Home arrow Application Notes arrow BASCOM-8051 arrow AN #24 - How to increase resolution of DS1821 temperature sensor
Thursday, 02 September 2010
Registration/Updates Registration/Updates
BASCOM Help BASCOM Help
AN #24 - How to increase resolution of DS1821 temperature sensor Print E-mail
This application note was written by Dusko Djuricin.
It shows how to expand the resolution of the DS1821.
Dusko included the schematic in ASCII too.
' Program: DS1821HI.BAS
' Author: Dusko Djuricin
' E-mail: djdusko@eunet.yu
' This program demonstrates how to increase resolution of DS1821 temperature sensor.
' According to Dallas Application Note 105, there is an undocumented command for reading
' remain value in DS1821 counter, which is used in standard application for rounding the
' readout (1 Celsius degree resolution). Using this technique it is possible to achive
' 0.5 Celsius degree resolution and an real (not integer) readout!
' Test bed for this program was 89S8252 with minimal hardware, 2x16 LCD and DS1821 connected
' in the following way:
' P1.1 +-----o----------------| 270E |-----------o +5V
' P1.0 +-----|---------o------| 4K7 |-----------o +5V
' AT89S8252 | o o
' -------------- VDD DQ
' Third pin of DS1821 (GND pin) should be connected directly to GND.
'-----------------------[Subroutine declarations]---------------------------------
Declare Sub Write_ds1821(addr As Byte , N As Byte)
Declare Sub Mode_toggle_ds1821
Declare Sub Write_stat_ds1821(n As Byte)
'------------------------[variable declarations]---------------------------------
Dim N As Byte
Dim Addr As Byte
Dim Temp_w As Word
Dim Count_remain As Word
Dim Count_per_degree As Word
Dim T As Single
Dim T1 As Single
Dim Sign As String * 1
Dim Tc$ As String * 8
Dq
Alias P1.0
Vdd
Alias P1.1
'-------------------------[Beginning of Code]------------------------------------
Config 1wire = Dq ' define 1WIRE pin
Cursor Off
Cls
Lcd " DS1821 in "
Lowerline
Lcd " high resolution"
Wait 2
Cls
Lcd " presented by"
Lowerline
Lcd "djdusko@eunet.yu"
Wait 3
For N = 1 To 16
Shiftlcd Right
Waitms 150
Next N
Cls
'-----[initialize DS1821]--------------
Mode_toggle_ds1821
' put device into 1wire mode
Write_stat_ds1821
&H01 ' write in status register:
' oneshot measure (IMPORTANT!)
' active output low,
' power up in 1wire mode
'----------[main loop]------------------
 1wreset
' reset 1WIRE bus
 1wwrite
&HEE  ' start conversion (one shot)
!L_wait: ' now...
 1wreset
' reset 1WIRE bus,
 1wwrite
&HAC ' read status register,
 N
= 1wread()  ' and check,
mov a,{n} ' does conversion is finished...
 rlc a
' if not,
 jnc L_wait
' loop for a while
 1wreset
' reset 1WIRE bus
 1wwrite
&HAA ' and read
 N
= 1wread() ' measured value
 Sign
= "" ' prepare sign variable
If N.7 = 1 Then ' if temperature is < 0
 N
= 256 - N ' convert it from 2nd complement
 Sign
= "-" ' and mark sign
End If ' (so far it was standard procedure).
 1wreset
' reset 1WIRE bus
 1wwrite
&HA0 ' now read remaind part of DS1821 counter
 Count_remain
= 1wread(2) ' (it is 9 bit long!)
 1wreset
' reset 1WIRE bus
 1wwrite
&H41 ' send LOAD COUNTER command which prepares
 1wreset
' (reset 1WIRE bus)
 1wwrite
&HA0  ' for reading the internal parameter
 Count_per_degree
= 1wread(2) ' needed for further calculations (9 bits)
 Temp_w
= Count_per_degree - Count_remain ' (see details in DALLAS AN105)
 T1
= Count_per_degree 'For T >= 0:
 T
= Temp_w / T1 ' Count_per_degree - Count_remain
 T1
= N 'T = N - 1/2LSB + -------------------------------
If Sign = "" Then ' Count_per_degree
 T1
= T1 - 0.5 '
 T
= T1 + T 'For T < 0:
Else ' Count_per_degree - Count_remain
 T1
= T1 + 0.5 'T = N + 1/2LSB - -------------------------------
 T
= T1 - T ' Count_per_degree
End If  '
 Tc$
= Fusing(t , ##.##) ' format the readout and
Locate 1 , 4 : Lcd "T=" ; Sign ; Tc$ ; "[C] " ' display measured temperature
Loop ' loop forever
'-------------------------------[DS1821 subroutines]-------------------------------
 1wreset
' reset 1WIRE bus
 1wwrite Addr
' write command
 1wwrite N
' and then data
End Sub
$asm
 setb Dq
' rise DQ line
nop ' (settling time required by DS1821)
clr Vdd ' now drop VDD line and
mov a,#15 ' clock DQ line 16 times ...
L_clk
: ' (this is the way how to put device
clr dq ' into 1WIRE mode, if it was previously
nop ' programmed in thermostat mode)
 setb dq
 djnz a
,l_clk
nop
 setb Vdd
' now rise VDD line (back to normal operation)
$end Asm
End Sub
 1wreset
' reset 1WIRE bus
 1wwrite
&H0C ' address status register (write command)
 1wwrite N
' and write data
End Sub
'---------------------------------[End of Code]----------------------------------
