'Amp Control Board
'RS-232 Protocol
'Normal operation
'a - Adjust to value
'd - Volume down
'f - Off
'm - Mute
'o - On
'r - Restore/Unmute
's - Status
'u - Volume up
'x - Settings
'In settings mode:-
'c - Current settings
'm - Set max gain
's - Set start gain
'x - Exit settings mode
'Port allocations
'Port D
'0 - RS232 RX
'1 - RS232 TX
'2 -
'3 - IR Indicator LED
'4 - DOUT (SDI) Pin 8 to Pin 3 - PGA2313
'5 - Clock (SCK) Pin 9 to Pin 6 - PGA2313
'6 - CS Pin 11 to Pin 2 - PGA2313
'Port B
'0 -
'1 -
'2 - IR Input
'3 - PWR Relay Pin 15
'4 - Vol+ Button Pin 16
'5 - Vol- Button Pin 17
'6 - PWR Button Pin 18
'7 - Mute Button Pin 19
'Gain Calulation
'For N = 1 to 255:
'Gain (dB) = 31.5 - [0.5 (255 - N)]
'Config Stuff
$regfile = "2313def.dat"
$baud = 9600
$lib "mcsbyte.lbx"
'Config SPI Interface
Config Spi = Soft , Dout = Portd.4 , Clock = Portd.5
Spiinit
'Config RC5 Interface
Config Rc5 = Pinb.2
Config Pinb.2 = Input
'Config debounce time in ms
Config Debounce = 30
'Declare Sub's and Func's
Declare Sub Get_gain
Declare Sub Set_gain
Declare Sub Inc_vol_up
Declare Sub Inc_vol_dwn
Declare Sub Mute
Declare Sub Unmute
Declare Sub Toggle_mute
Declare Sub Pwr_off
Declare Sub Pwr_on
Declare Sub Toggle_pwr
Declare Sub Print_off
Declare Sub Wait_some
'Declare Variables
Dim Volume As Byte
Dim Mute_state As Bit
Dim Max_gain As Byte
Dim Premute_lvl As Byte
Dim Address As Byte , Command As Byte
Dim Estartvol As Eram Byte , Emaxvol As Eram Byte 'Eprom Variables
'Aliases and Ports
Config Portb.3 = Output
Pwr_relay Alias Portb.3
Config Pinb.4 = Input
Volup_button Alias Pinb.4
Config Pinb.5 = Input
Voldwn_button Alias Pinb.5
Config Pinb.6 = Input
Pwr_button Alias Pinb.6
Config Portd.3 = Output
Ir_indicator Alias Portd.3
Config Portd.6 = Output
Cs Alias Portd.6
Config Pinb.7 = Input
Mute_button Alias Pinb.7
'Constants
Const Swversion = "1.0"
Const Startvol = 130
Const Maxvol = 220
Const Standardwait = 100
'Main Code
Print Swversion '; ", " ; Version()
Volume = Estartvol
Max_gain = Emaxvol
If Volume = 255 Then
Estartvol = Startvol
Emaxvol = Maxvol
Volume = Estartvol
Max_gain = Emaxvol
Premute_lvl = Volume
Pwr_off
'Main Loop
'Button handling
Debounce Volup_button , 0 , Inc_vol_up_sub , Sub
Debounce Voldwn_button , 0 , Inc_vol_dwn_sub , Sub
Debounce Pwr_button , 0 , Toggle_pwr_sub , Sub
Debounce Mute_button , 0 , Toggle_mute_sub , Sub
'Serial input handling
Select Case Inkey()
'ascii "a"
Case 097
Input "Gain? " , Volume ' (Max " ; Max_gain ; ")
Set_gain
'ascii "d"
Case 100
Inc_vol_dwn
'ascii "f"
Case 102
Pwr_off
'ascii "m"
Case 109
Mute
'ascii "o"
Case 111
Pwr_on
'ascii "r"
Case 114
Unmute
'ascii "s"
Case 115
Get_gain
'ascii "u"
Case 117
Inc_vol_up
'ascii x
Case 120
Print "Settings"
Gosub Settings
'RC5 IR Handling
Getrc5(address , Command)
If Address < 255 Then
Command = Command And &B01111111
Set Ir_indicator
Select Case Command
Case 12
Toggle_pwr
Case 86
Inc_vol_up
Case 85
Inc_vol_dwn
Case 13
Toggle_mute
Case Else
Wait_some
Reset Ir_indicator
'Sub Routines Code
'Get gain not in dB due to memory constraints!!
Sub Get_gain
Print "Gain=" ; Volume ; ", Mute=" ; Mute_state
'Set PGA gain
Sub Set_gain
If Volume > Max_gain Then
Volume = Max_gain
Reset Cs
Spiout Volume , 1
Spiout Volume , 1
Set Cs
Get_gain
'Increment Volume Up
Sub Inc_vol_up
If Pwr_relay = 1 Then
If Mute_state = 1 Then
Unmute
Volume = Volume + 1
Print "V+"
Set_gain
Wait_some
Print_off
'Increment Volume Down
Sub Inc_vol_dwn
Unmute
If Volume > 1 Then
Volume = Volume - 1
Print "V-"
Set_gain
Wait_some
Print_off
'Mute Routine
Sub Mute
'If Pwr_relay = 1 Then
If Mute_state = 0 Then
Volume = 0
Set Mute_state
Set_gain
If Pwr_relay = 0 Then
Print_off
Wait_some
'UnMute Routine
Sub Unmute
Volume = Premute_lvl
Reset Mute_state
Set_gain
Wait_some
Print_off
'Helper sub - mute toggle
Sub Toggle_mute
Unmute
Mute
'Power Off
Sub Pwr_off
Volume = Estartvol
Print_off
Mute
Reset Ir_indicator
Reset Pwr_relay
Wait 5
'Power On
Sub Pwr_on
Set Pwr_relay
Wait_some
Reset Ir_indicator
Print "PwrOn"
Unmute
'Helper sub - Toggle pwr state
Sub Toggle_pwr
Pwr_on
Pwr_off
'Prints "PwrOff" this is just to save memory(1%)!
Sub Print_off
Print "PwrOf"
'Wait sub to save memory
Sub Wait_some
Waitms Standardwait
'Labels for debouce calls
Inc_vol_up_sub:
Inc_vol_up
Toggle_pwr_sub:
Toggle_pwr
Toggle_mute_sub:
Toggle_mute
Inc_vol_dwn_sub:
Inc_vol_dwn
'Settings routine
Settings:
Select Case Inkey()
'ascii "c"
Case 099
Volume = Estartvol
Print "Start V " ; Volume
Print "Max V " ; Max_gain
'ascii "m"
Case 109
Input "Max? " , Max_gain
If Max_gain > 254 Then
Max_gain = 255
Emaxvol = Max_gain
'ascii "s"
Case 115
Input "Start? " , Volume
If Volume > 254 Then
Volume = 255
Estartvol = Volume
'ascii "x"
Case 120
Pwr_off
