Home arrow Application Notes arrow BASCOM-8051 arrow AN #23 - Reading and writing the Dallas DS1991 secure I-button
Thursday, 02 September 2010
Registration/Updates Registration/Updates
BASCOM Help BASCOM Help
AN #23 - Reading and writing the Dallas DS1991 secure I-button Print E-mail
This application note is written by Evert K. Dekker
Download .PDF file for DS1991
Download source code in .BAS file
'Demonstration of reading and writing the Dallas DS1991
'secure I-button. Using the 1-wire statements.
' You must use Bascom-8051 1.09 or higher !!
' pull-up of 4K7 required to VCC from P3.2
' DS1991 serial button connected to P3.2
' E.K.Dekker 1999 Lampje@Xs4all.nl
Config 1wire = P3.2 'use this pin
Dim Ar(16) As Byte , I As Byte , Temp As Byte
Dim Text As String * 16 , Temp2 As String * 1
Main
'Reading first the ROM-number
 1wreset
'reset the device
 1wwrite
&H33 'read ROM command
 Ar
(1) = 1wread(8) 'read 8 bytes
Print "ROM number : ";
For I = 1 To 8
 Printhex Ar
(i); 'print ROM-number
Wait 1 'wait a moment
'Writing scratchpad
'It is possible to write 64 bytes of data to the scratchpad. In this example
'i only used 16 bytes.You can write/read the other bytes if you change the
'array or start address.
 Text
= "Scratchpad data."
Ar
(1) = &H96 'Write scratch command
Ar
(2) = &HC0 'Start address + C0H
Ar
(3) = &HFF - Ar(2) 'Complement of Ar(2)
 1wreset
'reset the device
 1wwrite
&HCC 'Skip read ROM command
 1wwrite Ar
(1) , 3 'Write command to DS1991
Gosub Fill_write_array 'Fill array with "Text"
 1wwrite Ar
(1) , 16 'Write 16 bytes to DS1991
'Reading scratchpad back
Ar
(1) = &H69 'Read scratch command
Ar
(2) = &HC0 'Start adress + COH
Ar
 1wreset
'reset the device
 1wwrite
 1wwrite Ar
 Ar
(1) = 1wread(16) 'Read 16 bytes from DS1991
Print "Scratch pad : "; '
For I = 1 To 16 'Prints the contents of the
 Temp
= Ar(i) ' scratchpad
Print Chr(temp); '
Next I '
'Writing subkeyid and password
'Writing new subkeyid and password will destroy all data in subkey.
'The DS1991 has 3 Subkeys, 1=00H , 2=40H , 3=80H
'The variable "text" must be exactly 16 bytes, the first 8 for Subkey-id and the
'last 8 for password. Every subkey has it's own password.
Text
= "Subkyid1PASSWORD" 'New subkey-id and password
Ar
(1) = &H5A 'Change password command
Ar
(2) = &H00 'Subkey-id to change
Ar
 1wreset
'reset the device
 1wwrite
 1wwrite Ar
 Ar
(1) = 1wread(8) 'Read old-id
 1wwrite Ar
(1) , 8 'Write old-id back to DS1991
 1wwrite Ar
(1) , 16 'Write New-id and password
'Writing subkey
'It is possible to write 64 bytes of data to the subkey. In this example
Text
= "Hello world!!!!!" 'New subkey
 Ar
(1) = &H99 'Writing subkey command
 Ar
(2) = &H10 'Subkey(00H) + Start address (10H)
 Ar
 1wreset
'reset the device
 1wwrite
 1wwrite Ar
(1) , 3 'Write subkey write command
 Text
= "Subkyid1" 'Must be the same as the first 8
Gosub Fill_write_array ' bytes of "writing subkeyid & passw."
 1wwrite Ar
(1) , 8  'Write Subkeyid for conformation
 Text
= "PASSWORD" 'Must be the same as the last 8
 1wwrite Ar
(1) , 8 'Write password to DS1991
 Text
= "Hello world !!!!" 'New subkey data
 1wwrite Ar
Wait 1
'Reading subkey
Ar
(1) = &H66 'Read secured subkey command
Ar
(2) = &H10 'Subkey(00H) + Start adress (10H)
Ar
 1wreset
'reset the device
 1wwrite
 1wwrite Ar
(1) , 3  'Write subkey read command
 Ar
(1) = 1wread(8) 'DS1991 respons with the Subkey-id
 Text
 1wwrite Ar
 Ar
(1) = 1wread(16) 'Reads 16 bytes from DS1991
Print "Sub key : "; '
For I = 1 To 16 '
 Temp
= Ar(i) 'Prints the contents of the
Print Chr(temp); ' subkey.
Next I '
Goto Main  'And do it again
Fill_write_array
For I = 1 To 16
Temp2
= Mid(text , I , 1)
Ar
(i) = Asc(temp2)
Next I
