Home arrow Application Notes arrow BASCOM-8051 arrow AN #38 - ADC using TLC549 serial 8bit IC
Thursday, 02 September 2010
Registration/Updates Registration/Updates
BASCOM Help BASCOM Help
AN #38 - ADC using TLC549 serial 8bit IC Print E-mail
by K.S.Sankar - Mostek Electronics ( www.mostek.biz )
Originaly published in ELECTRONICS FOR YOU magazine ( INDIA - W W W . E F Y M A G . C O M )
  If you run out of Port pins when designing with parallel interface 8-bit ADC like the 0804, switch over to the new serial interface 8-bit ADC chips like the TLC549 from Texas Instruments . This 8-pin ADC gives you 8-bit resolution with a 3 way interface saving you precious port pins in projects using smaller micros like the 2051.
    This article provides valuable info on the SPI interface using CS DIN and CLOCK pulses. The micro controller used is ATMEL-89s8252 running at 6Mhz for convenience although the program will work on a smaller footprint micro.
 LCD is used to display the output 0-255 with an adjustable pot in the circuit that provides 0v to 5v to the analogue IN.
Brief Details about TLC549 form the data sheet:-
_ 8-Bit Resolution A/D Converter
_ Differential Reference Input Voltages
_ Conversion Time ...17 ms Max
_ Wide Supply Range ...3 V to 6 V
_ Low Power Consumption ...15 mW Max
_ CMOS Technology
Description
The TLC548 and TLC549 are CMOS analog-to-digital converter (ADC) integrated circuits built around an 8-bit switched-capacitor successive-approximation ADC. These devices are designed for serial interface with a microprocessor or peripheral through a 3-state data output and an analog input. The TLC548 and TLC549 use only the input/output clock (I/O CLOCK) input along with the chip select (CS) input for data control. The maximum I/O CLOCK input frequency of the TLC548 is 2.048 MHz, and the I/O CLOCK input frequency of the TLC549 is specified up to 1.1 MHz.
More info in the data sheet
The simple source code is given below:-
' 549lcd.bas
' research on TLC549 adc ic 8-bit 3 wire interface
' by K.S.Sankar www.mostek.biz for MCS Electronics AN
' 3-oct-2006
' LCD SHOULD DISPLAY 0-255 FOR 0V TO 5 VOLT INPUT
$crystal = 6000000
$regfile = "89s8252.dat"
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = P0.4 , Db5 = P0.5 , Db6 = P0.6 , Db7 = P0.7
Config Lcdpin = Pin , E = P0.3 , Rs = P0.2
P0 = 0
P1 = 0
P2 = 0
P3 = 0
Declare Sub Getval_549(w1 As Byte)
Dim W1 As Byte
Cs
Alias P1.2
Clock
Alias P1.0
Din
Alias P1.1
' not used
Dout
Alias P1.3
Dout = 1
' INPUT PULLED HIGH FOR READING
Dim V As Byte
Dim Bit2 As Bit
Cls
Lcd "ADC 549 RESEARCH"
Begin:
Call Getval_549(v)
' ans in v
Lowerline
Lcd " "
Lowerline
Lcd "Ans=" ; V
Waitms 255
Goto Begin
' SUBROUTINES / FUNCTIONS
Sub Getval_549(_w As Byte)
Dim _w As Byte , _j As Byte
 Cs = 0
 V = 0
For _j = 1 To 8
' read dout pin
 Bit2 = Dout
Shift V , Left , 1
 V.0 = Bit2
' send clock PULSE
 Clock = 1
 Clock = 0
Next _j
 Cs = 1
Waitms 1
 _w = V
End Sub
