Home arrow Application Notes arrow BASCOM-8051 arrow AN #06 - Reading the DS1820 Temperature Sensor
Tuesday, 09 February 2010
Registration/Updates Registration/Updates
AN #06 - Reading the DS1820 Temperature Sensor Print E-mail
This example is written by Bojan Ivancic.
It has 0.1 C resolution and with 8-bit CRC.
Download source code in Bas file
' Author : Bojan Ivancic
' Example measuring temperature using Dallas DS1820,
' with calculated for 0.1 C resolution and with 8-bit CRC!
$CRYSTAL = 12000000 ' we are using this frequency
declare sub Read1820
declare sub CRCit
declare sub Temperature
dim bd(9) as byte
dim i as byte , tmp as byte
dim CRC as byte
dim T as integer , T1 as integer
dim v as byte
Config 1wire = P1.0 ' DS1820 on pin 12 (pull up)
cursor off noblink
cls
locate 1 , 1 : lcd "DEMO for DS1820"
locate 2 , 1 : lcd "T="
do
 Temperature
waitms 250
loop
sub Temperature ' actual measuring
 1wwrite
&hcc : 1wwrite &h44 ' start measure
waitms 300 ' wait for end of conversion
 Read1820
' read 9 bytes
if Err = 1 then ' if there is no sensor
locate 2 , 4 : lcd "-- " ' we put "-- " on LCD
else
if CRC = 0 then ' sensor present, check CRC
locate 2 , 4 : lcd T ' CRC OK, print T*10 on LCD
else
locate 2 , 4 : lcd "** " ' CRC NOT OK, "** " on LCD
end if
end if
end sub
sub Read1820 ' reads sensor ans calculate
' T for 0.1 C
 1wreset
' reset the bus
 1wwrite
&hcc ' read internal RAM
 1wwrite
&Hbe  ' read 9 data bytest
 bd
(1) = 1wread(9) ' read bytes in array
 1wreset
' reset the bus
 CRCit
' ckeck CRC
if CRC = 0 then ' if is OK, calculate for
 tmp
= bd(1) and 1 ' 0.1C precision
if tmp = 1 then decr bd(1)
 T
= makeint(bd(1) , bd(2))
 T
= T * 50 : T = T - 25 : T1 = bd(8) - bd(7) : T1 = T1 * 100
 T1
= T1 / bd(8) : T = T + T1 : T = T / 10
end if
end sub
sub CRCit ' calculate 8 bit CRC
' bigger but faster
 CRC
= 0 ' needs a 256 elements table
for i = 1 to 9
 tmp
= CRC xor bd(i)
 CRC
= lookup(tmp , crc8)
next
end sub
crc8:
data 0 , 94 , 188 , 226 , 97 , 63 , 221 , 131 , 194 , 156
data 126 , 32 , 163 , 253 , 31 , 65 , 157 , 195 , 33 , 127
data 252 , 162 , 64 , 30 , 95 , 1 , 227 , 189 , 62 , 96
data 130 , 220 , 35 , 125 , 159 , 193 , 66 , 28 , 254 , 160
data 225 , 191 , 93 , 3 , 128 , 222 , 60 , 98 , 190 , 224
data 2 , 92 , 223 , 129 , 99 , 61 , 124 , 34 , 192 , 158
data 29 , 67 , 161 , 255 , 70 , 24 , 250 , 164 , 39 , 121
data 155 , 197 , 132 , 218 , 56 , 102 , 229 , 187 , 89 , 7
data 219 , 133 , 103 , 57 , 186 , 228 , 6 , 88 , 25 , 71
data 165 , 251 , 120 , 38 , 196 , 154 , 101 , 59 , 217 , 135
data 4 , 90 , 184 , 230 , 167 , 249 , 27 , 69 , 198 , 152
data 122 , 36 , 248 , 166 , 68 , 26 , 153 , 199 , 37 , 123
data 58 , 100 , 134 , 216 , 91 , 5 , 231 , 185 , 140 , 210
data 48 , 110 , 237 , 179 , 81 , 15 , 78 , 16 , 242 , 172
data 47 , 113 , 147 , 205 , 17 , 79 , 173 , 243 , 112 , 46
data 204 , 146 , 211 , 141 , 111 , 49 , 178 , 236 , 14 , 80
data 175 , 241 , 19 , 77 , 206 , 144 , 114 , 44 , 109 , 51
data 209 , 143 , 12 , 82 , 176 , 238 , 50 , 108 , 142 , 208
data 83 , 13 , 239 , 177 , 240 , 174 , 76 , 18 , 145 , 207
data 45 , 115 , 202 , 148 , 118 , 40 , 171 , 245 , 23 , 73
data 8 , 86 , 180 , 234 , 105 , 55 , 213 , 139 , 87 , 9
data 235 , 181 , 54 , 104 , 138 , 212 , 149 , 203 , 41 , 119
data 244 , 170 , 72 , 22 , 233 , 183 , 85 , 11 , 136 , 214
data 52 , 106 , 43 , 117 , 151 , 201 , 74 , 20 , 246 , 168
data 116 , 42 , 200 , 150 , 21 , 75 , 169 , 247 , 182 , 232
data 10 , 84 , 215 , 137 , 107 , 53
