How to use TWIy on XMEGA with MCU_REVID < 7
enniom
PostPosted: Mon Apr 21, 2025 2:54 pm    Post subject: How to use TWIy on XMEGA with MCU_REVID < 7 Reply with quote
Dear Forum,
Mark has documented this problem very well. In my case, I ordered 25 of these uC and, when I received them, found out they were MCU_REVID = 06. When programmed with this code, the uC simply stops responding.
'                  (c) 1995-2021, MCS
'                      xm128-TWI.bas
$regfile = "XM192A3Udef.dat"
$hwstack = 64
$swstack = 40
$framesize = 40
$crystal = 32000000
'NOTE" "Xmega revision: " ; Mcu_revid                   ' make sure it is 7 or higher !!! lower revs have many flaws
Dim Twi_start As Byte                                       ' you MUST dim this variable since it is used by the lib
Const _twi_stop_2 = 1
Open "TWIE" For Binary As #2
Config Twi = 100000                                         ' 100KHz
I2cinit #2
I2cstop #2
I2cstart #2                                                      'the uC "HANGS" / STOPS here. No additional code is processed
My question is: Is there a way to use the TWI software library routines with XMega?? Has anyone successfully modified the library to use software TWI on XMega uC? Any and all assistance would be greatly appreciated.
$lib "i2c_twi.lbx"                                         ' we do not use software emulated I2C but the TWI
Config Scl = Porte.1                                        ' we need to provide the SCL pin name
Config Sda = Porte.0                                        ' we need to provide the SDA pin name
I2cinit                                                     ' we need to set the pins in the proper state
Config Twi = 100000                                         ' wanted clock frequency when using $lib "i2c_twi.lbx"
As expected, this code generates errors as it intended for regular Mega AVRs.
(BASCOM-AVR version : 2.0.8.7 )
PostPosted: Mon Apr 21, 2025 3:43 pm    Post subject: Reply with quote
Here you have Very Happy Happy coding Very Happy
'*                         I2C CONFIG                            *
   Const Softi2c = 0
#if Softi2c
 $forcesofti2c                                              ' with this the software I2C/TWI commands are used when inlcuding i2c.lbx
 $lib "i2cv2.lib"
  I2cinit
  Config I2cdelay = 40                                      '40 - i2c na 10kHz
' Config I2cdelay = 10                                       'should be 100kHz
#else
 Open "twie" For Binary As #14
 Config Twie = 10000                                        '10kHz
 I2cinit #14
#endif
Curious is that I have Xm256A3U REV-6 and Xm384C3 REV-1 and TWIE works well on them. I have this code abowe because I switch someone`s Soft_I2C code into more stable TWIE (this code have much interrupts that can do some impact to that software bitbang).
But I can tell that firstly I found mistake in the this owner hardware. There was a level shifter for 3V3 to 5V1 I2C that was soldered inverted. Soft_I2C works with this somehow but TWIE did not want to. When I fix owner hardware then it turned out to TWIE works much better than soft Very Happy
Check B-Flash -my MCS bootloader app for Android
enniom
PostPosted: Mon Apr 21, 2025 5:37 pm    Post subject: Reply with quote
Thank you EDC for taking the time to help. In this case there is no level shifter - the slave pressure/temperature sensor is on 3V3.
I would like to ask a favor (since I'm not so familiar with the soft I2C). This is the code I'm using:
$hwstack = 64
$swstack = 40
$framesize = 40
$crystal = 32000000
$lib "i2cv2.lib"
'Config I2cdelay = 40                                        '~10kHz
Config I2cdelay = 10                                        '~100kHz
Waitms 10
I2crepstart
Waitms 10
I2cstop
Waitms 10
'TWI for Amphenol 442-ELVH-L04D-I-N2A4
Dim I, Twi_addr , Rawb(4) As Byte
Twi_addr = &H28
Shift Twi_addr , Left , 1
Twi_addr.0 = 1                                              'READ
  For I = 1 To 4
      Rawb(i) = 0
  I2crepstart
  Waitms 1
  I2cwbyte Twi_addr
  Waitms 1
  I2crbyte Rawb(1) , Ack
  Waitms 1
  I2crbyte Rawb(2) , Ack
  Waitms 1
  I2crbyte Rawb(3) , Ack
  Waitms 1
  I2crbyte Rawb(4) , Nack
  Waitms 1
  I2cstop
'  Waitms 10
  Wait 3
This code receives &HFF for only the first byte receive (and only every second time it is read from the slave chip). All other values are &H00.
