AN #172 - Inductance Meter |
by H. Williams ( http://rototron.info )
This is a perfect example of why it takes me so long to get projects done. I
was working on my computer controlled vacuum chamber to create better lens for
my RGB Volcano Buttons which behooved me to
create a 24V step up circuit which required an inductor. Looking though my
parts bin I found many inductors but had no way to determine their values.
Hence my Inductor Meter. I selected a Wintergreen Altoids tin as my project
enclosure.
Below is the 3D model of the circuit board created in POV-Ray using Eagle3D. The meter is controlled by an Atmel AVR microcontroller.
I designed the schematics and circuit board using the free version of
CadSoft Eagle.
I designed the board to be single-sided and no bridges are required.
I etched the circuit board using a laser printer, glossy photo paper, hydrogen
peroxide and muriatic acid.
Here is the completed board. The 11 unconnected pads are for the LCD display
and 3 pushbuttons which are mounted to the lid of the case. The red and black
plugs connect to banana jacks on the side of the case.
Here is a shot of the board mounted in the case. The Altoids tin is not very
deep so I had to make the board as low profile as possible. Therefore, none of
the IC's are in sockets. I used an extra small crystal and I found a very flat
DPDT 5V relay on an old modem card which also provided the opto-coupler that
allows the AVR to drive the relay. I bent the larger capacitors down and I
selected a mini-USB connector to supply the 5V power. I have a box in my office
of broken PDA's and cell phones that people have given me over the years. A
smashed Blackberry provided the USB connector. The SMD mini-USB proved very
difficult. I soldered 3 posts to the connector to mount it securely to the
board. However, when I tried bending the surface mount pins, they immediately
broke off. Much to my amazement, I was able to solder leads to the tiny +5V and
ground stubs. With minor modifications the meter could also be used to measure
capacitance, but the extra parts would have made it harder to fit in the
Altoids tin and I already have a multi-meter that measures capacitors.
Next I cut a rectangular opening in the Altoids top. This was not easy because
the opening had to be very precise to hold the LCD display. First I tried a
nibbler, but the tin kept jamming the blade. I also tried a scissor, which cut
well but was too hard to navigate in the confined space. Then I tried my Dremel
with a carbide disc. This cut very well, but I ruined 2 tins because I couldn't
cut straight enough. Fortunately, Altoids tins only cost 99 cents at my local
drug store. The third was a success after I built a small jig out of some old
3.5" hard drive mounts to keep the Dremel blade straight.
I salvaged the LCD display from a box of broken business phones at
my office. The display fits perfectly in the opening. There are also 3
buttons built in to the display. The mode button initiates a
calibration. I'm using the page and scroll buttons to lock and unlock
the display. The LCD plastic cover, buttons and the LCD display are
held in place by friction. It is very tight fit inside the case and
when the cover is closed nothing moves around.
I picked up a home powder coating kit that I was anxious to try out. I soldered
together a rig of 12 gauge copper wire to hold and ground the pieces of the
Altoids case while coating. It worked well but I didn't consider something very
important...
I neglected the fact that solder melts at about the same temperature that
powder coating melts. While cooking the powder in my toaster oven at 375F the
rig collapsed. Still the damage was not too bad. I lost some of the powder on
the sides, but it made an interesting pattern and the flaking was only along
the rim which you can't see when closed.
The reassembled case after powder coating.
The LCD display connected to the main circuit board. The pinout of the
LCD controller is a little different from most HD44780's. There are no
DB0-DB3 connections. Instead the 15 pin connector on the display
contains 3 pins and a dedicated ground for the 3 pushbuttons.
The LCD display mounted. The photo doesn't really do the powder coating
justice. The color is a very rich burgundy.
The meter measuring a 180uH inductor. The lock in the upper right corner
indicates that the display has been locked.
The total cost of the project is about $15.
Parts List:
Description |
QTY |
Atmel ATMEGA48V-10PI |
1 |
10 MHz Crystal HC49/US |
1 |
Resistor Carbon Film 330 Ohm 1/4 Watt 10% |
1 |
Resistor Carbon Film 1K Ohm 1/4 Watt 10% |
1 |
Resistor Carbon Film 10K Ohm 1/4 Watt 10% |
1 |
Resistor Carbon Film 47K Ohm 1/4 Watt 10% |
1 |
Resistor Carbon Film 100K Ohm 1/4 Watt 10% |
3 |
Ceramic Radial Capacitor 18pF 50V 5% |
2 |
Ceramic Radial Capacitor 1nF 50V 5% |
1 |
Ceramic Radial Capacitor .01uF 50V 10% |
2 |
Dipped Solid Aluminum Capacitor 10uF 16V 20% |
3 |
68uH Axial Inductor |
1 |
2 Pin Right Angle Header .100" |
1 |
Shunt .100" |
1 |
5 x 2 Pin Gold Straight Header .100" |
1 |
LM311N Comparator 8 DIP |
1 |
NEC 2501 Opto-Coupler |
1 |
NAIS TQ2SA 5V DPDT Relay 10 DIP |
1 |
Mini-USB SMD Connector |
1 |
Banana Jacks |
2 |
LCD Display 16x2 with HD44780 Controller & 3 pushbuttons |
1 |
Single-sided Copper Clad Board 1 oz. 2.75" x 2.125" |
1 |
Altoids 50g Tin |
1 |
I wrote the software for the AVR chip using Bascom-AVR. Using the formulas below, the code solves for
inductance (L) using 2 known values: capacitance (C) and frequency (f). The
capacitance is set using a 1nF capacitor and the frequency is generated using
the comparator. Once the meter is calibrated then the second formula can be
used to determine the change in inductance when an inductor is placed across
the probes.
