Keyboard decoder - by Mike Gill
Download source code in .ZIP file
' Reads a standard 3X4 keypad and
assembles No in Digits variable, then displays
' Led used is just to show program running 2K2 from port
pin via Led to +
' Setup for 89S8252. Use appropriate port assignments for
other processors
' Uses Active Low, so no extra components needed. Chip
internal tieups are utilised
' Mike Gill . B M Electronics UK 01422 839321
Startup:
Config DeBounce = 40 ' Set Key Pad Debounce to 40 Ms
Config Lcd = 16 * 1
Cursor OFF
'OUTPUTS All Active High
StatusLed Alias P2.7 ' Operational Status
Col1 Alias P2.6 ' Keyboard Column Drivers
Col2 Alias P2.5
Col3 Alias P2.4 ' Add Another Col for 4X4 Kpad
'INITIAL OUTPUT STATES
StatusLed = 1
'INPUTS All Active Low
Row1 Alias P2.0 ' Keyboard Rows (Read)
Row2 Alias P2.1
Row3 Alias P2.2
Row4 Alias P2.3
'VARIABLES
Dim Check As Byte ' Detects Key Released
Dim KeyRead As Byte ' Actual Button Value
Dim Digits As Word ' Actual Dialled Number
'INITIALISE VARIABLES
Digits = 0
KeyRead = 0
Check = 0
KeyScan: ' Keypad Read
Routine (Assignments can be changed for different connections)
StatusLed = 0 ' Status
Led OFF
Col1 = 0 : Col2 = 1 : Col3 = 1 ' Turns Columns On (Low) 1 by 1
KeyRead = 1 : DeBounce Row1,0,GotKey,Sub ' Gosub if Key
Pressed
(Reads LOW Input)
KeyRead = 4 : DeBounce Row2,0,GotKey,Sub
KeyRead = 7 : DeBounce Row3,0,GotKey,Sub
KeyRead = 11 : DeBounce Row4,0,GotKey,Sub ' CALL Button *
Col1 = 1 : Col2 = 0 : Col3 = 1 ' Assign KeyRead to Any No You Like <256
KeyRead = 2 : DeBounce Row1,0,GotKey,Sub
KeyRead = 5 : DeBounce Row2,0,GotKey,Sub
KeyRead = 8 : DeBounce Row3,0,GotKey,Sub
KeyRead = 0 : DeBounce Row4,0,GotKey,Sub
Col1 = 1 : Col2 = 1 : Col3 = 0 ' Add Another Section After this for 4X4 Kpad
KeyRead = 3 : DeBounce Row1,0,GotKey,Sub
KeyRead = 6 : DeBounce Row2,0,GotKey,Sub
KeyRead = 9 : DeBounce Row3,0,GotKey,Sub
KeyRead = 12 : DeBounce Row4,0,GotKey,Sub ' CANCEL Button #
WaitMs 50 ' Status Led OFF Time
StatusLed = 1 ' Turns
Status Led ON
WaitMs 15 ' Status Led ON Time (Only to show Program Running)
Goto KeyScan
GotKey:
CheckAgain: ' Reads P2
Directly and Waits for all Keys Released
Check = P2 And 15 ' Appropriate Port
If Check <> 15 Then : Goto CheckAgain
: End If ' Check for Key Release
If Keyread = 12 Then : Goto StartUp : End If ' CANCEL Button
If Keyread = 11 Then : Goto CallNumber : End If ' CALL Button
Digits = Digits * 10 ' Assemble Dialling No in Digits
Variable
Digits = Digits + Keyread
Cls : Lcd Digits ' Display Accumulating Number
KeyRead = 0 ' Clear
Keypad Read Variables
Check = 0
CallNumber: ' What You Like
Here. When call key pressed
Goto StartUp
