| View previous topic :: View next topic |
| Author |
Alex-Dan
Posted: Sun Feb 23, 2025 5:46 pm Post subject: |
fourth: The compiler settings have a section for setting the end of memory address:
Options >> Compiller >> Misc
Misc> Byte End(Hex)
If this value is set incorrectly, the program does not work.
But the Dat-file has a corresponding section for specifying the size of this memory: IRAM = ###
Is this a feature of the compiler (it is not fully written) or do I not understand something about the operation of this type of uC? |
| Back to top |
Posted: Mon Mar 03, 2025 9:29 pm Post subject: |
the byte end you can set since the program often needs some stack. if you set it to the size of ram you will see you run into problems. _________________ Mark |
| Back to top |
Alex-Dan
Posted: Fri Mar 14, 2025 12:24 pm Post subject: |
I see, thank you.
If I understand the compiler's work correctly, then the size of this stack should be calculated approximately the same as for the HWstack in BascomAVR. |
| Back to top |
plouf
Joined: 19 Jan 2012 Posts: 117 Location: Athens,Greece
Posted: Fri Aug 29, 2025 3:59 pm Post subject: |
| albertsm wrote: | support for HW means support for interrupts, serial (uart) and other hardware found in a normal 8051.
the other hardware support depend on how good the info is in the datasheets. i do not have time to do extensive research(puzzling). (unless it is paid for)
so expect the same as for other 8051 processors. and one can always access the registers so it would not be even required.
i have done some projects with Chinese pdf's and these docs are often badly translated. making it a puzzle. but maybe this is the exception and it is not so bad.
i need to finish some other tasks first but i scheduled time to get things done and then i know all about it  |
after 1 year, is any idea in horizon ?
like the decision in chips? some kind of prelimiraly test version can test ? _________________ Christos |
| Back to top |
Alex-Dan
Posted: Sat Aug 30, 2025 12:20 pm Post subject: |
I stopped hoping long ago...
I wrote the subroutines for working with the chips myself.
YES, the previously listed types of variables and other things are very much lacking, but what can you do
I understand perfectly well: respected Mark earns money on AVR and he alone does all the work.  |
| Back to top |
Posted: Sat Aug 30, 2025 12:48 pm Post subject: |
As long time users you should know that i do not give release dates. And to be honest i find these kind of messages demotivating.
After the last AVR release i have worked long on the 8051. But since it is an old product it is not a good idea to make some patches. This means i started converting the code so it is more simple to maintain and extend.
A correction: i do not work alone but i have contract workers and family assisting me. But not with all tasks.
Anyway, top priority is always support and that was to be expected after the 2087 release with the TYPE support.
And as all people i need a holiday once in a while.
You also should know i always keep my promise sooner or later.
And as i do not charge for updates it also means that i need to do custom jobs once in a while. Contract workers and the MCS server are not cheap. _________________ Mark |
| Back to top |
plouf
Posted: Sat Aug 30, 2025 12:55 pm Post subject: |
I know and understand all these,
I dont feel very "pressuring" to ask after a year sorry if anything like this look like to do:-)
I also not pressure, but ask stuff like "the family of mcu/devices choosen"
So i can have a idea and/or get my own these for my own test in the meanwhile  _________________ Christos |
| Back to top |
Posted: Sat Aug 30, 2025 1:05 pm Post subject: |
just do whatever you want. when there is info i share it somewhere on the forum. _________________ Mark |
| Back to top |
Alex-Dan
Posted: Tue Sep 16, 2025 7:26 am Post subject: |
Mark, we don't want to offend you
You do a great job, and your products are interesting to us!
| albertsm wrote: | | just do whatever you want. when there is info i share it somewhere on the forum. |
| Back to top |
begunof
| Back to top |
plouf
Posted: Wed Dec 31, 2025 5:52 pm Post subject: |
Very nice congratulations
So the star we see in final frames of video, in a led panel controlled by a mcu that makes that effects?
Is the sound from mcu too ? _________________ Christos |
| Back to top |
begunof
Posted: Wed Dec 31, 2025 6:31 pm Post subject: |
The final frames show a demo routine that displays a linear brightness gradient at a random angle with ({360/256}°; 255 eq. 358,59375°) increments (in video step is 30 * increment).
The background music was generated by suno ai.
| Back to top |
begunof
Posted: Sat Jan 17, 2026 2:37 pm Post subject: |
I'd like to be able to work with lib files that are located alongside the bas file, not just those in the \lib directory. I'm forced to use $include for each procedure as a separate file as here:
| Code: | Ab = 255 : Bb = 31 : Cb = 5
$include "asm_calc.bas"
do ... loop |
| Back to top |
