ATXMEGA32A4U Real clock
matjazs
PostPosted: Sun Jul 20, 2025 12:57 pm    Post subject: ATXMEGA32A4U Real clock Reply with quote
Hello.
I'm trying to configure real time on my ATXMEGA32A4U. It's not working.
It's delayed by about 3 seconds every minute.
I have:
ATXMEGA32A4U
external 16MHz crystal oscillator and configured internal 32KHz oscillator.
Any idea what's wrong?
This is my example.
' File Name:       CLK_XM32-TST.bas
' Hardware PCB:    GSM800L-PLC
' Date:            2025-07
' Controller:      ATXMEGA32A3U
' LCD:             128x64 - glcd-ST7567.lib"
' WiFi: ESP8266 Firmware "guio_esp8266.ino"
' GUI-O Ver v.1.0.101  2025-07
$regfile = "xm32a4udef.dat"
$crystal = 32000000
$hwstack = 150
$swstack = 150
$framesize = 200
Config Watchdog = 8000
Start Watchdog
Reset Watchdog
'-Oscilator --------------------------------------------------------------------
Config Osc = Disabled , Pllosc = Enabled , Extosc = Enabled , 32khzosc = Enabled , Range = 12mhz_16mhz , Xosc_sel_startup = Xtal_16kclk , Pllsource = Extclock , Plldiv2 = Disabled , Pllmul = 2
Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1
Config Clock = Soft , Rtc = 1khz_int32khz_ulp , Gosub = Sectic       ' we select the internal 1 KHz clock from the 32KHz internal oscillator
Config Date = Dmy , Separator = -
Config Submode = New
'-EEPROM XMEGA------------------------------------------------------------------
Config Eeprom = Mapped
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Com3 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Com5 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'--Open all UARTS---------------------------------------------------------------
Open "COM1:" For Binary As #1                               'Bluetooth HC06
Open "COM3:" For Binary As #3                               'GSM modem 800L
Open "COM5:" For Binary As #5                               'WiFi  ESP8266
Config Portb.3 = Output
Config Print0 = Portb.3 , Mode = Set
Config Serialin = Buffered , Size = 200
Config Serialin2 = Buffered , Size = 255
Config Serialin4 = Buffered , Size = 200
'-PIN---------------------------------------------------------------------------
Config Porta.7 = Output                                     'LED Display
Ledd Alias Porta.7
Set Ledd
'-LCD ST-7567-------------------------------------------------------------------
$lib "glcd-ST7567.lib"
Config Vport0 = A , Vport2 = C
Config Graphlcd = 128x64sed , Si = Port2.4 , Sclk = Port0.6 , A0 = Port2.5 , Rst = Port2.7 , Cs1 = Port2.6       'Veliki
Const Negative_lcd = 0
Const Mirror_y = 1
Const Mirror_x = 0
Dim N As Byte
'N = 35                                                      'mali
N = 50                                                      'Veliki
Initlcd
Lcdcontrast N
Time$ = "14:00:00"
Date$ = "20-07-25"
Main:
Reset Watchdog
Sectic:
Reset Watchdog
    Setfont Font5x5
    Lcdat 7 , 1 , Time$
    Lcdat 7 , 58 , Date$
'-GLCD-------------------------------------------------------------------------
$include "font5x5.font"
$include "font5x12.font"
(BASCOM-AVR version : 2.0.8.7 )
JC
PostPosted: Sun Jul 20, 2025 5:42 pm    Post subject: Reply with quote
I don’t know what the issue is, but I have a thought or two that you could try.
For initial testing remove all of the code except for the Clocks, Interrupts, and Display.
Remove all of the USART (serial port) code.
Remove the Open… and the Config Serialin…
REMOVE the Watchdog code
Remove the EEPROM code.
If you have a floating input on one of the serial input pins it could be continually interrupting.
The Sectic uses the Lo ISR priority.
The ISR driven, buffered, serial input uses the MED priority, so it could be continually interrupting the program, and not allowing the Sectic to run as you think it should.
Make sure that none of your serial communications input pins are floating, (not connected to anything).
Although it is not the cause for your problem, you could make the Sectic ISR much shorter if you simply set a flag in the routine, and then actually update the GLCD in the Main Loop, (and reset the flag). Since you do not change the Font being used, you also can call the SetFont once, and not every time you update the GLCD.
Once the clock is working, then add back your other code, one part at a time.
You could also flash an LED at one flash per second, within your Main Loop, to make sure that the serial communications are not tying up the micro's processing time.
The Sectic is very short, and an LED that flashes using Waitms to flash on and off should flash at about 1 / sec.
