const Pca9685m2 =&H01 ' Register Adress Mode 2 Const Led0 =&H06 ' Register adress LED0 next +4 Const Speedfront =250' Define waitms before next led front or left Const Speedback =100' Define waitms before next led back or right Const Minpower =0' Define minimum power to star led light Const Maxpower =4095' define max power Const Boostspeed =9' reduce the step 4096 is big
Dim A AsByte Dim Temp AsByte Dim Temp2 AsByte Dim Z AsWord Dim Inv AsWord Dim Pwml AsByte Dim Pwmh AsByte Dim First AsBit
' Reset device I2cinit I2cstart I2cwbyte Pca9685adw
I2cwbyte Pca9685m1
I2cwbyte&H01
I2cstop Waitms10 ' Set MODE 1 I2cstart I2cwbyte Pca9685adw
I2cwbyte Pca9685m1
I2cwbyte&H81 ' PCA Responds to Led All Call and Restart enabled I2cwbyte&HA1 ' enable auto increment I2cstop ' Set MODE 2 I2cstart I2cwbyte Pca9685adw
I2cwbyte Pca9685m2
I2cwbyte&H10 ' Set the output pin mode (direct to led) I2cstop ' ALL LED OFF For A =0To15
Temp =4* A
Temp = Temp + Led0
I2cwbyte Temp
I2cwbyte&H00
I2cwbyte&H00
I2cwbyte&H00
I2cwbyte&H00
I2cstop Next
First =1 Do For A =0To15Step1
Temp =4* A
Temp = Temp + Led0
Temp2 = Temp -4 For Z = Minpower To Maxpower Step Boostspeed
If First =1Or A >0Then
Pwml =Low(z)
Pwmh =High(z) I2cstart I2cwbyte Pca9685adw
I2cwbyte Temp
I2cwbyte&H00
I2cwbyte&H00
I2cwbyte Pwml
I2cwbyte Pwmh
I2cstop End If If A >0Then
Inv = Maxpower - Z
Pwml =Low(inv)
Pwmh =High(inv) I2cstart I2cwbyte Pca9685adw
I2cwbyte Temp2
I2cwbyte&H00
I2cwbyte&H00
I2cwbyte Pwml
I2cwbyte Pwmh
I2cstop End If Next
Waitms Speedfront
First =0 For A =15To0Step-1
Temp =4* A
Temp = Temp + Led0
If A >0Then
Inv = Maxpower - Z
Pwml =Low(inv)
I2cwbyte Temp
I2cwbyte&H00
I2cwbyte&H00
I2cwbyte Pwml
I2cwbyte Pwmh
I2cstop End If
Pwml =Low(z)
I2cwbyte Temp2
I2cwbyte&H00
I2cwbyte&H00
I2cwbyte Pwml
I2cwbyte Pwmh
I2cstop Next Waitms Speedback
Next Loop End
