Home
Wednesday, 22 May 2013
BASAVR Help BASAVR Help
ETS Series - get more for your test budget Print
ProbeSTAR uses the ETS Series to “automate” a PCB, Functional Test process.
Frymaster is a leading supplier of commercial fryers, frying systems, water-bath rethermalizers, pasta cookers and related equipment.
Frymaster approached ProbeSTAR to develop a custom “automated” test fixture which would be used to perform a comprehensive Functional Test sequence for a low-volume PCB. There were three reasons that drove the decision to automate the test process. First, the company was concern because the PCB required the use of potentially lethal AC voltages, which could pose a danger to the test Operator or the test equipment itself. Also, the test fixture should have the means to select any one of (4) configurations to accommodate (4) different versions of the same PCB. Finally, at the completion of a test, the test fixture should engage a device that leaves a permanent mark on the PCB (which indicates a PASS unit).
