| View previous topic :: View next topic |
| Author |
altron
Posted: Thu Jan 18, 2018 9:10 am Post subject: ASM start character ! |
Hi all
I have just upgrade from version 2.0.79 to 2.0.8.1.
I am getting errors compiling any previously used code with ASM in it.
After a bit of reading I see that in version 2.0.8.0 there was a change to the way ASM is written in any bascom file.
The trouble for me is that some of the files I use like LCD driver code (such as ili9341) that has a lot of lines of ASM.
Do I need to go through all these files and put a ! at the start of each ASM line?
Any way I can get around this?
Thanks.
Altron.
| Back to top |
laborratte
Posted: Thu Jan 18, 2018 1:48 pm Post subject: |
You can enclose blocks of assembler code in the
directives. See help. |
| Back to top |
altron
Posted: Fri Jan 19, 2018 1:45 am Post subject: |
I have gone through and put ! in front of all lines in the .inc file.
It has a compile error on lines that already started with a !. There is now two ! at the start of some lines.
The line reads now reads !!OUT LCD_CTRL_PORT, R16 and gives errors.
Error : 215 Line : 652 Unknown ASM mnemonic [!OUT LCD_CTRL_PORT, R16] , in File : Ili9341_inc for A4275NG ASM FIXED.inc
Should there be only one ! and never double up.
What does the original ! do in ASM?
Thanks |
| Back to top |
Posted: Fri Jan 19, 2018 3:01 am Post subject: |
In ASM ! does not mean nothing. Exclamation mark in Bascom code means ASM instructions..for compier(you want to use ASM and you know what you`re doing)
Asm instructions you can read in the Atmel notes Some of the procesors have them >130 some of them have them less like Attiny (for example they dont have hardware multiplying(I was read this somewhere, I can be wrong))
In the another way *Basic in the libraries means basic language...
My advice is: If you want to run code that works on the previous version you should click on the every error code and fix it then CTRL + S
This will adapt library to the new compiler.
Do you use Code Explorer? |
| Back to top |
altron
Posted: Fri Jan 19, 2018 6:55 am Post subject: |
Looking at the HELP in the older versions it recommends to have a ! at the start but it wasn't required to compile.
I guess thats why there is some ASM with ! at the start and some without.
I tried converting all double !! to single ! and it compiles and works.
I dont use code explorer. Should I be? |
| Back to top |
altron
Posted: Fri Jan 19, 2018 7:34 am Post subject: |
I lied, I do use code explorer.
Doesn't seem to work on .INC files.
Good for .BAS. |
| Back to top |
Posted: Fri Jan 19, 2018 1:07 pm Post subject: |
Code explorer works on INC files but only in project mode. _________________ Mark |
| Back to top |
