ATXtiny3217 USART RX buffer bug?
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR XTINY/MEGAX/AVRX
kasny.ondrej
PostPosted: Wed Jul 17, 2024 3:44 pm    Post subject: ATXtiny3217 USART RX buffer bug? Reply with quote
Hello Mark me again,
I have some troubles with USART. I spent two days until I figured that Input statement does not clear flags or dont read whole buffer thus MCU goes wild. Now facing different problem. Messages between two xtinys are not 100% realible. Not every message is complete.
Changing baudrate won't solve anything.
Recieve side code:
$regfile = "atxtiny3217.dat"
$hwstack = 50
$swstack = 50
$framesize = 60
'$sim
'$dbg
Config Sysclock = 16_20mhz , Prescale = 2
'-----------------------UART CONFIG------------------------------------------------
Config Com1 = 38400 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1 , Baud_offset = Osc16_3v3
Config Serialin = Buffered , Size = 40
'---------------------------SPI CONFIG------------------------------------------------
Config Spi0 = Hard , Clockdiv = Clk16 , Data_order = Msb , Mode = 0 , Master = Yes , Ss = Auto
If Ischarwaiting() = 1 Then
         Uart_input_byte = Inkey()
         Uart_income_data = Uart_income_data + Chr(uart_input_byte)
      Loop Until Ischarwaiting() = 0
      print Uart_income_data
end if
waitms 15
I found that problem is in reciving side. When I send messages into xtiny via USART (USB 232 converter) and then print them back, they are often separated, but when I am only printing anything that is not from input buffer it is fine:
Also in loop I need to have wait statement or Ischarwaiting would not work.
Tested on two xtinys and it does the same. Also if messsage is longer it makes much more often
PostPosted: Wed Jul 17, 2024 3:57 pm    Post subject: Reply with quote
Your receiving method is poor.
You should wait for some string termination sign like Carriage Return or Line Feed.
This is my frequently used method:
'--[ USART0 COM1 USB ]------------------------
 If 0 < Ischarwaiting(#usb) Then
   Char = Inkey(#usb)
   Select Case Char
    Case 10                               'LF sign -> simply swallow and ignore
    Case 13 : Got_str1 = 1         'CR sign -> parse msg
    Case Else
     Command1 = Command1 + Chr(char)
   If Len(command1) > 49 Then Got_str1 = 1                '
   If Got_str1 = 0 Then Cmd_timeout1 = 50                   '50x10ms
   'end if Ischarwaiting
If Got_str = 1 Then
 Got_str = 0
  Cmd_timeout1 = 0
      'parse new message
 Command1 = ""
'--[ TIMER2 10ms ]----------------------------
 If Tifr2.ocf2a = 1 Then    'valid for Mega2560
  Tifr2.ocf2a = 1
'COM1 USB
     If Cmd_timeout1 > 0 Then
      Decr Cmd_timeout1
       If Cmd_timeout1 = 0 Then
        'Got_str1 = 1
         Command1 = ""
Eventually, in your method, after the first Ischarwaiting() you should wait some time in the Do Loop Until Ischarwaiting = 0 for receive next character. Baud 38400 means ~250us for one byte i think.
Check B-Flash -my MCS bootloader app for Android
kasny.ondrej
PostPosted: Wed Jul 17, 2024 4:25 pm    Post subject: Reply with quote
Ok, I will process it into code a give it a try again.
kasny.ondrej
PostPosted: Wed Jul 17, 2024 4:42 pm    Post subject: Reply with quote
Works!!!! Very Happy Thank you EDC, I thought that every command take its own time to process it without errors. Now I see that it is not true and any type of wait statement must be in code included. I apologize to all for my unconscious.
PostPosted: Wed Jul 17, 2024 5:11 pm    Post subject: Reply with quote
I don't think your actually using serial buffering. Your missing the:
Open "COM1:" For Binary As #1
enabling interrupts
reading the buffered serial data over #1 ( Inkey(#1))
It works for you as your reading directly from the serial input without any buffering, and your CPU is doing nothing more than waiting for data from the serial port.
Ian Dobson
kasny.ondrej
PostPosted: Wed Jul 17, 2024 5:20 pm    Post subject: Reply with quote
Forgot to include here on web into sample code, of course Enable Interrupts is in code.
kasny.ondrej
PostPosted: Fri Mar 21, 2025 2:13 pm    Post subject: Reply with quote
Hello guys. I have encoutered another buffer bug seems to me at Atxtiny3217. From some reason exceeding buffer size start causing random executing errors those errors are perfectly repeatable. The thing is: Let say we have Config serialin = 50. If come more bytes than this, let say 80+ bytes, some variables gets corrupted. It look like buffer continues to write in SRAM where other variables are already stored and thus overwriting them. Code then starts act like crazy. Somethin starts executing when it shouldn't, primarily I would say thanks to corrupted variables. Where should be zero is one and magic starts to happening then.
PostPosted: Fri Mar 21, 2025 3:08 pm    Post subject: Reply with quote
you should post a sample that will demo this.
serial buffered input is used a lot and the only difference between xtiny/normal AVR is that other registers need to be accessed.
i also do not recall that 3217 has some specific difference.
for your info : when the buffer is full it will not store more data.
so make a small as possible example and test it. when it demos this bug post it. you should also give info about the data you send.
that said : when you read data and add it to a string and do not check the string length it can overwrite the string. bur that is USER code not a built in function/code.
and finally when you made your own hardware post the schematic too.
kasny.ondrej
PostPosted: Mon Mar 24, 2025 7:22 am    Post subject: Reply with quote
My apologies Mark I am idiot as usual. You are right. I didn't realized when string is bigger than dimensioned it starts to overwrite another data behind him. Another valuable experience. Always check length of string. Smile There is a saying: He can't see the forest for the trees.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR XTINY/MEGAX/AVRX All times are GMT + 1 Hour
You can post new topics in this forum
You can reply to topics in this forum
