Home arrow Application Notes arrow BASCOM-8051 arrow AN #25 - Using the T6963 based GRAPHIC DISPLAY
Thursday, 02 September 2010
Registration/Updates Registration/Updates
BASCOM Help BASCOM Help
AN #25 - Using the T6963 based GRAPHIC DISPLAY Print E-mail
Peter Huijssen figured out how to use the graphical displays that are equipped with the T6963 chip.
The following document describes how you can create your own bitmaps
The document for writing software for T6963C based LCD
A part of the BASCOM-8051  sample is shown below.
Since it is much work to include these DATA lines, I will create a special compiler directive so that TIF files can be included without modification!
'DEMO PROGRAM T6963 BASED GRAPHIC DISPLAYS USING BASCOM-8051
'Author : P. Huijssen
' The Netherlands
'This program shows a bitmap and some text on a graphic display type : TLX1741-C3M
'which uses the T6963 controller.
'The display has a screenresolution of 240x128 pixels
'The display uses a data/command line to determine of a databyte or command byte is sent.
'In this application it's connected to A14 which makes it easy te sent data or a command.
'Data is sent to &H8000 (C/D line low)
'Commands/statuscheck written/read at &HC000 (C/D line high)
'The software is really an experiment and may not match the 'rules' of proper programming
'All of the used settings regarding the display are very well described in the datasheet
'The displayscreen should show 'TOSHIBA' in large characters (bitmap) and two lines of text
'INIT
$regfile = "REG51.DAT" 'your uC
$crystal = 11059200 'your crystal. Not important to control the display
'as long if you don't exceed an instruction time of 200ns
'VARIABELS DISPLAY AND TO SHOW GRAPHICS
Dim Data_display As Byte
Dim Status As Byte
Dim Mask_status As Byte
Dim Dta_1 As Byte
Dim Dta_2 As Byte
Dim Cmdo_1 As Byte
Dim Adres_pointer As Integer
Dim Dummy_adres_pointer As Integer
Dim Dummy As Integer
'VARIABELS USED TO SHOW TEXT
Dim Text As String * 21
Dim String_length As Byte
Dim String_scanner As Byte
Dim Temp_string As String * 2
'START PROGRAMME
Gosub Set_display  'init display
Gosub Display_blank 'clear screen
Gosub Show_bitmap 'place bitmap
Text
= "T6963 DEMO SOFTWARE"
Adres_pointer
= &H1831  'set adres_pointer in text ram
Gosub Show_text 'calculate display data
Text
= "PH 2000"
Adres_pointer
= &H1891
Gosub Show_text
'DISPLAY SETUP
Set_display
P1
.0 = 1 'Reset display. Active low
Nop : Nop 'I thought I might need it during
P1
.0 = 0  'the execution of the code so I didn't
Nop : Nop 'use a hardware reset from a watchdog for
P1
.0 = 1 'instance.
Restore Dta_init 'init display. see also datasheet
For dummy = 1 To 7
Read Dta_1
 Data_display
= Dta_1
Gosub Writed
Read Dta_2
 Data_display
= Dta_2
Gosub Writed
Read Cmdo_1
 Data_display
= Cmdo_1
Gosub Writec
Next Dummy
Dta_init
Data &H00 , &H00 , &H42 'home adress graphical ram.upperleft corner
Data &H1E , &H00 , &H43 'linewidth graphics (bytes per line)
Data &H00 , &H17 , &H40 'home adres text ram.upperleft corner
Data &H1E , &H00 , &H41 'lijnbreedte grafisch (characters per line)
Data &H00 , &H00 , &H81 'modeset intern CharRom,XOR mode
Data &H00 , &H00 , &H9E 'displaymode mixed text and graphics
Data &H00 , &H00 , &H24
'CLEAR SCREEN (ERASE GRAPHIC+TEXT RAM)
Display_blank
Adres_pointer
= &H00 'upperleft corner graphic ram
Gosub Set_adres
For dummy = 1 To 3840  'clear graphic ram
'by writing '0'
 Data_display
= &H00
Gosub Writed
 Data_display
= &H00
Gosub Writed
 Data_display
= &HC0  'auto increment adres_pointer by 1
Gosub Writec
Next Dummy
Adres_pointer
= &H1700 'upperleft corner text ram
Gosub Set_adres
For dummy = 1 To 480 'clear text ram
'by writing '0'
 Data_display
= &H00
Gosub Writed
 Data_display
= &H00
Gosub Writed
 Data_display
Gosub Writec
Next Dummy
' PLACE ADRES POINTER DISPLAY
Set_adres
:  'set adres display
Dta_1
= Adres_pointer And &H00FF 'calculate msb/lsb
Dummy_adres_pointer
= Adres_pointer And &HFF00
Dummy_adres_pointer
= Dummy_adres_pointer / &HFF
Dta_2
Data_display
= Dta_1 'send adres to display
Gosub Writed
Data_display
= Dta_2
Gosub Writed
Data_display
= &H24 'data sent is adres data
Gosub Writec
'PLACE TEXT.
Show_text
Gosub Set_adres 'set adres pointer
String_length
= Len(text)  'calculate string length
For String_scanner = 1 To String_length 'send string to display one
'character at the time
 Temp_string
= Mid(text , String_scanner , 1)
 Dta_2
= Asc(temp_string)
 Dta_2
= Dta_2 - &H20 'ascii codes in the char rom
'have an offset of - &H20. see datasheet
 Data_display
= &H00
Gosub Writed
 Data_display
= Dta_2
Gosub Writed
 Data_display
Gosub Writec
Next String_scanner 'loop until whole string is sent
'WRITE COMMAND AND DATA NAAR DISPLAY + STATUSCHECK
Writec
: 'write display command
Gosub Status_check
Out &H3800 , Data_display
Writed
: 'write display data
Gosub Status_check
Out &H3000 , Data_display
Status_check
:  'check status controller
Status_1
Status
= Inp(&H3800)
Mask_status
= Status And 3
If Mask_status = 3 Then : Return
End If
Goto Status_1
'SHOW BITMAP
Show_bitmap
Gosub Display_blank
Adres_pointer
= 0
Gosub Set_adres
Restore Bitmap_data
Read Dta_2 'read bitmap data and send to display
 Data_display
= 0
Gosub Writed
 Data_display
= Dta_2
Gosub Writed
 Data_display
= &HC0
Gosub Writec
Next Dummy
Bitmap_data
: 'TOSHIBA in large characters
Data &H00 , &H00 , &H00 , &H00 , &H00 , &H00
Data &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00
THE REST
IS DELETED. So you need the SAMPLE!