Version 0.10 - Released 08/20/2006 - For ATMEGA48V (Requires fuses set to 10
MHz external crystal with no divider, CKSEL=1110 and SUT=00)
$regfile = "m48DEF.dat"
$crystal = 10000000
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Cursor Off Noblink
'Set up timer0 to count frequency
Config Timer0 = Counter , Edge = Rising
'Handle frequency timer overflow
On Timer0 Timer0_overflow
'Track number of frequency couter overflows between measurements
Dim Overflow_count As Long
Overflow_count = 0
Dim Freq As Single
Dim Inductance As Single
'Calibration factors
Dim Fcal As Single
Dim Ical As Single
'Set default calibration
Fcal = 390000.25
Ical = 65.115398
Dim W_temp As Word
'Flag designates calibration mode is active
Dim Calibrate As Bit
Calibrate = 0
'Flag designates lock mode is active
Dim Lock As Bit
Lock = 0
'Inductance formula constant 4 x Pi^2
Const Ifactor = 39.4784176043574
'Set up timer to track time
Config Timer1 = Timer , Prescale = 256
Stop Timer1
'Preload timer constant for 1 second duration at 10 MHz
Const Timer1pre = 26472
Timer1 = Timer1pre
'Handle time overflow (occurs every second)
On Timer1 Pulse
Start Timer0
Start Timer1
Enable Timer0
Enable Timer1
'Set port B pins as inputs except PB2 which fires opto
Ddrb = &B00000100
'Turn on internal pull-up resistors for port B pins
'Set PB2 low
Portb = &B11111011
'Set port D pins as inputs
Ddrd = &B00000000
'Turn on internal pull-up resistors for port D pins
Portd = &B11111111
'Set up lock character
Deflcdchar 0 , 14 , 17 , 17 , 31 , 27 , 27 , 31 , 31
Wait 1
'Check if calibration button pressed
If Pind.2 = 0 Then
'Only run calibration once per button press
'Do not allow calibration in lock mode
If Pinb.2 = 0 And Lock = 0 Then
'Activate relay to ground base inductor
Set Portb.2
'Set calibrate mode flag
Calibrate = 1
'Wait to allow calibration to obtain frequency
Wait 3
Stop Timer0
Stop Timer1
'Calculate frequency calibration factor
Fcal = Freq * Freq
'Calculate inducatance calibration factor
Ical = Fcal * Ifactor
'Adjust by capacitor value (1000pF)
Ical = Ical * .000000001
Ical = 1 / Ical
Cls
'Lcd "fCal:" ; Fcal
'Lowerline
'Lcd "iCal:" ; Ical
Lcd "Calibration"
Lowerline
Lcd "Completed..."
'End calibration mode
Calibrate = 0
'Switch relay back to inductance measurement position
Reset Portb.2
'Reset timers
Counter0 = 0
Overflow_count = 0
Start Timer0
Timer1 = Timer1pre
Start Timer1
If Pind.1 = 0 And Calibrate = 0 Then
' Enable lock mode (button 2) (except if calibrating)
If Lock = 0 Then
Lock = 1
Stop Timer0
Stop Timer1
'set cursor position
Locate 1 , 16
Lcd Chr(0)
If Pind.0 = 0 Then
' Disable lock mode (button3)
If Lock = 1 Then
Lock = 0
'Reset timers
Counter0 = 0
Overflow_count = 0
Start Timer0
Timer1 = Timer1pre
Start Timer1
'Track frequency overflows
Timer0_overflow:
Incr Overflow_count
'Measure frequency and inductance on timer1 overflow
Pulse:
Stop Timer0
Stop Timer1
Cls
W_temp = Counter0
Freq = Overflow_count * 256
Freq = Freq + W_temp
'Adjust frequncy from Hertz to KiloHertz
Freq = Freq * .001
'Calculate inductance
Inductance = Freq * Freq
'Skip if frequency below minimum to avoid divide by zero error
If Inductance > 10 Then
Inductance = Fcal / Inductance
Inductance = Inductance - 1
Inductance = Inductance * Ical
'Update LCD display based on mode
If Calibrate = 1 Then
Lcd "* Calibrating *"
Lowerline
Lcd "Please Wait..."
Else
Lcd Fusing(freq , "#.##") ; " kHz"
Lowerline
Lcd Fusing(inductance , "#.##") ; " uH"
'Reset counters
Counter0 = 0
Overflow_count = 0
Start Timer0
Timer1 = Timer1pre
Start Timer1