Thanks in advance for any your help you can offer.
E
PostPosted: Mon Apr 21, 2025 6:02 pm    Post subject: Reply with quote
Im not familiar wit those sensors yet but i think your first "repstart" then "stop" causes the first exeption described in the note.
Then consistent using the "repstart" dont clears the error that can be done by normal "start" I think.
So using "repstart" in the loop I think cuses second exeption and so on...
Did you try normal "start" instead of "repstart"?
enniom
PostPosted: Mon Apr 21, 2025 6:13 pm    Post subject: Reply with quote
Thank EDC.
Removing I2cREPSTART and I2cStop before the loop and using only I2cStart and I2cStop in the loop gives the same result.
If you have a minute, please consider the requirements in the section "START condition (ST)" of the datasheet. I cannot determine if this code meets those conditions.
E
_jarek_
PostPosted: Mon Apr 21, 2025 11:21 pm    Post subject: Reply with quote
Arrow enniom
You don't need
you must also change the entry
Config Twi = 100000
to
Config TwiE = 100000
declaration running on 64A3U
config porte.0=output
config porte.1=output
dim twi_start as byte
open "twie" for binary as #5
config twie=400000
i2cinit #5
PostPosted: Tue Apr 22, 2025 4:53 am    Post subject: Reply with quote
I would recommend some debug info even if you dont use any COMx from Xmega.
Here, for example, I open a serial on PORTF.3 where I print the debug data.
$hwstack = 64
$swstack = 40
$framesize = 40
' ***************** SYSTEM CLOCK CONFIG **************************
'                INTERNAL 32MHz NO PRESCALE
' ENABLING AUTOMATIC OSCILLATOR CALIBRATION
Osc_dfllctrl.0 = 1
Dfllrc32m_ctrl.0 = 1
'*                         I2C CONFIG                            *
Const Softi2c = 0
#if Softi2c
   $lib "i2cv2.lib"
   I2cinit
   Config I2cdelay = 10                                      ' 100kHz
#else
   Config Twie = 100000                                       '100kHz
   I2cinit #14
#endif
'************ CONFIGURATION FOR SERIAL ON PORTF ******************
Open "COMF.3:115200,8,n,1" For Output As #7
Const Com = 7
Debug On
Dim I , Twi_addr , Rawb(4) As Byte
Twi_addr = &H28
Debug #com , "{013}{010}Debug started"
 #if Softi2c
   I2cstart
   If Err = 0 Then
      I2cwbyte Twi_addr
      If Err = 0 Then
         For I = 1 To 4
            Debug #com , Hex(rawb(i)) ;
         Debug #com , ""
         Debug #com , "Device dont responding at this address"
      Debug #com , "Bus start error"
   I2cstop
 #else
   I2cstart #14
   If Err = 0 Then
      I2cwbyte Twi_addr , #14
      If Err = 0 Then
         I2crbyte Rawb(1) , Ack , #14
         I2crbyte Rawb(2) , Ack , #14
         I2crbyte Rawb(3) , Ack , #14
         I2crbyte Rawb(4) , Nack , #14
         For I = 1 To 4
         Debug #com , ""
   I2cstop #14
 #endif
enniom
PostPosted: Tue Apr 22, 2025 12:56 pm    Post subject: Reply with quote
Thank you Jarek and EDC. You have given me more than enough to get started.
In the future, we will ask the "Polish Connection" for help with I2C/TWI problems.
:D
E
PostPosted: Tue Apr 22, 2025 1:29 pm    Post subject: Reply with quote
If you finally find the cause of this troubles then you can convert those all I2c routines into one line.
I2creceive Twi_addr , Rawb(1) , 0 , 4
This will do Start, read four bytes and do Stop Very Happy
You only should not set that R/W bit manually.
