Home arrow Application Notes arrow BASCOM-8051 arrow AN #27 - Count up/down timer
Tuesday, 09 February 2010
Registration/Updates Registration/Updates
AN #27 - Count up/down timer Print E-mail
Count up/down timer
This is a complete project Jure sent me with PCB design. It can be compiled with the BASCOM-8051 info since Jure used the AT89C2051 with 2KB of code.
Here is the comment from Jure:
Here is the description of the Timer:
S.E. Timer can countdown from 1-99 seconds, 1-99 minutes or 1-99 hours.
Timer has 4+1 press buttons, UP, DOWN, MODE, START + RESET
UP, DOWN set time that we want to count down, MODE selects the unit (sec., min. or hours) that we want to count down. Once we set time and set MODE, we can start countdown sequence. After countdown the relay turns on. To restart Timer, we must press RESET button.
In the countdown mode no buttons except RESET are active.
Download source code in .BAS file
Download PCB file #1
Download PCB file #2
And here is the BASCOM-8051 code:
' S.E. Timer, improved version
' author Jure Mikeln, December 2000
' S.E. Timer can countdown from 1-99 seconds
' 1-99 minutes or 1-99 hours
' Timer has 4+1 press buttons, UP, DOWN, MODE, START + RESET
' UP, DOWN set time that we want to count down
' MODE selects the unit (sec., min. or hours) that we want to
'  count down. Once we set time, set MODE, we can start countdown
' sequence. After countdown the relay turns on. To restart Timer,
' we must press RESET button.
' In the countdown mode no buttons except RESET are active.
' PCBs for Timer are available from: stik@svet-el.si
' or www.svet-el.si/english
Dim Clock As Byte , Stevec As Byte , Segmenti As Byte , X As Byte , P15 As Bit , P16 As Bit , P17 As Bit
Dim Clock12 As Word , Stevec1 As Bit , Stevec2 As Byte , Mux As Byte , Prikaz As Bit
Dim T1 As Bit , T2 As Bit , T3 As Bit
Dim Clock1 As Byte , Mod1 As Byte
Dim Izracun As Bit , Pomozna_v As Byte , Enice As Byte , Desetice As Byte , Minute As Word , Ure As Word
' SEGMENTS ARE AT P1.1 to P1.7
' P1.6 flashes with respect Timer MODE
' Mod=1=>sec =>P1.6 flashes quickly, Mod=2=>min =>P1.6 flashes slowly,
' Mod=3=>ure =>P1.6 glows constantly
Config Timer0 = Timer , Gate = Internal , Mode = 2
Config Debounce = 10
'Gate = Internal
'Mode = 2  8 bit auto reaload
Enable Interrupts
Enable Timer0
Load Timer0 , 250
Start Timer0
'initial settings
Clock
= 0
Stevec
= 0
T1
= P3.0 ' UP button
T2
= P3.2 ' DOWN button
T3
= P3.1 ' MODE button
'P3.0 and P3.1 together ' START button, see schematics
P16
= 1
P15
= 0
Mod1
= 1
P3
.7 = 0
Reset Segmenti
Minute
= 0
Clock12
= 0
Ure
= 0
On Timer0 Timer_0_int
'Main program
T3
= P3.1
T1
= P3.0
T2
= P3.2
If Mod1 = 1 Then
 P1
.6 = P15
End If 'P1.6 flashes quickly (seconds)
If Mod1 = 2 Then
 P1
.6 = P16 'P1.6 flashes slowly (minutes)
End If
If Mod1 = 3 Then
 P1
.6 = 0 'P1.6 glows constantly (hours)
End If
Gosub Tipke
Gosub Izracun1
'Interrupt routine
Timer_0_int
Incr Clock12
If Clock12 > 4000 Then
 Clock12
= 0
 P16
= Not P16 'one second pulse
 P17
= Not P17  'seconds indication
End If
Incr Clock
If Clock > 19 Then 'each 5 mS change of MUX-a
 Clock
= 0
Incr Mux
If Mux > 3 Then
 Mux
= 0
End If
 Prikaz
= 1
Incr Clock1
If Clock1 > 29 Then
 Clock1
= 0
 P15
= Not P15 'LED flashes every 150mSec.
