Home arrow Application Notes arrow BASCOM-8051 arrow AN #04 - Reading the Dallas temperature sensor DS1821
Tuesday, 09 February 2010
Registration/Updates Registration/Updates
AN #04 - Reading the Dallas temperature sensor DS1821 Print E-mail
Here is a good example on how to read the Dallas DS1821.
It is written by Denis Bernard.
Download source code in Bas file
 ' Written by Denis Bernard
' bernard@xs4all.nl
' 1 wire communication with Dallas temperature sensor DS1821
' small PR35 Package, 3 pin , ± 2$. See Conrad elec.(europe)
' Temperatures are printed in degres when >-1° , <125°
' for temperature <0 , 256 - Temp_buf will give from -55 to -1
$crystal = 24000000 : $baud = 2400
Config 1wire = P3.3 'use P3.3 for 1 wire communication
Enable Int1 : Enable Interrupts 'Int1 optional (24MHz)
Dim Temp_buf As Byte , Stat_buf As Byte
 1wreset
Print Err ' optional
 1wwrite
&H0C ' write status
 1wwrite
&B01000010 ' continu convertion
Debut
 1wreset
 1wwrite
&HEE ' start conversion
 1wreset
 1wwrite
&HAA ' get temperature
 Temp_buf
= 1wread()
 1wreset
' optional
 1wwrite
&HAC ' optional read status
 Stat_buf
= 1wread() ' optional 82 when DS1821 run
Print Temp_buf ; " " ; Stat_buf ; " " ; Tcon ' temperature is Temp_buf
Goto Debut
'Note that int1 pin is used because of the 24 Mhz Crystal
'this slow-down the communication (with out Isr code) just enough.
'make sure Tcon.2 (IT1) remain zero. if not [ Reset tcon.2 ]
'with a 12 MHh crystal any pin can be used and no need for interrupt.
' DS1821 pin1 = Gnd / pin2 = data in/out / pin 3 = +5v
' tested on Bascom-8151 + Bascom Lt
