Home arrow Application Notes arrow BASCOM-8051 arrow AN #42 - 555 calculator using 89S8252
Tuesday, 09 February 2010
Registration/Updates Registration/Updates
AN #42 - 555 calculator using 89S8252 Print E-mail
By K.S. Sankar, Mostek India
          If you do a lot of r/c calculations for designing an oscillator circuit using IC 555, this project may come in  handy. Even though the 555 timer IC was first introduced around 1971 by Signetics Corporation which after 35 years is still very popular and used in many schematics, there seems to be no simple calculator design anywhere since then. A programmable calculator seems to be the only quick solution or writing a program to run on a PC. Switching on a Pentium for calculating r/c values seemed ridiculous to me.
A simpler method would be to use a micro controller ATMEL-AT89s8252 and a telephone type matrix keypad with an LCD display. The Software gets the r/c values and flashes the result.  A perfect companion on your work bench.
To minimise the number of components, the circuit uses only a 7805 5volt regulator , power ON led, pull-up resistor packs  and a reset switch besides the Keypad & LCD.
The program inputs Ra , Rb and C values through the keypad ( * is used as a decimal point and # as the ENTER key) in Kilo Ohms and Microfarads and displays  t1, t2, T in milli seconds and Frequency in hertz along with the duty cycle as a %.
To enter Ra=1k , RB=10k, C=10 Mfd ( result=7hz)
Press 1<enter>
Press 10<enter>
Press 10<enter>
And see the result
Press <enter> to continue
The software uses a matrix keypad scanning routine and a straight forward calculation to get the results. The Source code is self-explanatory and the schematic are shown.
Source code:
' 555lcd.bas ver8.1 21-oct-2006
' by K.S. Sankar www.mostek.biz India
' for MCS Electronics, Holland
' (byte end hex=) 80 in misc settings
$large
$regfile = "89s8252.dat"
$crystal = 6000000
Dim N As Byte
Dim Blue As Byte
Dim Dtime As Byte
Dim Key As String * 1
Dim Kbchar As String * 10 , Tempstr As String * 11
Dim Col As Byte , Row As Byte
Dim Keyrel As Byte
Dim Ra As Single , Rb As Single , Cap As Single
Dim T1 As Single , T2 As Single , Freq As Single
Dim Duty As Single , Capt As Single
Declare Sub Getstring(kbchar As String * 10)
Declare Sub Kb_disp(key As String * 1)
Declare Sub Sub Zero()
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = P0.4 , Db5 = P0.5 , Db6 = P0.6 , Db7 = P0.7
Config Lcdpin = Pin , E = P0.3 , Rs = P0.2
Start:
Cls
'clear the LCD display
Lcd "555 calc Mostek"
Waitms 500
P1 = 0
' yellow
P0 = 0
' red
P2 = 255
' green bott as out and in
P3 = 0
' blue
'all ports off
Lowerline
Cursor On Blink
Lcd "RA in k:"
Call Getstring(kbchar)
Key =
Left(kbchar , 1)
If Key = "." Then
Tempstr =
"0" + Kbchar
Kbchar = Tempstr
End If
Ra =
Val(kbchar)
If Ra = 0 Then
Call Zero() : Goto Start
End If
Cls
Lcd "RB in k:"
Key =
Left(kbchar , 1)
If Key = "." Then
Tempstr =
"0" + Kbchar
Kbchar = Tempstr
End If
Rb =
Val(kbchar)
If Rb = 0 Then
End If
Cls
Lcd "C in mfd:"
Key =
Left(kbchar , 1)
If Key = "." Then
Tempstr =
"0" + Kbchar
Kbchar = Tempstr
End If
Cap =
Val(kbchar)
If Cap = 0 Then
End If
Cls
Lcd "Processing..."
Waitms 255
'if Ra = 1.0 : Rb = 10.0 : Cap = 10.0
'then f=7hz
Ra = Ra * 1000
Rb = Rb * 1000
T1 = Ra + Rb
T1 = T1 * Cap
T1 = T1 / 1000000
T1 = T1 * 0.693
T2 = Rb * Cap
T2 = T2 / 1000000
T2 = T2 * 0.693
Capt = T1 + T2
Freq = 1 / Capt
Duty = T1 / Capt
T1 = T1 * 1000
T2 = T2 * 1000
Capt = Capt * 1000
Duty = Duty * 100
Cls
Lcd "RA ohms=" ; Ra
Lowerline
Lcd "RB ohms=" ; Rb
' wait for # press on keypad
Cls
Lcd "cap=" ; Cap
Lowerline
Lcd "F hz=" ; Freq
Cls
Lcd "t1 ms=" ; T1
Lowerline
Lcd "t2 ms=" ; T2
Cls
Lcd "T ms=" ; Capt
Lowerline
Lcd "duty %=" ; Duty
Cls
Lcd "F hz=" ; Freq
Lowerline
Lcd "The end..press#"
Goto Start
Rem -------------functions below ---------------
Kbchar =
' green row run (0 led)
Key =
P2 = &B01111111
For Row = 1 To 4
If Row = 1 Then
P2 = &B01111110
End If
If Row = 2 Then
P2 = &B01111101
End If
If Row = 3 Then
P2 = &B01111011
End If
If Row = 4 Then
P2 = &B01110111
End If
' look for port-2 pin to go off
Debounce P2.4 , 0 , Col1 , Sub
Debounce P2.5 , 0 , Col2 , Sub
Debounce P2.6 , 0 , Col3 , Sub
If Key <> "" Then
' wait for key release
' 6-3-06
Key_rel:
P2 = &B01110000
' all rows=0 look for any col=0
Keyrel =
P2
Keyrel = Keyrel
And &B01110000
If Keyrel <> &B01110000 Then
Goto Key_rel
Else
P2 = &B01111111
Exit For
End If
Exit For
End If
Next Row
If Key = "#" Then
P2 = &B01111111
Exit Sub
End If
Kbchar = Kbchar + Key
Col1:
If Row = 1 Then Key = "1"
If Row = 2 Then Key = "4"
If Row = 3 Then Key = "7"
If Row = 4 Then Key = "."
Call Kb_disp(key)
Col2:
If Row = 1 Then Key = "2"
If Row = 2 Then Key = "5"
If Row = 3 Then Key = "8"
If Row = 4 Then Key = "0"
Call Kb_disp(key)
Col3:
If Row = 1 Then Key = "3"
If Row = 2 Then Key = "6"
If Row = 3 Then Key = "9"
If Row = 4 Then Key = "#"
Call Kb_disp(key)
End Sub
Sub Kb_disp(key)
Lcd Key
Waitms 255
End Sub
Sub Zero()
Cls
Lcd "zero not allowed"
Wait 1
End Sub
' end of program size=4137 bytes