If the processor is continually running ISRs, then the Main Loop and Lo priority ISRs don't get to run very much processor time, and the LED will also flash very slowly.
(See Config Priority and the Roundrobin mode, to allow Sectic to fire, (but that isn't the best way to fix this problem.))
JC
matjazs
PostPosted: Sun Jul 20, 2025 6:47 pm    Post subject: Reply with quote
JC I changed it as you suggested, but nothing changed.
I think, there is something wrong with the parameter settings.
' Date:            2025-07
' GUI-O Ver v.11.07  2021-08
$crystal = 32000000
$hwstack = 150
$swstack = 150
$framesize = 200
'Config Watchdog = 8000
'Start Watchdog
'Reset Watchdog
'Config Eeprom = Mapped
'Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Config Com3 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Config Com5 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Open "COM1:" For Binary As #1                               'Bluetooth HC06
'Open "COM3:" For Binary As #3                               'GSM modem 800L
'Open "COM5:" For Binary As #5                               'WiFi  ESP8266
'Config Portb.3 = Output
'Config Print0 = Portb.3 , Mode = Set
'Config Serialin = Buffered , Size = 200
'Config Serialin2 = Buffered , Size = 255
'Config Serialin4 = Buffered , Size = 200
Ledd Alias Porta.7
Set Ledd
Const Mirror_y = 1
Const Mirror_x = 0
Dim N As Byte
'N = 35                                                      'mali
N = 50                                                      'Veliki
Initlcd
Lcdcontrast N
'Reset Watchdog
'Wait 3
Time$ = "19:00:00"
Date$ = "20-07-25"
Setfont Font5x5
Main:
'Reset Watchdog
    Lcdat 7 , 1 , Time$
Sectic:
'Reset Watchdog
    'Setfont Font5x5
    'Lcdat 7 , 1 , Time$
    'Lcdat 7 , 58 , Date$
PostPosted: Sun Jul 20, 2025 7:48 pm    Post subject: Reply with quote
Start with the Xmega sample provided by Mscelec, see if this works.
PostPosted: Tue Jul 22, 2025 9:55 am    Post subject: Re: ATXMEGA32A4U Real clock Reply with quote
From the help:
The internal 32 kHz Ultra Low Power (ULP) is a very low power clock source, and it is not designed for high accuracy.
Try the option:
Rtc = 1KHZ_INT32KHZ_RCOSC
The following Microchip document talks about 1% accuracy for the 32kHzRC-oscillator, which - 14 minutes per day - is rather useless for a proper time-keeping device:
https://onlinedocs.microchip.com/oxy/GUID-E67844AC-6EF1-4149-B445-44B52E1F1DC2-en-US-2/GUID-0C5D02AE-E09D-4DB5-89F7-1448DD1C7F3E.html?hl=rc32kcal
Anyway, 5% as the reported 3 out of 60 seconds seems a bit much, the 32kHzRC can be calibrated via OSC_RC32KCAL, however a simple external 32768Hz crystal will be more accurate.
Normally calibration is done already at startup, but if you're curious you can compare the content of OSC_RC32KCAL against the value in the signature row.
See:
calibration byte from the signature row
https://ww1.microchip.com/downloads/en/Appnotes/XMEGA-Internal-RC-Oscillator-Calibration-00002644A.pdf
matjazs
PostPosted: Tue Jul 22, 2025 5:36 pm    Post subject: Reply with quote
Try the option:
Thank you. Now is 1 second per minute delay.
Although it is not exact, it is better.
The time in my application is not that important, but I would like to be as accurate as possible on the LCD screen.
There is no room on my PCB for e.g. DS2331.
Every time I connect to the device (GUI-O), I set the time to the exact value.
PostPosted: Tue Jul 22, 2025 8:46 pm    Post subject: Reply with quote
As already said, alter (increase) OSC_RC32KCAL.
You can look up this register in the processor's Dat-file.
OSC_RC32KCAL is a 8bit-register, it should work if your code in startup looks like that:
Dim RCCal As Byte
RCCal = OSC_RC32KCAL
RCCal = RCCal + 10
OSC_RC32KCAL = RCCal
May work also:
OSC_RC32KCAL = OSC_RC32KCAL + 10
matjazs
PostPosted: Fri Jul 25, 2025 11:48 am    Post subject: Reply with quote
May work also:
Thank you. I changed this on:
OSC_RC32KCAL = OSC_RC32KCAL + 7
I think 10 is too fast.
matjazs
PostPosted: Fri Jul 25, 2025 11:52 am    Post subject: Reply with quote
May work also:
PostPosted: Fri Jul 25, 2025 4:48 pm    Post subject: Reply with quote
Sure, it was only an example value.