End If
End If
'Press buttons routine
Tipke
If Mux > 2 Then 'this prevents turning LED display off when buttons are pressed
Debounce T1 , 0 , Stevec1 , Sub 'UP
Debounce T2 , 0 , Stevec , Sub 'DOWN
Debounce T3 , 0 , Mod , Sub 'MODE
End If
'Decrement variable Stevec
Stevec
If Stevec > 0 Then
Decr Stevec
If Stevec = 255 Then
 Stevec
= 99
End If
End If
'Increment variable Stevec
Stevec1
If T3 = 0 Then 'start countdown
Gosub Odstej1 'go to sub for decrementing
End If
Incr Stevec
If Stevec > 99 Then 'prevent Stevec to increment over 99
 Stevec
= 0
End If
'MODE select routine
'Mod1=1 seconds, Mod1=2 minutes, Mod1=3 hours
Mod:
Incr Mod1
If Mod1 > 3 Then
 Mod1
= 1
End If
'Routine that calculates tenths & units
Izracun1
 Desetice
= Stevec / 10
 Pomozna_v
= Desetice * 10
 Enice
= Stevec - Pomozna_v
If Prikaz = 1 Then
 Prikaz
= 0
 P3
.4 = 1
 P3
.5 = 1 'disable display
'disable display
If Mux = 0 Then
 Pomozna_v
= Enice 'show units
Gosub Prikaz1 'gosub for displaying
 P3
.5 = 0 'enable transistor for units
End If
If Mux = 1 Then
 Pomozna_v
= Desetice 'show tenths
 P3
.4 = 0 'enable transistor for tenths
End If
End If
'Displaying routine
Prikaz1
Restore Tabela
For X = 0 To 9
Read Segmenti
If X = Pomozna_v Then 'if X = value to display
 P1
= Segmenti 'then set this value to Port1
Exit For 'and exit FOR loop
End If
'---- data for LED display ------
Tabela
Data 96 , 249 , 196 , 208 , 89 , 82 , 66 , 248 , 64 , 80
'Routine that decrements preset time
Odstej1
Clock12
= 0 'reset timer variable
P16
= 1
If Stevec > 0 Then 'condition that prevents decr. below zero
Gosub Ure_sub 'gosub hours
Gosub Minute_sub 'gosub minutes
Gosub Sekunde_sub 'gosub seconds
Else
Exit Do 'it does not decrement if Stevec=0
End If
'Routine for minutes decrement
Minute_sub
If Mod1 = 2 Then 'check if Timer is in minutes MODE
 P1
.6 = P17 'signalization that it's minutes
 Min1
If P16 = 0 Then 'wait until P16 changes it's state (every second)
 P16
= Not P16
Incr Minute 'incr Minutes variable
If Minute > 59 Then 'if minutes > 59 then
 Minute
= 0
Decr Stevec 'decr variable Stevec every 60 sec
If Stevec = 1 Then
 Stevec
= 60
 Mod1
= 1
End If
If Stevec = 0 Then
 P3
.7 = 1 'turn on relay
 P3
.4 = 0 'both displays are on
 P3
.5 = 0
 P1
= 96 'display "0" on display
Stop
End If
End If
End If
Gosub Izracun1 'display value of Stevec variable
End If
'Routine that decrements preset hours
Ure_sub
If Mod1 = 3 Then 'check if Timer is in hours MODE
 P1
.6 = 0 'signalization of Hours MODE
 P16
= Not P16
Incr Ure
If Ure > 3599 Then
 Ure
= 0
Decr Stevec 'decrement Stevec variable every 3600 seconds
If Stevec = 1 Then 'when Stevec=1,
 Stevec
= 60 'Set Stevec=60 and decrement minutes
 Mod1
= 2 'Set Mod1 to minutes MODE
End If
If Stevec = 0 Then
 P3
 P3
 P3
.5 = 0
 P1
= 96 'display number "0"
Stop
End If
End If
End If
End If
'Routine for Seconds decrementing
Sekunde_sub
If Mod1 = 1 Then
 P16
= Not P16
Decr Stevec 'Decrement variable Stevec for 1
If Stevec = 0 Then
 P3
 P3
 P3
.5 = 0
 P1
Stop
End If
End If
End If
Gosub Izracun1 ''display value of Stevec variable
